Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 12-03-2012, 01:09 PM   #1
BUDDY BLANKENSHIP
Member#: 337079
Default Suggestions For 2.2 Build
Have A 97 Outback W A 2.2 That I Want To Rebuild. Suggestions For Cams? Low End Power?
BUDDY BLANKENSHIP is offline   Reply With Quote
Old 12-03-2012, 02:12 PM   #2
tunedbysti
Member#: 334146
1998 Honda Accord LX
2000 Chevy Silverado 1500
I have a 1999 Legacy with the 2.2 and as far as I can find, it would take A LOT of moolah to get more power out of it. I mean you can do things like upgrade the intake and exhaust work and things like that, but as far I've been able to find out, there's not too much we can do to get more power out of 'em. BUT if you have the money to do it, and the time and know-how, go for it! That'd be cool!!
tunedbysti is offline   Reply With Quote
Old 12-03-2012, 03:23 PM   #3
GrundleJuice
Member#: 165749
High compression pistons, combustion chamber reworking, light port work, 5 angle valve job, cams for your desired tq curve, EL headers with a quality merge collector. Of course, all this stuff would require a tune to take advantage of it and that means a stand alone ecu.
Cams without a good header is leaving a bunch of tq on the table. Cams without a tune can be harmful to the engine if the factory ecu can not adjust timing enough.
Any way you slice it, the $ to power ratio is pretty crappy on n/a ej engines.
Old 12-03-2012, 04:39 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
High compression frankenstein
/thread.
Jay
Old 12-04-2012, 04:57 AM   #5
subi400
Member#: 216984
1996 Impreza outback
Green
/thread.
Jay
^^^ I agree! I am about to start getting parts for a 2.5 block and phase 1 2.2 heads so I can run my original steel borla single port header with 1 high flow cat and a straight threw muffler. Going to do some light port work along with the delta 220's. Already have a lightweight flywheel for it.
So, to the OP, doing the 2.5 block and 2.2 heads is about the cheapest power upgrade you can do for these cars along with some torque grind cams and opening up the exhaust some.
subi400 is offline   Reply With Quote
Old 12-10-2012, 12:59 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I'm actually looking to do this to my wifes 99 Impreza L since it has a rod knock. Her 2.2L heads on a 2.5L SB.
Old 12-13-2012, 08:53 PM   #7
200kimpreza
Member#: 282945
97 impreza
red
Look at paeco. They have three cam set ups and they can port/polish, oversize valves, knife edge the crank to find some lost hp.
200kimpreza is offline   Reply With Quote
