Welcome to the North American Subaru Impreza Owners Club Saturday August 30, 2014
Mid Atlantic Impreza Club
Old 12-27-2012, 06:59 PM   #1
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Default Anybody in DE free tomorrow with axle repair experience?
My ****ing car pissed its oil out from the passenger side axle. I guess I'm going to try to snag a new seal from Subaru tomorrow. If anybody is local that could help, I'd really appreciate it. I'm in over my head and I have NO idea how this happened
skatin707 is offline   Reply With Quote
Old 12-27-2012, 07:45 PM   #2
skatin707
Member#: 251552
2014 FXT
Forgot to mention, steak beer and money involved (if you are of age).
Old 12-27-2012, 08:03 PM   #3
enjoi1968
Member#: 234416
It's A BRAAAAAHtato,
Yo.
I'm leaving lewes now unfortunately, but its a pretty easy job with hand tools
the jist is;
Looks like the oil seal on the end of the axle either went or the axle moved out (weird).
-Take off wheel
-remove lower castle nut on lower control arm
-stand on control arm and pop hub loose
- remove axle locknut, tap axle out of hub with dead blow hammer, while pulling hub out and towards rear of wheel well.
-the oil seal will be either there and broken or totally missing, in which case the groove where it should go on the trans side of the axle will be apparent.
-reverse order to re-assembly making sure the seal 'snaps' into the trans when re-inserting, and check trans fluid level after all said and done
enjoi1968 is offline   Reply With Quote
Old 12-27-2012, 09:07 PM   #4
skatin707
Member#: 251552
2014 FXT
Thanks man, I'll give it a try. I think my axle came out a bit while swapping my coils on.
Old 12-27-2012, 10:27 PM   #5
Jard
In the silly seat
Member#: 34935
SPB- 2013 Smugmobile
and DADCORE
That's not from the axle, it's from the transmission. So refill the tranny fluid after you "fix" it.
Jard is offline   Reply With Quote
Old 12-27-2012, 10:35 PM   #6
skatin707
Member#: 251552
2014 FXT
Right, it's from where the axle meets the transmission.
Old 12-28-2012, 12:44 AM   #7
Abnormal
Douchebag Moderator
Member#: 149626
2005 CGM FXT
Rocket Box! :D
What were you going when this happened?
Abnormal is offline   Reply With Quote
Old 12-28-2012, 05:43 AM   #8
skatin707
Member#: 251552
2014 FXT
I was turning around in my driveway. I moved a total of 50 feet, at most.
