Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Exterior/Styling
Old 12-13-2012, 05:33 PM   #1
KSTech
Vendor Sales Rating: (6)
Member#: 143570
Default KSTech Hood Vents, Scoop Deletes, Diverter Plates, etc.
The first product KSTech ever made and sold was the Hood Vent / Scoop Delete for 04/05 WRX/STI. That was over 6 years ago, and we are still making them, and the price is still the same! We now also have versions for the 02/03, 06/07, and the 04-08 ForesterXT (same as the 02/03 WRX/STI), along with some other options:
http://www.kstech.biz/servlet/the-WR...ete/Categories
Replace the scoop on your 2002-2007 WRX or STI with an unique Hood Vent that sets your car apart from the masses and gives it a stealthy look. The frame is CNC machined from 6061 aluminum, and the mesh is a custom pattern in phosphated steel that is powder coated for maximum durability and corrosion resistance. The whole Vent weighs only 2.30 lbs. which is less than the factory scoop and splitter.
This item is available two ways:
  • Unfinished aluminum frame (ready for primer/paint) and powder coated semi-flat black mesh.
  • Frame and mesh both powder coated semi-flat black.
Recommended for cars with front-mount intercoolers only (of course).
Hood Vent is pre-assembled and ready to install, which takes less than a half hour. Comes complete with all the hardware needed (in stainless steel). No drilling is required at all, since the the factory scoop mounting points are used.
Prices:
  • Bare Aluminum Frame with Semi-Flat Black Mesh..................... $195 + shipping
  • Powder-Coated Frame and Mesh in Semi-Flat Black................. $205 + shipping
Current Availability as of 1/25:
02/03 WRX/STI & Forester XT .......... In Stock
04/05 WRX/STI ............................. In Stock
06/07 WRX/STI ............................ In Stock
__________________
[SIZE=3][B][SIZE=2]Matt Taylor - Sales / Engineering
__
__ (775) 250-7903 __ Facebook:
[SIZE=1]All KSTech-brand products are designed, manufactured, and tested in the Reno/Tahoe region of Nevada, USA
[/SIZE]
[SIZE=1]
[/SIZE] [/SIZE] [/B][/SIZE]
KSTech is offline   Reply With Quote
Old 12-13-2012, 05:33 PM   #2
KSTech
Member#: 143570
Default Hood Vent Options and Accessories
There are some optional add-ons to go with the Hood Vent Scoop Delete:
Louver Plate ............................... $150 + shipping
  • Used in conjunction with the Hood Vent, this louvered undertray attaches where the factory "splitter" used to go.
  • Blocks off the large Vent opening but still allows hot air to escape.
  • Hides expensive engine mods from prying eyes.
  • Also works with OEM or aftermarket scoops if so desired.
  • Uses factory mounting points and hardware - only one more hole to be drilled (optional).
  • Fits 2002 - 2007 WRX and STI. Forester XT fitment is not yet verified.
  • Current availability: 1-2 weeks out.
Air Diverter Plate ......................... $96 + shipping
  • For 2002 - 2007 WRX and STI with a hood scoop or Hood Vent along with a front-mount intercooler.
  • Attaches on the underside of the hood where the factory "splitter" used to go.
  • Directs the incoming air and rain to the turbo area for maximum cooling.
  • Some water is collected and drained away from the throttle and TGV electronics.
  • The rest of the engine compartment stays dry and clean.
  • Works with all OEM scoops and aftermarket scoops, or the KSTech Hood Vents.
Hood Vent Block-Off Plate ......................... $47 + shipping
  • Blocks off the Hood Vent scoop delete for people who do not want rain or snow pouring into the engine compartment.
  • Semi-flat black aluminum plate attaches under the Hood Vent mesh to retain the normal look.
  • Some customers install this during the cold or rainy season and take it off when it gets hot or at the track.
  • Installs in less than a half-hour.
  • Current availability: 2-3 days out.
__________________
__
[/SIZE]
[SIZE=1]
Old 12-13-2012, 05:34 PM   #3
KSTech
Member#: 143570
Default Hood Scoop Options
For those who want to keep the scoop look on their WRX/STI we have the following options:
http://www.kstech.biz/servlet/the-WR...ons/Categories
  • For 2002 - 2007 WRX and STI with a hood scoop along with a front-mount intercooler.
2008+ WRX/STI Hood Scoop Block-Off Plate............................................$ TBD
  • COMING SOON...
__________________
__
[/SIZE]
[SIZE=1]
Old 12-13-2012, 05:58 PM   #4
KSTech
Member#: 143570
Default Scoop Delete Plates
For those who want to block off the hood scoop hole totally, but keep the aluminum hood:
02-07 WRX/STI Scoop Delete Plate....................................... $85 + shipping
  • Replace the scoop on your WRX, STI, or FXT with an unique block-off plate that covers the hole where the scoop is removed and gives it a stealthy look while retaining the lightweight aluminum hood.
  • This Scoop Delete Plate has the same fit as our popular Hood Vent, but it blocks off the scoop hole completely.
  • This is obviously for cars with front-mount intercoolers only.
  • Available only in unfinished aluminum, ready for primer and paint.
  • ThreeWRX/STI/FXT shapes: 02/03/FXT, 04/05,and 06/07.
  • This is normally a special-order item. Lead time is only 2-3 days though.
__________________
__
[/SIZE]
[SIZE=1]
Old 12-14-2012, 09:51 AM   #5
KSTech
Member#: 143570
Updated some info...
__________________
__
[/SIZE]
[SIZE=1]
Old 01-08-2013, 05:25 PM   #6
taco15
Member Sales Rating: (5)
Member#: 297764
2006 WRX
website shows air diverter plate out of stock. accurate?
taco15 is offline   Reply With Quote
Old 01-26-2013, 11:33 AM   #7
KSTech
Member#: 143570
Diverter Plates are back in stock.
__________________
__
[/SIZE]
[SIZE=1]
Old 01-31-2013, 10:52 AM   #8
point78
Member Sales Rating: (1)
Member#: 344329
2008 Wrx, 6mt
any update on the '08 wrx block off plate?
point78 is offline   Reply With Quote
Old 02-27-2013, 02:17 PM   #9
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Originally Posted by KSTech View Post
Don't shoot me, but would it hurt the engine on an '02 to run this setup with a stock TMIC and stock engine? I assume performance may be hurt, I just don't want to hurt the motor.
I ask because I'm looking for a way to possibly "tone-down" the boy-racer look of my '02 wagon. Are there other options for a smaller scoop or vents that for a DD?
mmiller2002 is offline   Reply With Quote
Old 02-27-2013, 04:10 PM   #10
KSTech
Member#: 143570
Do not use this with a TMIC. It will greatly diminish the effectiveness of the IC leading to knock, which can destroy the engine.
I wouldn't go any smaller than the stock 02/03 scoop, so no options I know of. Sorry.
__________________
__
[/SIZE]
[SIZE=1]
Old 03-24-2013, 05:42 PM   #11
spinningcain
Member Sales Rating: (77)
Member#: 176490
2005 STI
I want a delete 05 sti your site says back ordered what up? Ready to buy now
spinningcain is offline   Reply With Quote
Old 03-25-2013, 10:44 AM   #12
KSTech
Member#: 143570
More of the 04/05 can ship tomorrow, Tuesday 3/26.
__________________
__
[/SIZE]
[SIZE=1]
Old 03-25-2013, 12:12 PM   #13
spinningcain
Member#: 176490
2005 STI
Let me know if I should order from your site or what?
Old 03-25-2013, 12:27 PM   #14
POP3Y3
Member Sales Rating: (64)
Member#: 149465
2003 2.5R(eal)S(low)
Yeah, I'm looking to purchase one (or 2) diverter plates for an 04-05 STi, too. Curious... Do you offer free or reduced shipping for a certain value/quantity of items ordered?
POP3Y3 is offline   Reply With Quote
Old 05-08-2013, 12:00 AM   #15
labbybreeze
Member#: 353422
2004 Impreza 2.5 RS
Same question. I'm looking to purchase an 04 Hood Vent Block Off Plate, but they looked sold out on the website. Are they in stock?
labbybreeze is offline   Reply With Quote
Old 05-10-2013, 05:37 PM   #16
KSTech
Member#: 143570
There will be more in stock on Monday, all years from 02-07.
__________________
__
[/SIZE]
[SIZE=1]
Old 06-02-2013, 04:16 PM   #17
Corentco
Member#: 293525
Any updates on the 08+ block-off plate?
"2008+ WRX/STI Hood Scoop Block-Off Plate............................................$ TBD"
I'm interested in one right away potentially.
Corentco is offline   Reply With Quote
Old 07-06-2014, 02:49 PM   #18
Ginola
Member#: 371516
2005 Impreza STI
I've just ordered one of your WRX/STI Hood Scoop Air Diverter Plates for my 05 STI,
Any chance you could let me know a rough lead time before they will be back in stock?
Cheers.
Ginola is offline   Reply With Quote
Old 07-07-2014, 02:05 PM   #19
knucklesplitter
Member Sales Rating: (3)
Member#: 64246
Cheers.
Next batch is back from powder coat tomorrow, so should ship Wednesday.
knucklesplitter is offline   Reply With Quote
Old 07-07-2014, 04:02 PM   #20
Ginola
Member#: 371516
2005 Impreza STI
Brilliant thanks for coming back to me
looking forward to fitting it
