Old 12-13-2012, 08:42 PM   #1
xredjar
Member#: 335597
2013 WRX 5 door Prem
Ice Silver
Default Question about Stage 1 93 Tune
How much of a safety margin is in this tune? I know it may seem like a dumb question, but after reading the notes on Cobb's web page, I'm trying to decide if going with the stage 1 91 tune would be better.
The notes say its good for most 92 and 93 octane gas. It's the "most" that is the basis of my question.
I want to get rid of the couple of hiccups when wot, but want good margins of safety. I am running 93 octane gas, but I'm generally very conservative when tuning.
xredjar is offline   Reply With Quote
Old 12-13-2012, 10:12 PM   #2
shamrocker
Member#: 258219
2011 WRX Limited
WR Blue Pearl
It's my understanding that the Cobb stage 1 is still conservative compared to a pro tune. The best thing to do is to try the 93 map, and do some data logging to check the quality of the fuel. If there's knocking with the gas you usually buy, then try the 91 map, which gives you a little bigger margin of safety, or find another "top-tier" station. If there's no knock, just keep data logging in the future to make sure you're still getting good quality fuel.
shamrocker is offline   Reply With Quote
Old 12-14-2012, 08:57 AM   #3
Cobb Tuning
Member#: 4803
If you want to stay on the conservative side, you can always run the most conservative map (91ACN) while still running 93 octane. This is perfectly fine, even in the long-term and will give you additional margin for knock resistance. Regardless of what map you go, data logging is always a good idea to monitor how your car responds to the map:
Bill
Old 12-14-2012, 08:12 PM   #4
xredjar
Member#: 335597
Ice Silver
Thanks guys!!
I had really good results tuning my S2000 with Hondata. This is my first turbo car, and I while I want to get rid of the hicups and smooth things out....this seems a lot different than the Honda.
I'll have to do some data logging and see what the results are. The S2000 had a fair bit of knock while untuned. My tuner and I were able to get rid of almost all of it when we were finished.
Thanks again
Old 12-18-2012, 04:20 PM   #5
cmiovino
Member#: 134005
2004 WRX Premium
For the record, I'm running the 91 oct tune with 93 oct fuel. Works great, DAM stays at 16 now and very very limited knock. I highly suggest this if you are experiencing any.
Old 01-04-2013, 06:57 PM   #6
jamesashe
Member#: 338920
2005 WRX Wagon
I'm in the same boat as you, I like having a safety margin so I don't have to worry as much on road trips.
Since Cobb states the difference is 5hp, there was no reason to do anything other than flash the Stage 1 91 Octane map.
jamesashe is offline   Reply With Quote
Old 01-09-2013, 01:36 AM   #7
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
I did the same thing, stage 1 91 octane map and I always buy 93 octane gas.
aerosaaber is offline   Reply With Quote
Old 01-09-2013, 11:54 AM   #8
Tripintaz
Member#: 245218
2013 STI Limited
The Stage 1 93 octane tune from Cobb is already pretty conservative. Don't be a sissy.
Tripintaz is offline   Reply With Quote
