Old 09-14-2002, 11:07 AM   #1
nekard
Member#: 12927
2002 Impreza WRX
Default STi Brembo Brakes
I was wondering if anyone knew how much the calipers and pads are for these brakes? Any vendors out there know this question? And is it worth it to buy the Brembos or the wilwood/perrin kit? Anyone?
nekard is offline   Reply With Quote
Old 09-14-2002, 12:16 PM   #2
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
The fact you compare the Wilwood/Perrin kit to the STi Brembo's is hilarious.
The wilwood/perrin kit is a kit designed to fit the stock wheels with a stock size rotor. It's obviously a very low cost solution.
The STi Brembo's fit only 17" or larger wheels, and only ones with lots of spoke clearence. The rotor is almost two inches larger than the stock size rotor. These will likely set you back in the area of over $2400 just for the fronts. Don't even ask about the rears.
If you want comparisons, the true Wilwood 6-pot/4-pot kit can be compared to the full STi Brembo front and rear setup.(4-pot/2-pot).
Zahnster is offline   Reply With Quote
Old 09-14-2002, 03:20 PM   #3
nekard
Member#: 12927
2002 Impreza WRX
That is why I ask. I have to opertunity to buy the STi brembos front and rear for 2k but I need the rotors and wondered on cost of pads for either. Thanks again.
Old 09-14-2002, 05:37 PM   #4
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
My understanding is that you can't even use the rear Brembo's unless you pretty much have the entire rear diff ass'y, half shafts, knuckles, etc.
As Zahnster, said, the fronts are pretty much a wheel clearance issue, if you have the rotors & calipers, you should be able to at least use those.
CTKAG is offline   Reply With Quote
Old 09-14-2002, 09:46 PM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default well
As CKTAG said the rear installation is theoretically a nightmare.
Did you mean to say rotors and pads?
The DBA rotor numbers are 654 and 655 for the front and rear respectively. I am pretty sure DBA manufactures the rotors that are oem for the Brembos.
The rotors and pad sets can be found at: www.wrxrsparts.com/BRAKES
Get ready to break out some large green.
subysouth
subysouth is offline   Reply With Quote
Old 09-15-2002, 04:01 AM   #6
nekard
Member#: 12927
2002 Impreza WRX
Yup! Nevermind! I think I am going to go with the STi calipers front and rear because replacement rotors from subaru are 240 a PIECE and like 250 a SET for pads. Not gunna pay that! STi 22b calipers here I come! Or in this aspect which would be better? Perrin/wilwood or STi calipers?
Old 09-15-2002, 10:18 AM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default given those two choices
I would get the Subaru 4pots. In the same price range you might also want to consider the Baer front kit. Baer is working on a rear kit allegedly.
Read these threads Nekard:
http://forums.nasioc.com/forums/show...hreadid=236250
http://forums.nasioc.com/forums/show...hreadid=221178
subysouth
Old 09-15-2002, 10:23 AM   #8
nekard
Member#: 12927
2002 Impreza WRX
Thanks a bunch! I mostly want these for looks but also want to be able to stop when I want to, not when the car wants to. I have been looking at all of these kits for about a month now and think I will go with the good ole' subarus. I found a front and rear set for 1500 with SS lines so i think I might jump on that.
The STi Brembo Brake FAQ - including "will STi Brembos fit on [x]?" ButtDyno Brakes, Steering & Suspension 74 05-18-2012 03:12 PM
compare Stock STI Brembo Brake with Project mu Forged 4 piston, 4 pads Brake System manman99 Brakes, Steering & Suspension 10 06-19-2006 09:33 AM
WTB: STi Brembo Brakes & Stock WRX Brakes willfong Private 'Wanted' Classifieds 0 07-28-2005 10:37 PM
Brembo and STi/Brembo brakes and rim info Imprezer Brakes, Steering & Suspension 13 03-20-2003 07:14 PM
Message Board Statistics All times are GMT -4. The time now is 12:53 AM.
