Old 12-14-2012, 10:37 AM   #1
theprodigy
Member#: 333875
Default SAE or Metric socket for 2011 WRX wheels?
Sorry, spare my noob question. I searched and couldn't find anything.
I have a 2011 WRX. I need to buy a socket set for the wheel lug nuts. Do I buy the SAE or metric sockets?
theprodigy is offline   Reply With Quote
Old 12-14-2012, 10:55 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You don't need a set, you need ONE socket. You can buy either 19mm or 3/4", the correct size has been debated here since Jefferson was in office.
Old 12-14-2012, 11:14 AM   #3
mtarr07
Member#: 246990
2010 Wrx
Use all the sockets!
mtarr07 is offline   Reply With Quote
Old 12-14-2012, 11:23 AM   #4
theprodigy
Member#: 333875
Didn't word it quite right...should have said if I had to buy a set, would I be better off buying the sae or metric set. It's a better deal to buy them as a set than individually anyways. I'm looking beyond just the wheels, obviously. But it sounds like I can go with either. thanks.
Old 12-14-2012, 11:25 AM   #5
ogboot
Member#: 170906
psm
The rest of the car is going to be predominantly metric.
ogboot is offline   Reply With Quote
Old 12-14-2012, 11:25 AM   #6
mtarr07
Member#: 246990
2010 Wrx
No, dont go with either. Subaru's are built off of 10mm and 12 mm sockets. You can practically take the entire car apart with those 2 sockets.
Old 12-14-2012, 11:54 AM   #7
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
This. But I would extend the list to: 10, 12, 14, 17, 19. That will do about 99.9% of any work you will do on your car.
As for metric vs SAE, you can get virtually any size in either, but 10mm in fractions is going to be really tough to find. I think its like 13/32 iirc, good luck finding that in a kit.
happs subi is offline   Reply With Quote
Old 12-14-2012, 11:59 AM   #8
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
True story, but add in 14 and a few others. But I replaced an entire motor using basic hand tools and the 10, 12, 14 combo. Only needed a "special" socket for head bolts.
Old 12-14-2012, 12:01 PM   #9
theprodigy
Member#: 333875
Thanks, guys. I'll go pick up a metric set.
Old 12-14-2012, 12:09 PM   #10
mtarr07
Member#: 246990
2010 Wrx
I was going to add 14mm, but I've only had to use that on a few occasions (compared to how often im using a 10 and 12mm). Literally, for 99% of people that do your "basic" bolt ons, all you're ever going to use is a screwdriver, a 10mm and a 12mm. But now we are just getting picky, haha.
There ya go young patowan!
PS. Your SN is quite comical.
Old 12-14-2012, 12:32 PM   #11
leecea
Member#: 37359
2003 WRX
Common first mods include suspension and downpipe, neither of which can be done with just a 10 & 12. Add 14, 17, and 19 to your list.
leecea is offline   Reply With Quote
Old 12-14-2012, 12:33 PM   #12
J-hop
Member#: 318428
Probably because 3/4" = 19.05mm so the difference is extremely minimal. That being said as you know you should always go with the smallest socket that will fit over a nut and I believe with the rest of the car being metric the size is definitely intended to be 19mm.
Argument solved!!!
J-hop is offline   Reply With Quote
Old 12-14-2012, 12:38 PM   #13
mtarr07
Member#: 246990
2010 Wrx
Go hug a cactus. I'm wrong. My badddd. What the eff are you using a 19mm for? I think I used 17mm for some suspension stuff.
Old 12-14-2012, 12:40 PM   #14
J-hop
Member#: 318428
^generally have to take the wheels off to get at the suspension
Old 12-14-2012, 12:42 PM   #15
leecea
Member#: 37359
2003 WRX
If you can, get some 6-pt sockets, a variety of extensions, and a breaker bar.
Old 12-14-2012, 12:44 PM   #16
leecea
Member#: 37359
2003 WRX
19mm is strut to knuckle, at least on my car. Need it to remove struts for spring or strut changes, or even just to max out front negative camber with stock suspension.
Old 12-14-2012, 12:45 PM   #17
mtarr07
Member#: 246990
2010 Wrx
Ahhh dang. I wasn't thinking about that. I have a tire iron for that. So it doesn't count. Bahahahah
Old 12-14-2012, 12:57 PM   #18
J-hop
Member#: 318428
Haha just giving you a hard time
Old 12-14-2012, 01:54 PM   #19
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
You're car is Japanese. Go buy Metric.
Honestly, I think even American cars these days are being built with Metric bolt sizing.
Loyale93 is offline   Reply With Quote
Old 12-14-2012, 02:12 PM   #20
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
To take the car apart? Only one size needed:
Putting it back together, now that's a different story.
Crazy_pilot is offline   Reply With Quote
