Old 12-14-2012, 06:41 PM   #1
racerdane
Member#: 330644
2004 WRX
blue
Default help me please misfire that i can not figure out
ok so i've read just about every misfire thread and i still can't figure out my problem so here it go's: 2004 wrx completely bone stock throwing a p0301 code for a couple months I've tried swapping coils and plugs it didn't work...the car has a rough idle at times and stutters a little at take off also the whole car surges when accelerating quickly so i was thinking injector but then today it also threw a p0303 and that is about where i got confused so i tested for vacuum and intake leaks and it seems to be all good i don't know what to do so if you can help i definitely need it lol.
racerdane is offline   Reply With Quote
Old 12-14-2012, 07:42 PM   #2
quazimoto
Member#: 70395
quazimoto is offline   Reply With Quote
Old 12-16-2012, 12:02 AM   #3
TheRedStig
Member#: 339781
2002 WRX Sedan
Has that thread helped mate? My problem seems to have ended up being a bad coil pack CONNECTOR...mine was mostly broken and thusly loose. Also gap your plugs at .24. I did those two things and bam, no check engine in 1300 miles since.
TheRedStig is offline   Reply With Quote
Old 12-16-2012, 08:34 AM   #4
quazimoto
Member#: 70395
I don't recommend gapping plugs at .24. The factory range is .028-.032 and is completely fine.
