#1 |
Member#: 320301
NWIC
Vehicle:1995 Legacy GT-B |
Got this car from a friend whose wife rear ended someone at about 25, didnt break the grille or headlights, aside from a couple mounting tabe...but the frame damage on the lower radiator support and mostly driver's side, folded over where the towhook is..and the airbags went off....
The car drives fine as the damage didnt tweak much,(beside the obvois frame damage) but it did push the fans into the pulleys a bit, enough to crack the timing cover and pop the belt off the alt.... I got the plastic out of the cover and ended up just breaking it off to expose the hole here: The timing belt seems to have enough tension and i replaced the serp. Belt and removed the radiator and cooling stuff... turned the key and just got a click, not a dead battery click, we were under jumper cables at one point... itsounded like a relay but thats it, im not sure where to go from here.. ![]()
#2 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
Is there an immobilizer system on this vehicle? Is it an automatic or manual transmission? As a safety feature on some vehicles several systems are disabled after a collision. Might be another place to investigate
#3 |
Member#: 320301
NWIC
Its a manual, from what I've been searching that sounds likely, although im not sure how to disable it..I'm not sure if its the same as the factory alarm override button which I can't find either..
Car seems good when key is 'on'...all lights and everything is normal ...but when turned to start, only silence and dark |
#4 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper Wagon |
Does everything electrical die when it goes click (lights, etc. go off)??
If so, double check the main battery cables, neg to ground, positive to fuses & starter. Before starting, I would pull the timing cover and likely replace the timing belt (you say serpentine belt, was this the timing belt?) I believe most immobilizers kill the start circuit, so you wouldn't get the "click". |
#5 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
I'd start with the obvious stuff. Put a 22mm socket on the crank pulley to make sure the motor still turns. Then, as suggested earlier, pull the timing covers and check the timing belt and pulleys (this is a damage prone area in front hits). If that all checks out good, look at the starter itself. The hit might have knocked the small gauge solenoid wire off the back of the starter (unlikely, but ya never know).
I don't believe there's an impact triggered immobilizer on these cars. If there were, it would likely shut the fuel off at the pump only. Good luck, Jay |
#6 |
Member#: 320301
NWIC
a bit late, but since i dont like leaving threads open, i found the problem was that the main (+) wire was pulled away from the terminal of the battery, but the accessory one was there...
so simple! |
#7 | |
Member#: 30669
Thanks for closing this out, it can help someone else down the road. ![]() |
