Old 09-13-2002, 09:22 PM   #1
Icon25rs
Member#: 20728
2006 STI
Unhappy Noise at drivers side window
I think I have found a way to get rid of the noise that we often here when we roll down the drivers side window. Open the door and roll down the window a little bit and pull back on it. Not to much you don't want to break the window, just enough to realign it back. From now on before you roll up your window open the door first then roll it up and close it. I did that I and I havne't heard a sound from it since. It might work for you. I got my MY02 RS in January so my car is new, I don't know about other models. Just be careful not to totally offset you window and have it drop into the door.
Good Luck!
Icon25rs is offline   Reply With Quote
Old 09-18-2002, 03:16 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If it's the squeaking noise that mine starting making, a quick squirt of silicone spray lube (actually, I just used Armorall Protectant pump spray) in the slot of the rubber weatherstripping just above the triangle at the front of the door solved my problem (just clean off any that gets on the visible glass).
Old 09-18-2002, 05:03 PM   #3
zfoster13
Member#: 24732
2002 Impreza 2.5 RS
Platinum Silver Metallic
Default window squeak
Squirt it in with the window up or down? Mine's making that squeaking noise, too, it's annoying! Thanks
zfoster13 is offline   Reply With Quote
Old 09-18-2002, 11:05 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I agree with the Armorall solution, works great, no more squeak.
It's not necessary to spray it in there, if you look at the rubber piece in the front corner there's only the outer lip that actually contacts the window. Just put some Armorall on a small piece of rag or towel and apply it to the inner surface of that lip (with the window open of course). Wipe off any excess that gets on the outside, and voila! Quiet.
Old 09-20-2002, 02:28 PM   #5
ScoobieSnacks
Member#: 15218
2000 Impreza 2.5RS
Silverthorn
A lot of people have this problem especially when it is cold.
ScoobieSnacks is offline   Reply With Quote
Old 09-23-2002, 04:39 PM   #6
golfs2good
Member#: 23004
2004 WRX
One Problem that I had also was that there was a loud rattle and I took off the door pannel and found a loose bolt holding in the drive. all Fixed
golfs2good is offline   Reply With Quote
I looked out my drivers side window to see this staring at me swiftwrx06 Off-Topic 122 07-18-2008 11:51 AM
'04 Wind noise in driver side window! zacek Interior & Exterior Modification 26 05-01-2007 06:47 PM
Wierd Buzzing occuring at 40mph+ with drivers side window all the way down faylix Interior & Exterior Modification 3 05-30-2005 01:21 PM
Excessive driver side window wind noise ghostfoot7 Service & Maintenance 7 09-26-2004 05:33 PM
('93-'01) Wind noise, coming from drivers side window?? impresivesoob Impreza Forum 3 02-27-2004 06:28 PM
