Old 12-14-2012, 10:11 AM   #1
cmiovino
Member#: 134005
2004 WRX Premium
Default The new FB engine oil filter
We all know the black 'JDM' oil filters previously offered for the WRX/STi are superior to their blue Canadian couterparts now produced by Honeywell (same company as FRAM). The blue filters are made to Subaru's specifications though with the correct bypass pressure, but still have paper endcaps. The black ones are very hard to come by now.
With the introduction of the FB engine in the 2012 Impreza, Subaru specifics the new 15208AA160 filter, which is black and is "made in Japan". Most likely the internals are very similar to the original black oil filters and they do have the same thread. They will screw right on. They are longer however, but as far as I know, the EJ20 has enough room to accommodate this.
Link with pictures:
http://www.mann-engineering.com/prod...ilter-fb20fb25
Has anyone used these on our older engines? (EJ251 NA, EJ20 turbo, EJ25 turbo, etc as they all take the same one). PSI is 23.2
This might be what we are looking for. As far as I know, you could pick these up at your local dealer with no problem now.
Old 12-14-2012, 10:16 AM   #2
cmiovino
Member#: 134005
2004 WRX Premium
Just to be completely clear, these ARE NOT the exact same as the original, shorter, black filters. They appear to be identical, except for the length.
Old 12-14-2012, 10:18 AM   #3
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
uh you can get it for cheaper than $8
Old 12-14-2012, 10:20 AM   #4
cmiovino
Member#: 134005
2004 WRX Premium
Well yeah, I'd assume they would be about the same as the blue ones at the dealer ($5-6ish). $8 is overpriced, but the link is to show the actual filter.
My question is about would they fit WRX/STi engines and if they would meet the specifications.
Old 12-14-2012, 10:23 AM   #5
WRXLTD
Member#: 136314
2014 Grand Cherokee
Has anyone cut one of these new oil filters open to verify they're like the older "black" Subaru filters inside?
WRXLTD is offline   Reply With Quote
Old 12-14-2012, 10:28 AM   #6
cmiovino
Member#: 134005
2004 WRX Premium
Yes, that would be great. I'm only assuming at this point as they appear to be the same on the outside and are made in Japan. Some research will be needed to confirm this
Someone with a 2012+ and who has one of these filters lying around from an oil change... could you please cut one open?
Old 12-14-2012, 10:46 AM   #7
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Better stock up. Post #14847
http://forums.nasioc.com/forums/show...31206&page=594
Dealerships installing blue filters on fb now too
Old 12-14-2012, 10:47 AM   #8
cmiovino
Member#: 134005
2004 WRX Premium
If you look at the part numbers on the old and new filters, the only numbers that change are the last ones (100 = old, 160 = new).
For comparison, here is the original shorter, black, filter:
Old 12-14-2012, 11:01 AM   #9
cmiovino
Member#: 134005
2004 WRX Premium
Ah, I see.
It might not even be possible to get these at dealerships right now even. They are available online it appears, but production may stop.
Thanks for this.
Old 12-14-2012, 11:04 AM   #10
cmiovino
Member#: 134005
2004 WRX Premium
Size comparison betweek the 130 and 160:
Old 12-14-2012, 12:19 PM   #11
Rallbaru
Member#: 322127
2013 WRX Limted
Dealership gave me a 15208AA160 filter when I went in to buy one for my 2013 wrx. I was under the impression that the filter my car used was 15208AA12A. I'm going to return the filter they gave me next week for what I believe to be the correct one.
Rallbaru is offline   Reply With Quote
Old 12-14-2012, 02:00 PM   #12
cmiovino
Member#: 134005
2004 WRX Premium
Technically yes, the 15208AA12A is what they should have given you for a 2013 WRX.
Old 12-14-2012, 02:09 PM   #13
Chuckls
Member#: 280696
2005 WRX
Snagged a couple of these for the ol' TS wagon. It's a pain to do an oil change with my UEL covering 1/2 of the filter.
Chuckls is offline   Reply With Quote
Old 12-14-2012, 02:35 PM   #14
dsn112
Member#: 332561
2016 WRX LTD
A dealer i went to just gave me the black one when I said 2013 wrx. I asked and said I thought I need the blue one. He said you told me 2013 and we went back and forth a bit. He asked for my vin and came back with the blue filter. It be cool to see the new one opened up and side by side vs the blue.
dsn112 is offline   Reply With Quote
Old 12-14-2012, 02:45 PM   #15
cmiovino
Member#: 134005
2004 WRX Premium
I very well might just fork over $5.XX this weekend to cut a clean one up for us all to see
Old 12-14-2012, 06:40 PM   #16
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Tokyo Roki 15208AA160
Specs:
OD: 86.25mm
Length: 70.18mm
Thread: M20x1.5, Roll-formed
Spring type: Stamped leaf
Bypass Valve: 23 PSID, Metal valve integrated into the end cap on the dome end.
Anti Drain Back Valve: Yes, Nitrile
Media type: Paper
Media Surface area: 1,092cm2
Beta Ratio: Unknown
Flow Rate: Unknown
Gasket style: "P" ring
Oil inlet hole/s area: Six 6.25mm holes. 184.07mm2 total area.
End caps: Metal
Can side thickness: .44mm
Honeywell/Subaru 15208AA15A (Blue filter speced for the FB2.5 in the Outback)
Specs:
OD: 67.9mm
Length: 86.9mm
Bypass Valve: 23.2 PSID, Plastic, located in the stamped spring, positioned at the end cap on the dome end
Media type: Paper
Media Surface area: 837cm2
Beta Ratio: Unknown
Flow Rate: Unknown
Oil inlet hole/s area: Ten 5mm holes. 196.34mm2.
End caps: Engineered media
Can side thickness: .37mm
flstffxe is offline   Reply With Quote
Old 12-15-2012, 01:21 AM   #17
hi5.0
Member#: 340456
2013 Impreza
Aww crap. Better start searching for some of those Tokyo Roki oil filters, if still available. Not a fan of the "orange can of death" filters no matter what color they may be painted. Any one get their hands on a aftermarket filter for a look inside yet?
hi5.0 is offline   Reply With Quote
Old 12-15-2012, 09:25 AM   #18
JustyWRC
Member#: 153088
2005 Baja Turbo
06 Forester 04 Forester
I really don't see what the issue is. Do ya'll really think Subaru is going to have an oil filter that will be detrimental to its engine? Seriously?
I don't care if someone makes a filter with some metal parts instead of paper. It is not on the engine that long. I have yet to hear of ANY engine fail because it used a Subaru filter.
Old 12-15-2012, 11:05 AM   #19
cmiovino
Member#: 134005
2004 WRX Premium
For the record... I dissected a used blue one after 5k miles and 6 months soaked in oil.
http://www.rs25.com/forums/f117/t165...view-blue.html
"Conclusion: There are nothing wrong with these filters for daily driver, autocross, or spirited use. MAYBE if you are building a turbo track car you MAY want to use something different."
The main thing we're talking about is the blue ones are meant for daily driver use and are fine for that. Given you are going to the track, autocross, etc... you might want to get a better one if they are the same price. Even if you don't do those things, metal end caps are just a little bit better.
Old 12-15-2012, 11:19 AM   #20
cmiovino
Member#: 134005
2004 WRX Premium
flstffxe, thanks for the pics... look great!
Old 12-15-2012, 12:43 PM   #21
hi5.0
Member#: 340456
2013 Impreza
My aversion to FRAM filters is not just about the endcaps, but also has to do with the blue filter having less filtering media surface area vs. the OEM Tokyo Roki filter. That's just my opinion on this topic no doubt influenced after seeing this: http://www.knizefamily.net/minimopar...reference.html
Would rather have the OEM or similarly constructed filter based on what was presented in that link. But that's like the reasons for people preferring a particular brand of motor oil over another so YMMV.
Old 12-15-2012, 12:52 PM   #22
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Here is a thread with a bunch more filters speced for the EJ. I am sure some 3rd party filters are also spec them for the FB.
This is far from a whats better or best test......but more of a comparison of construction, advertised specs and specs that were obtained from the manufactures all put into one place.
http://www.subaruforester.org/vbulle...parison-99130/
Old 12-15-2012, 01:49 PM   #23
bjkeed21
Member#: 247029
2010 WRX Hatch (02C)
Proletariat
i've used the 160 filters for two oci's in a row, and got a blackstone report on the second. they said i got good filtration. sadly, i have the new blue version of the filter on for the current oci since my local dealership said the black ones are getting axe'd (at least in central nj).
here's an lgt thread that relates the 160 to the previous rx8 filters that were used.
http://legacygt.com/forums/showthrea...-147113p6.html
edit: fyi, i threw away my most recent black filter, so i can't cut it open; better get those 160's before they disappear from dealerships
bjkeed21 is offline   Reply With Quote
Old 12-20-2012, 09:56 AM   #24
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
The 160's are 18.25mm larger in diameter than the 100's. Getting 9.125mm closer to my header I'm not so comfy with (it's already only about 25mm away if memory serves me right). Stock manifolds may be ok though?
Good thing I stocked up on 100's back in the day. Still have 2-1/2 cases left =]
NitroTrike is offline   Reply With Quote
Old 12-21-2012, 10:39 PM   #25
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
People who REALLY care about oil filtration will get an oil bypass set-up which runs ~$300.
People who really don't give a **** will put on whatever oil filter is on sale, hopefully for $1.XX or thereabouts.
People who use a scanning, tunneling electron microscope to justify their spending $8 on the "most" correct and "best" filter that is one step up from a $2 filter and one hundred steps down from a oil bypass set-up have differing priorities.
<-------------Has 2X HP on OEM 170,000 mile motor and uses $1.XX oil filters
