Alaskan Impreza Club
Old 12-18-2012, 06:25 PM   #1
rudd
Member#: 164612
2003 wrx
purple
Default 2010 sti and a 03 wrx swap
What would it take to use the motor and trans? Anyone know? I know that a lot of the parts are the same as any sti but has anyone done a swap like this or know of any problems that have been ran into
rudd is offline   Reply With Quote
Old 12-18-2012, 06:44 PM   #2
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
it can be done, use your intake manifold and wireharness ecu ect, plug all the cams use your cam gears, and the drivetrain will be a direct swap, dccd will not work with out a controller and drivetrain will be rwd biased.
Alaskan EJ20 is offline   Reply With Quote
Old 12-18-2012, 06:57 PM   #3
rudd
Member#: 164612
2003 wrx
purple
That's what I figured but the good thing is the tans comes with the controller so that's a poise and if I have to swap the harness for the eng and bulk head that's fine mine needs to be swapped anyways
Old 12-18-2012, 06:59 PM   #4
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
I've always been curious about a swap with an 05-09 Legacy-based 08+ STI swap into a GD chassis. I always assumed the length of the transmission from the Legacy would be too long and different to properly fit up.
Old 12-18-2012, 07:12 PM   #5
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
way too much work, id just get a spider dccd controller and use the stock harness, and get aftermarket avcs controller if you want avcs.
Old 12-18-2012, 07:14 PM   #6
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
good point you may need a 04-07sti driveshaft
Old 12-18-2012, 07:56 PM   #7
rudd
Member#: 164612
2003 wrx
purple
Ok we'll I'm just wondering because a guy I know built this kids car and rolled it a few weeks ago and is selling it so I'm just wondering what it would take to use the trans and poss. Motor also
Old 12-19-2012, 12:12 AM   #8
snowdrift86
Member#: 273920
05 Legacy GT
Regal Blue Pearl
That year trans will be slightly rear biased. It has a helical center diff with the clutch packs so it can never FULLY open up unlike the 04-05 6spds. Definitely easier to get a dccdpro or spiider controller as I hear you need like all the sensors and corresponding wiring to get the factory setup to work. Dual AVCS also won't work without using the oem wiring and ecu. Someone already said plug em and use your cam gears so unless you are good at wiring or get a standalone that's the easiest way to swap it in
snowdrift86 is offline   Reply With Quote
Old 12-19-2012, 12:15 AM   #9
snowdrift86
Member#: 273920
05 Legacy GT
Regal Blue Pearl
OH and as far as the shafts go the transmissions are all the same length so just stick with the driveline parts that fit your body style when it comes to drive shaft and cv shafts. 08+ cars are longer so the drive shaft wont work and i do believe the track is wide enough to where the cv shafts will not work. The front for sure is wider.
Old 12-19-2012, 01:21 AM   #10
AKGC8
Member#: 1305
2000 Impreza
You'd need an 04-07 STI driveshaft or an 02-07 Impreza auto trans driveshaft. The front axle stubs need to be swapped so you can use your WRX axles.
Another big issue is the 08+ transmissions do not have vehicle speed sensors. The only fix I know of is from DCCDpro which will convert your ABS signal into a speed signal.
With the CANBUS system, it would be a big PITA to run the engine as is, with the 2010 ECU. Much easier to swap some engine components and run it off an earlier ECU like Alaskan EJ20 was saying.
AKGC8 is offline   Reply With Quote
Old 12-19-2012, 02:22 AM   #11
rudd
Member#: 164612
2003 wrx
purple
Well nvm than I might just buy it and strip it and sell the parts so I can get my v7 set up than
Old 12-19-2012, 12:53 PM   #12
zachary.berrier
Member#: 82476
GOD CREATED TURBO
LAG TO GIVE V8'S A CHANCE
The dccd pro or Jeff's spider controllers don't convert abs speed sensors that's only the vss pro to calibrate the speedometer,it has its own 2 axis g sensor to control his auto program. The controllers work good, I've used one since 2008 and Jeff has great customer service also.
zachary.berrier is offline   Reply With Quote
Old 12-19-2012, 02:19 PM   #13
AKGC8
Member#: 1305
2000 Impreza
I was talking about DCCD pro the company, not the part. The fix, VSS pro, is available from DCCDpro.com.
Old 12-19-2012, 02:30 PM   #14
zachary.berrier
Member#: 82476
GOD CREATED TURBO
I know what u meant, I was just writing the specifics and that the actual controller doesn't use a speed sensor at all
Old 12-20-2012, 01:43 AM   #15
wuuusaa
Member#: 92894
2015 Wrx
Damn Zach don't be so serious... lol! How you been short man?
Old 12-20-2012, 03:01 AM   #16
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Damn Alex.
All balls and zero brain man.
Nomadgene is offline   Reply With Quote
Old 12-20-2012, 03:32 AM   #17
wuuusaa
Member#: 92894
2015 Wrx
Originally Posted by Nomadgene View Post
Damn Alex.
Why you say that? Because Zach is supposed to scary? Ugh I think not, he is just mad of size
It's all love I just haven't bothered Zach in a long time
Old 12-21-2012, 02:39 AM   #18
zachary.berrier
Member#: 82476
GOD CREATED TURBO
Alex are u still worried im gonna crack a rib with a finger, u know I'm not serious. I'I heard you were trying to sell motorcycles.
