![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 16345
Vehicle:2003 WRX- Sold E60 BMW 545i |
hey guys! Up until the other day i was planning on buying a set of ground control coilovers for my wrx, but I have started to rethink that. I could get a really good deal on some brand new eibach pro kit springs, so I have decided to rethink my plan.
I wanted the GC coilovers in the first place because I wanted to be able to raise it back to stock ride height and put the stock wheels back on for winter, but now I am wondering if i even need that. First off, my car is all wheel drive, and if i had on my stock rims, I would still be able to drive around in adverse conditions. What is your experience on the subject? Anybody drive their lowered wrx all year round in the snowbelt? Is it possible? Also, do you reccomend the eibach pro kit? how much does it lower the car? Will i rub w/ 18" Prodrive P1's w/ 215/35/ZR18 tires? I have to drive my car every day to school, so please give me some good advice here!
#2 |
Member#: 7958
Vehicle:09 GH B+ |
I believe the Eibach's (after settling) lower ~ 1.5 - 1.75"s, that might be a little low for adverse conditions (deeper snow). The STi sport springs lower in the 1" range, might be a better choice (cost more though).
Before deciding on coilovers insure they are meant to be operated at stock height, the DMS golds are reccomended not to run higher than 20mm below stock (that's where I'm running them). Lot's of factors go into deciding whether to go w/ coilovers vs strut/spring setups- what kind of driving are you going to do-influences spring rates, damping, height?, how important is adjustability-damping/height?, how important is cost?, how important is installing it and not having to mess w/ it anymore (stut/springs), how important is it to have something rebuildable (coilovers, some stuts)? Not an easy decision. Big Sky |
#3 |
Member#: 16345
hmm...well I am looknig for cvomfort. tHe main reason i am looknig for springs/coilovers is that my car would look rediculous on 18's withouyt a drop.
Also, are the whiteline springs any good? |
#4 |
Member#: 17397
BAIC
Vehicle:many '02 Rex,'13 FRS WRB, White |
I've tried EIBACH prokit springs.
its lowered about 1 and quarter... ride was almost like stock. but you can definately feel the diff on the turns. then i switched to the TANABE Racing sustec pro.... STIFF! definately NOT a daily driver anymore. if you are using your car as a daily driver i wouldn't suggest putting on coil overs (at least not agressive ones). In my wagon i have the DMS coil overs its on its middle setting and its still capable of a 'comforable ride'. sd |
#5 |
Member#: 10627
Vehicle:2002 WRX Sedan Platinum Silver Metallic |
That is correct, I also have the DMS Golds and they are not really designed to put the car in the weeds or raise it up to rally height. They actually have a relatively narrow operating height range.
#6 |
Member#: 15618
International
I rum DMS 50s (road) on my daily driver and on LA's freeways in traffic - about 20mph - it's absolute hell. Above about 35 the ride smooths out nicely.
#7 |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
I think Lawn Boy is talking about the Ground Control coilover "springs" not the full system... Or am I wrong?
#8 |
Member#: 17684
Vehicle:1989 pathfinder rusted red |
i had the same question a while back ago, but then i thought about what my plans were. I told myself that this is my only car, and that ride comfort can't be sacrificed. So, i thought about my options. Hmmm. coilovers, or just springs to work with stock shocks, or springs/stuts combo. After a while of debting, i figured out that even if i did get coilovefs, i wouldn't know how to properly "dial them in". As in dampening force, and all those other adjustible setttings that can be altered. I don't know that much about suspension, and i know i wont be able to fine tune it, so, coilovers are not really needed.
Then i thought about springs. Hmmm...There are many types of springs available. Since most aftermarket springs (over time) do cause more harm then good to stock shocks, i decided to pass (even though i know prodrive and those sti springs would have worked great) My final answer? The STI dealer option, non adjustables. Pretty expensive, but from what i have read, ride quality is awesome, and not harsh, they retain a similar "look" by only lowering the car a bit, and they are also said to be able to tackle the corners very well. There are many options. You say your car is a daily driver, does that mean you want it super low? There are a lot of questions that need answers. Asses your position, and rank what is most important to you. FWIW-i think prodrive springs would be best in your case (but like i said, ask yourself more questions about what you intend to do with your car) |
#9 | |
Member#: 16345
#10 | |
Member#: 2272
BAIC
I dont know if I would get them for the stock struts though, might have a severe over-dampening problem due to the stock struts not being stiff enough to counteract the stiffness of those coilover springs. |
#11 |
Member#: 22478
Vehicle:2002 WRX Sedan Platinum Silver |
why would you want to run 215/35-18 tires? Too keep the stock rolling diameter your going to want 225/40-18.
#12 |
Member#: 10151
Vehicle:2002 WRX Sedan Blue |
After researching for months. I have decided to do the following. Which will cost much less.
Summer Use Prodrive Springs on stock struts with my 18" P1s. Looks Great with 1.25" drop and feels good for highway and city(chicago) driving. Maybe next summer going to add STI top hats. Winter With cost in mind and no coilover. I will be going back to stock height. I have decided to switch back to stock springs (3hrs twice a year since summers are short here) and stock wheels. Also thinking of purchasing someones used WRX suspension (struts, spring and tophats) this will make the swap much easier. And for alignment, I will purchase a lifetime deal with Firestone. This solution for me sounds the best. I don't auto cross and more into looks than performance. Plus I just saved myself over $1000 in suspension that I will never utilize to its full potential. |
| Thread Tools | |
| Display Modes | |
| Time to poop. To flush or not to flush, that is the question | sonic_boost_wagon | Off-Topic | 31 | 09-25-2010 12:45 PM |
| Going to track, to lip or not to lip | jpmarotta | Motorsports | 3 | 09-19-2003 07:05 PM |
| Chance to buy mint ITR to buy or not to buy? | WRC WRX | Off-Topic | 16 | 09-23-2002 12:24 PM |
| MY00-01 2.5RS or MY02 2.5RS, to buy or not to buy, that is the question | Fujiwara | General Community | 7 | 04-24-2002 08:54 PM |
| ('93-'01) (My mistake) To drift or not to drit? | BHONE78 | Impreza Forum | 6 | 05-13-2001 01:08 PM |
