Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Old 12-19-2012, 10:05 PM   #1
Member#: 308617
1999 Impreza
Default 99 impreza won't turn over
So, I came home the other day and left my lights on, didnt come back to the car for about 14 hours, then i tried to start it up, nothing, power locks didn't work, no power at all. Tried to jump it but it didnt even make a sound. I take the battery into Autozone and get it tested. It was done for, I buy a new battery and install it and try to crank it, still nothing. There is no clicking, no noise. no lights, no radio and when I turn the key nothing at all happens, I checked the ignition fuse inside the cabin and it was good.
There are no mods whatsoever except for a pair of auxiliary lights (Which do work)
Any thoughts?
Daletehbest is offline   Reply With Quote
Old 12-19-2012, 10:58 PM   #2
Member#: 165749
Trace power with a meter from the Battery until you fine where it stops. Chk that the ground are all good
Old 12-20-2012, 03:32 AM   #3
Member#: 318428
Check main fuse in engine bay. Double check for correct orientation of battery cables
J-hop is offline   Reply With Quote
Old 12-23-2012, 09:33 AM   #4
Elbert Bass
Member#: 283429
This is a lame question - but....
Didja take the little plastic caps off the battery posts?
David Little
Elbert Bass is offline   Reply With Quote
