Old 09-14-2002, 12:23 PM   #1
subaruracerx
Member#: 8380
Default perrin wilwood vs. subaru 4-pot?
I haven't seen this comparison. Are they about the same?
I'm not racing the car so the fact that one is made of aluminum and the other out of cast iron or whatever isn't a concern to me. Just want to know a general daily driving comparison.
subaruracerx is offline   Reply With Quote
Old 09-14-2002, 12:29 PM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Talking Try these threads:
subysouth is offline   Reply With Quote
Old 09-14-2002, 07:52 PM   #3
Gargantua
Member#: 15090
2002 WRX sedan
Default Four pots
Those are some very informative threads.
I bought the Subaru four pots from Puyallup Subaru through their website for 600.00 which included the shipping costs and of course the pads as well. There have also been some group buys for them as well
Gargantua is offline   Reply With Quote
Old 09-16-2002, 12:49 AM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
My reasons for going with the Subaru 4 pots:
1) There's no way the Wilwood caliper is stiffer than the Subaru 4 pot caliper
2) Similar piston area to stock and similar brake torque to stock will probably lead to more consistent ABS activation (assumption, not based on fact)
3) I liked the street pads available for the Subaru 4 pots better than the street pads available for the Dynalite.
4) Wilwood makes a brake upgrade for Subarus already. They decided not to use the Dynalite in the front right? Hmm....
5) I already had rims to fit over the 4 pots (16x7 '00 RS wheels and 17x7.5 Sub Zeros)
If #5 isn't there, some people may have problems with a setup that won't fit under stock rims.
Concillian is offline   Reply With Quote
Old 09-16-2002, 01:35 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Based on what data? Billet aluminum Wilwood vs. cast iron STi, my bet's on the billet aluminum piece.
I haven't looked into this myself, but considering the wide-ranging usage of the Wilwood calipers I'm pretty sure you can find just about any pad you want for them. What were you looking for that you weren't able to find?
There's a big distinction between the kit that Wilwood markets and the one marketed by Perrin. Wilwood's kit is a whole hog, all out track setup - 6 piston front, 4 piston rear, with big rotors. The Perrin kit that uses the Dynalite is intended for street/light track use. I'm sure if Wilwood was looking to market a street-type setup, they would have used one of their smaller, lighter, less costly calipers.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 09-16-2002, 11:36 AM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Based on the material used (cast iron stiffer than aluminum), amount of it, and the design. The dynalite is somewhat known for being a little flexy on larger cars as well. Call up Precision Brakes Company and get their opinion of the Dynalite. They MAKE a bracket for the Dynalite for the Subaru (it's what Nino sells in his packages in the Vendor section) and they were trying to steer me away from it when they heard I would potentially be using it for track duty.
I have a hard time understanding why you think a race caliper with weight considerations made out of a material with a lower modulus of elasticity is going to be stiffer than an OEM application caliper made out of a material with a higher modulus of elasticity. It's no secret that the Subaru 4 pots weigh a ton. They are a beefy caliper. The Dynalite is designed to tradeoff some flex for weight savings. Wilwood has several other heavier 4 pot calipers in their product line, but none smaller. It wouldn't surprise me if most were more rigid than the Dynalite.
That is my line of thinking.
I was talking specifically axxis pads, which I like for the street. Definitely personal preference there, though influenced somewhat by the fact that I know DBA makes sure their rotors are very compatible with the popular Axxis compounds. (And I already had DBA rotors)
Perhaps true. Something to think about none the less.
Old 09-16-2002, 12:36 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
One other thing I took into consideration is the pad thickness.
The Dynalites are thinner than the 4 pot pads. The stock pads I used for a few thousand miles are still almost 0.1 inch thicker than Dynalite pads are when they're new.
New Dynalite pads are 0.49 thick (including backing plate, according to the Wilwood site) my OEM 4 pot stock pads with a few thousand miles on them are all over 0.56.
I guess that's the price to pay for a 4 pot that fits under the stock wheels. Not a huge deal, but something for consideration.
STI brembos VS Subaru 4 pots/2 pots Sypher Brakes, Steering & Suspension 6 05-17-2006 05:22 PM
STi Brembos vs. Subaru 4-pot projectrally Brakes, Steering & Suspension 35 04-27-2005 10:46 AM
Wilwood 4 pot vs Subaru 4 pot Jaz_rs Brakes, Steering & Suspension 25 05-13-2004 12:03 PM
Legacy H6 rear upgrade vs. Subaru 4 pots no_rex_yet Brakes, Steering & Suspension 21 01-16-2004 03:05 PM
Wilwood 4 pot vs Subaru 4 pot BIGSKYWRX Brakes, Steering & Suspension 124 12-09-2002 11:07 AM
