Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Closed Thread
Old 12-21-2012, 12:58 PM   #1
42Autosports
Vendor Sales Rating: (6)
Member#: 257297
2002 H6
Default Fuel Injector Flow Testing and Cleaning Services
Introducing 42 Autosports Fuel Injector Flow Test and Cleaning Services!
http://42autosports.3dcartstores.com...vice_p_61.html
42 Autosports offers fuel injector flowing and cleaning services using our ASNU injector diagnostic testing and servicing system. As part of the cleaning service, as necessary, we will replace the pintle caps, o-rings, and injector filters, ultrasonic clean and bead blast your injectors.
About Our Services:
Flow - We will Flow Test your injectors at settings that will simulate loads seen in your particular vehicle by adjusting the fuel rail pressure and injector pulse width to match your vehicle. Injectors will be leak tested at 3 bar and 6 bar and flowed ten times from 10% to 100% duty cycles in 10% increments. You'll be provided with a digital and paper copy of the results.
Flow and Clean - Injectors will be flowed as above to establish a baseline, and then cleaned thoroughly using multiple ultrasonic baths. We will then replace the pintle caps, o-rings, and injector filters. Metal body injectors will be bead blasted to remove rust. The injectors are then re-flowed. You'll be provided with a digital and paper copy of the results before and after cleaning.
Services
4 Cylinder Flow - $37.99
4 Cylinder Flow and Clean - $79.96
6 Cylinder Flow - $56.99
6 Cylinder Flow and Clean - $119.94
8 Cylinder Flow - $75.99
8 Cylinder Flow and Clean - $159.92
__________________
[/URL]
42Autosports is offline
Old 01-01-2013, 02:33 PM   #2
42Autosports
Member#: 257297
2002 H6
All work, no play on New Years.
__________________
[/URL]
Old 01-07-2013, 10:22 AM   #3
42Autosports
Member#: 257297
2002 H6
__________________
[/URL]
Old 02-05-2013, 10:38 AM   #4
42Autosports
Member#: 257297
2002 H6
__________________
[/URL]
Old 02-07-2013, 04:55 PM   #5
42Autosports
Member#: 257297
2002 H6
__________________
[/URL]
Old 02-10-2013, 08:26 PM   #6
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-13-2013, 12:21 PM   #7
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-16-2013, 01:20 PM   #8
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-19-2013, 10:16 AM   #9
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-21-2013, 05:05 PM   #10
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-25-2013, 03:12 PM   #11
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 03-02-2013, 07:47 PM   #12
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 03-13-2013, 01:17 PM   #13
42Autosports
Member#: 257297
2002 H6
__________________
[/URL]
Old 03-18-2013, 04:47 PM   #14
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 03-22-2013, 02:07 PM   #15
42Autosports
Member#: 257297
2002 H6
Unfortunately this service will no longer be offered.
__________________
[/URL]
Closed Thread
