Old 09-14-2002, 04:51 PM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Default Radiator fans not coming on with link plus
Okay, my car likes to over heat it seems. I went for a short drive today and got the engine temp upto 110c. my fan on is set to 90c and I cant seem to get the fans to come on. They were running on the stock ecu. Engine temp is in red, so I know the software sees the warning. Any ideas?
-B
Midwayman is offline   Reply With Quote
Old 09-14-2002, 05:46 PM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Are you sure the wires are correct? Do you have B134 pin 3 hokked up to B12 on the Link?
Impreza Rider is offline   Reply With Quote
Old 09-14-2002, 06:04 PM   #3
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Ill have to go check, but I have the Plug and play harness from AMR.
Checked the harness. Looks like the white/red wire (fan) goes to b134 #3 (right next to injector 4)
Any other ideas?
Old 09-14-2002, 09:37 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Tested the white/red wire with a small test light and a 9v battery. the fan wire connection through the harness appears to be working.
-B
Old 09-14-2002, 11:00 PM   #5
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
-B
I'm not sure how your test light was hooked up. I presume you had one end on a 12V wire (from battery or ignition relay), and the other on the fan wire at the harness? The test light should be off when coolant temp is below the trip point, and on when coolant temp is above the trip point. The voltage at this wire will be high when off, and near 0V when on (it's "backwards").
If it passes this test then you have a wiring problem in the car harness. Maybe you disconnected the connectors at the fan(s)?
-WaC
Wayne
wac is offline   Reply With Quote
Old 09-14-2002, 11:08 PM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
My next suggestion, and then I would check/swap relays to make sure they're still working.
Old 09-15-2002, 01:28 AM   #7
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
No, no it was just running through the the plug and play harness. Ie the ~12" long bit. Just thinking there might have been a bad connection there or something. FWIW the fans still work when the factory ECU is hooked up.
-WaC
Wayne
Radiator Fans not coming on lmnop32bc Service & Maintenance 3 12-18-2009 03:35 PM
radiator fans not coming on craig41 Service & Maintenance 1 10-16-2006 10:37 PM
('93-'01) radiator fans won't come on ruff Idle comp1 Impreza Forum 0 08-12-2006 09:17 PM
Car overheating & radiator fans not turning on SlowPoke00 Service & Maintenance 10 02-08-2005 02:19 AM
Radiator fan not coming on. So it seems. ebeck Electrical & Lighting 15 12-21-2004 11:40 AM
