Old 09-14-2002, 05:56 PM   #1
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Thumbs up STi clutch hose
It's braided stainless steel, with a plastic sheathing, and those stylin' pink STi tips at either end.
Installation: piece of cake. Remove intercooler, and then remove existing hose. You will need a 10 and 14mm socket for the pair of bolts at the hose. Then install new hose, taking care to bleed the clutch system after doing so. The system takes brake fluid, so just use your favorite.
Performance: well, it's a clutch hose. It ain't going to change the world. Now having said that, it is easier to modulate and apply the clutch smoothly, which points to the efficacy of this as a feel mod. It's along the same level as stainless brake lines. It's subtle, but if you know your car, you know it's there. Less lurching and all that jazz. There is only slightly more effort required at the clutch pedal, but not by an appreciable amount.
Kevin
gtguy is offline   Reply With Quote
Old 09-17-2002, 01:40 PM   #2
pwrup25RS
Member Sales Rating: (2)
Member#: 1011
2004 Impreza WRX
Rally Blue
sounds great. now where'd ya get it?
pwrup25RS is offline   Reply With Quote
Old 09-17-2002, 01:43 PM   #3
gtguy
Member#: 2184
Irvine Subaru, but other vendors have it, as well.
Also interesting, is that the stock clutch hose is nicely done. Rather than the stock brake lines, which are rubber hose, the stock clutch hose is that same rubber hose as the brake lines, but it's wrapped in hard plastic, presumably as a rudimentary effort to control the flexing and bulging of the simple rubber hose.
The thought that goes into these cars continues to impress me.
Kevin
Old 05-13-2003, 11:01 AM   #4
MK19
Member#: 21977
Bear s like food
And your write ups continue to impress me as well!!! Thanks Kevin!!
MK19 is offline   Reply With Quote
FS : OEM STI Clutch and flywheel jsharp2280 Drivetrain 15 09-20-2010 08:02 PM
FS: CA - Lake Forest ---New/Never Used STI Stainless Mesh Clutch Hose for '02-'05 WRX igalwrx Drivetrain 2 10-10-2007 07:27 PM
FS: CA - Lake Forest ---New/Never Used STI Stainless Mesh Clutch Hose for '02-'05 WRX igalwrx SCIC Private Classifieds 1 10-09-2007 12:24 PM
STi Group-N timing belt, JDM auto IC switch, STi stainless clutch hose **PICS** phlegmon Engine/Power/Exhaust 0 11-11-2006 06:08 PM
sti stainless steel clutch hose rperillo_2.5i Normally Aspirated Powertrain 3 07-26-2006 01:49 AM
