Old 12-23-2012, 11:35 AM   #1
doema
Member#: 340222
2013 Impreza HB
Default Making a Bluetooth hands free call while driving
I have just purchased a 2013 impreza sport premium within the last week so everything with the car is still very new to me.
My question is once my phone (iphone 4) is paired to the blutooth system and speed dial numbers are set, is it possible to make a call with the system while driving?
I get a message saying something to the effect of "due to safety concerns, this feature is not available while driving". Is this correct? Is anyone out there able to make a bluetooth call while driving?
Once the speed dial is set it takes about the same effort to make a call as
it does to change a radio station or turn on the a/c. (Which the car allows you to do while driving)
Thanks in advance for your help!
doema is offline   Reply With Quote
Old 12-23-2012, 11:23 PM   #2
ICE_NY
Member#: 324263
2013 Impreza Sport
Which head unit do you have? I have the navigation and once you hit the phone button on the steering wheel (bottom left on the picture) I have access to a key pad on the nav which is gray-out (assuming the car is moving) but I still can access my "favorites" at the bottom menu. From there I can choose any of my favorites saved numbers.
Also, until last week I had a razr2 phone and I used to flip the phone and press and hold a key and be able to start a phone call regardless of if I was using the head unit (Radio, GPS, etc.) at the moment. I know with the iPhone this is much more complicated because of the touch screen interface, but maybe you can use Siri to assist you.
One more thing, I know for a fact you can use the "virtual assistant" in the car (the button with the speaking face on the steering wheel) to dial a number. I found this feature a hit or miss.
I hope this helps a little,
cheers.
ICE_NY is offline   Reply With Quote
Old 12-25-2012, 08:54 PM   #3
blzr25x
Member#: 337689
2013 Impreza Premium
DGM Sedan
I've experienced the same thing, I don't understand why it doesn't let you use the speed dials while driving. Even thought it is pretty much the same as using your radio presets, as you said. But you can dial by using voice commands.
blzr25x is offline   Reply With Quote
Old 12-25-2012, 10:20 PM   #4
mclrn227
Member#: 83441
2013 5DR WRX
This annoys me to no end. You can easily press radio presets, so wtf? Or, they could have made the preset button on the steering wheel scroll through them and she could say the names!
I think they want to discourage the driver from placing calls while driving.
mclrn227 is offline   Reply With Quote
Old 12-28-2012, 06:20 PM   #5
vette2000
Member#: 340625
Is this an Iphone behavior or is it related to the subaru bluetooth?
vette2000 is offline   Reply With Quote
Old 12-28-2012, 06:27 PM   #6
Mephiska
Member#: 17560
2013 STI 5-door
Satin White Pearl
The Nav has voice recognition for names in your contacts. I find it works best if you say the last name first, then first name. I have an iphone 5 paired via bluetooth on my 2013 nav.
voice recognition works while driving.
Mephiska is offline   Reply With Quote
Old 12-28-2012, 06:38 PM   #7
DANGELO
Member#: 329707
Unhappy Agreed! Annoying...
In my '13 Sport, I cannot use the car to make calls, nor can I adjust the stereo settings for balance, fade, and bass. I can receive calls fine, and I can use my iPhone 4S to make calls using Siri, which ain't all that bad.
The limits on the stereo settings irk me most...Can't lower the bass while driving. With my iPod shuffling thru literally thousands of different types of songs, I worry I will kill my speakers from bass settings from one genre to the next.
Alas, although I upgraded the speakers, the sound is lacking compared to the Alpine head-unit & Boston Acoustics Components in my '04 Corolla S that the Impreza replaced.
I see a new (Alpine or Pioneer) double-din touchscreen 'app-capable' head-unit down the road.
VR/SLD in CT
Happy New Year
DANGELO is offline   Reply With Quote
Old 12-29-2012, 01:33 AM   #8
Shohin
Member#: 170188
2016 STI Limited
Somewhat related, but where is the microphone located for the handsfree?
Whenever I make a call, people tell me it sounds like I'm driving with the all the windows down on the freeway.
2013 WRX w/o nav paired with iPhone 5
Shohin is offline   Reply With Quote
Old 12-31-2012, 02:41 AM   #9
rickrobin
Member#: 306993
2012 Impreza Ltd.
Ice Silver Metallic
These outrageous, unacceptable speed dial preset, tone control, and HD on/off lockouts are controlled via a wire that tells the head unit when the car is in motion. In the 2012 Impreza Limited, it's pin 19 in the wiring harness to the head unit. If you cut the wire, full control is restored. If you prefer not to cut the wire, search the audio forum for svxdc. He makes harnesses that can be inserted between the factory harness and the HU. Removing the bezel and head unit to do the mod is quite easy on the LTD, since the automatic climate control is electronic; on other models you have to disconnect the mechanical controls. There are threads, including mine, about all of this and other models, and svxdc can help as well.
Also, there are hidden menus where you can access the overall eq and loudness settings, which are largely responsible for making these stereos sound so bad. (Recommend turning both the eq and the loudness OFF.) Here's the insane procedure to access these on the Ltd:
Key in ACC position, radio off: Hold preset button #6 while spinning the right adjust knob 4 or 5 notches (works for me, but some people say more); release the button, then REPEAT the procedure. Now you're in the adjustable presets pages. Spinning the knob or hitting the "back" button will bring up loudness, EQ, and screen brightness settings, which can be toggled with the knob.
rickrobin is offline   Reply With Quote
Old 01-02-2013, 09:28 PM   #10
doema
Member#: 340222
2013 Impreza HB
Thanks for all the replies!
Old 01-29-2013, 01:30 AM   #11
Banner
Member#: 116138
2013 BRZ
The BRZ has the same thing, even the VOICE CONTROLS won't let you make a phone call while drive? What stupid F'king ******* thought this up? Should be fired and never allowed to work again. NOW I have to dig my phone out and focus on that tiny screen to make a call.
THAT is a lot more dangerous.
Banner is offline   Reply With Quote
Old 10-01-2014, 04:01 PM   #12
JunctionMalfunction
Member#: 380454
Default Voice dial tips?
I live in the Nanny State of Vermont. As of today, October 1, 2014, I cannot TOUCH my Android phone or iPod while driving. If a cop sees you with an electronic device in hand, you get a ticket and I believe points too! Thankfully, I can still use my portable GPS. The Phone (for Torque app car info) and the iPod (for my tunes) have to be installed in docks to be used, just like the GPS. Yeah, I have been dangerous driving with the iPod in hand, so I get the point.
Enough grousing! My question is how do I set up voice dialing? Should I use Google Now or another app on the phone to listen in, and dial? If so, will GN work in the background properly? I tried using voice recognition with the stock radio. So far, with no set up, the 2013 Impreza's voice recognition has not worked at all for anything other than command words. Anybody know what to do to train it to understand me? Receiving calls is no problem, once the phone was paired. It still surprises me when the phone rings through the turned off stereo and the phone is in my pocket! Yeah, I'm so old that I used dial phones but it's also true that I don't get lots of calls. I don't usually make them while driving either - Except when on a trip! Any help would be appreciated, the last thing I want to do is drive seriously distracted in unfamiliar territory. Most likely, I'll have to do this all over again when I upgrade the head unit to be like the 2015 Imprezas' with rear cam and all. Only difference is that I have my eye on an Android 4.2 unit. 8-))
JunctionMalfunction is offline   Reply With Quote
Old 10-01-2014, 04:24 PM   #13
JunctionMalfunction
Member#: 380454
Default OK,ok, I read the fine manual!
Figures, I hadda download and RTFM!
There are voice "tags" I can set for up to 50 phone book entries. I can even lock the phone book. I'll let you know how the tagging goes.
