Old 09-14-2002, 07:29 PM   #1
Danny
Member#: 18444
2002 wrxwagon
Default up pipe torque sequence?
quick, im installing my up pipe and i cant remember the torque sequence. does the down pipe also have a torque sequence? and is the torque 25-30 for both the up pipe and down pipe?
dan
Danny is offline   Reply With Quote
Old 09-14-2002, 08:16 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
It's 26-28 ft-lbs for all those bolts. The proper procedure is manifold loose to head, turbo very loose to up-pipe, up-pipe torqued to manifold, turbo torqued to up-pipe, crossoverpipe torqued to manifold, brackets torqued to up-pipe, downpipe torqued to turbo. Vishnu has a guide you can download for their recommended torque specs which I think are the way to go.
-Jon
www.nothingserious.net
Old 09-15-2002, 12:08 AM   #3
Danny
Member#: 18444
2002 wrxwagon
thanks jon, everything worked out great.
FS: Stock 04 WRX exhaust jouka NESIC Private Classifieds 24 06-22-2010 10:54 AM
What bolts/Nuts for Up pipe? subaru_steve Newbies & FAQs 0 06-01-2010 11:17 AM
up pipe torque/bolt pattern? 03boxer4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-06-2009 02:25 PM
turbo to up pipe torque spec> jimtweet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-24-2007 12:55 PM
Up pipe torque order? turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-25-2003 01:16 AM
