Old 09-14-2002, 07:51 PM   #1
fungracing
Member#: 15291
Default down pipe smog problem
I am in LA. I am about to get the HKS downpipe. Will this makes my car fail the smog check?
fungracing is offline   Reply With Quote
Old 09-14-2002, 08:27 PM   #2
Romanikque
Member#: 7675
Depends what else you do to the car.
-MAX
Romanikque is offline   Reply With Quote
Old 09-14-2002, 08:29 PM   #3
SonicYellowWRX
Guest
Member#: 23351
Pika Chu!
TEAM DARRIIFFFTAA
Default Re: down pipe smog problem
yes. in CA you need to pass VISUAL and EMISSIONS. If it doesnt look like all cats are in place as well as other smog equipment, you will fail.
SonicYellowWRX is offline   Reply With Quote
down pipe and mid pipes mikEimpreza07 MWSOC Private Classifieds 7 06-02-2010 09:38 PM
down pipe and mid pipes IL mikEimpreza07 Engine/Power/Exhaust 5 06-02-2010 09:34 PM
Down Pipe to Mid pipe Leak Problems DemiSlayer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-28-2007 09:50 PM
JC Sports down-pipe problem yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 13 01-21-2006 04:24 PM
open down pipe? any problems? import111 Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-04-2004 07:39 AM
