Old 12-26-2012, 04:47 PM   #1
jrog28
Member#: 316269
2012 wrx premium
wrb
Default Tpms?
Hello everyone. 2012 wrx here, stock tires and wheels. This morning it was in the low 20's and the tpms light came on. I checked the air pressure in all my tires but none are low. Has anyone else had this issue?
jrog28 is offline   Reply With Quote
Old 12-26-2012, 04:57 PM   #2
horrorbiz
Member#: 77290
15 VW GTI / FiST
Those sensors tend to be very sensitive. When the weather changes dramatically they will get set off. It should go away after a bit of driving if the pressure is correct.
horrorbiz is offline   Reply With Quote
Old 12-26-2012, 05:03 PM   #3
dsmtweaker
Member#: 265405
2013 Audi
Find a station that will fill nitrogen. Also, takes 5 miles of driving iirc for them to get a new reading if they change.
dsmtweaker is offline   Reply With Quote
Old 12-26-2012, 05:30 PM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i think the spare also has a tpms sensor. just a thought.
Old 12-26-2012, 05:43 PM   #5
jrog28
Member#: 316269
2012 wrx premium
wrb
I was wondering if it did. I just did a visual check of it and it didnt appear low but didnt use the guage.
Old 12-26-2012, 05:44 PM   #6
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
was just a thought about the spare. if not, 1 sensor might be faulty. take it to the dealer for warranty.
Old 12-26-2012, 05:45 PM   #7
El tor0
Member#: 291450
There is no sensor in the spare. If the pressure is correct a short drive should fix the issue. If it persists one of the sensors may have a bad battery or may just need to be manually reset. If you live near a Costco with a tire center they should be able to do this for free.
El tor0 is offline   Reply With Quote
Old 12-26-2012, 05:49 PM   #8
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
Old 12-26-2012, 06:13 PM   #9
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
The TPMS flips out every winter on my parents' 2009 Legacy. I tell them to not worry about it because well, all the tire pressures are within spec. I actually run winter tires without the TPMS linked up with the computer. Just make sure your tire pressures are good and keep driving
RM_2 is offline   Reply With Quote
Old 12-26-2012, 06:16 PM   #10
jrog28
Member#: 316269
2012 wrx premium
wrb
Thanks for everyone's input.
Old 12-26-2012, 07:29 PM   #11
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i havent had sensors in about 4 years. i just use my mac tire guage.
Old 12-27-2012, 05:27 PM   #12
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
tpms sensors always go nuttly when cold. In the manual it states this and tells you that its normal. Check your tires weekly. I use a bike pump to pump em up and have my tire gauge to set the exact psi that I like.
Old 12-27-2012, 05:30 PM   #13
mrkyle3
Member#: 272675
2004 Miata
To my knowledge there is indeed a TPMS sensor in the spare. This happened to me this year. All four of my tires were at spec'd psi but my TPMS light was still on. Checked spare and it was low (although it looked fine). I pumped it up and TPMS light went away.
mrkyle3 is offline   Reply With Quote
Old 12-27-2012, 05:40 PM   #14
jerrywayne
Member#: 295261
2008 WRX Stg II
Pearl White
Just had one of mine replaced a few weeks ago on my 08. The tpms light would flash a few times at start, and then stay on for good. Replaced under warranty, otherwise, $150. Ridiculous.
jerrywayne is offline   Reply With Quote
