Old 12-24-2012, 01:36 PM   #1
Uruchima
Member#: 322246
2013 WRX Sedan
Default Odd Turnover for 2009 2.5i
So I have an '09 Impreza 2.5i, COSMO CAI, OBX catback and an Open Source tune... That being said...
My car's battery died a while back and I went to Autozone, charged it, even though it wasn't a 100% perfect battery, worked like a wonder after that. Then a little bit ago it started lagging when it came to turnover, it would slooooww-ly crank, then crank then crank until it turned over... sometimes it wouldn't at all... so fine. I went and bought a new battery. The first few days it worked like wonders... now it lags to crank, as if the battery was almost dead. Some days it just starts just fine, other days it just goes to crank veeerrryyy slowly but never had a problem starting and getting my car to turnover, just had to give it a try or two. ( I have a brand new starter too btw)
Should I just go get the battery checked even though it's a brand new battery?
Thoughts?
PS: I would post video, when I went to record the video... it turned on without a hitch...as if it knew it was being recorded.... hmmm
Uruchima is offline   Reply With Quote
Old 12-24-2012, 02:47 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
The Battery is only one part of the charging/starting system. Why did the original Battery die? I would not only check the current Battery to make sure it's in good shape but also the alternator and connections for corrosion and security.
Old 12-24-2012, 05:30 PM   #3
Uruchima
Member#: 322246
2013 WRX Sedan
The Original Battery was apperantly 8years old But I will make sure I check tomorrow and see what's going on. I'll check the cables/wiring to make sure everything is ok and I'll get back to you guys.
PS: Merry Christmas eve
Old 12-24-2012, 05:47 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
it doesnt hurt to chk resistance from the neg cable (while unattached from the battery) to a few different grounds. the starter, intake manifold and unibody somewhere opposite the battery side should give you an idea
Old 12-25-2012, 06:01 AM   #5
Uruchima
Member#: 322246
2013 WRX Sedan
Merry Christmas Morning, I will definitely check once I land back in FL today.
Old 12-25-2012, 10:55 AM   #6
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Originally Posted by Uruchima View Post
So I have an '09 Impreza 2.5i, COSMO CAI, OBX catback and an Open Source tune... That being said...........
Some thing doesn't add up here
A 4 year old car with an 8 year old battery
flstffxe is offline   Reply With Quote
Old 12-26-2012, 11:55 AM   #7
Uruchima
Member#: 322246
2013 WRX Sedan
I know, doesn't make sense either... I didn't even know Panasonic made car batteries... anyways I ended up checking the cables... everything works fine. Im going to get the battery checked today
Old 12-26-2012, 12:30 PM   #8
Kevlar_07
Member#: 339474
2008 Impreza OBS
sounds like a charging problem, or your starter is drawing too much voltage when it cranks. I would recommend checking you alt output should be around 13.6-14.2 DC volts, also check it with no load and with a load, i have seen bad regulators that don't allow enough voltage through when loaded. Hope this helps
Kevlar_07 is offline   Reply With Quote
Old 12-26-2012, 01:28 PM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
My 1998 Legacy GT had a Panasonic battery.....lasted ~9 years.
My wifes 99 Impreza L had a Panasonic battery......lasted ~8 years.
Both were great batteries.
Why do you say you had an "8 year old battery"? Maybe whoever read the date code had their head up their butt??
Do you do short trips?
Do you have a massive sound system?
Old 01-17-2013, 10:56 PM   #10
Uruchima
Member#: 322246
2013 WRX Sedan
I figured it out. The starter had lost the bolt to which it connects the wiring from the battery. New bolt, fixed
