Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 02-17-2013, 05:52 PM   #1
unlimited6986
Member#: 149206
08 FSXT
Default po137
I through a po137 code which came up as rear 02 sensor. Its a 2008 forester xt currently pro tuned by EFI with a VF43, Catted dp, Exhaust, Bigger tmic, Walboro 255, Grimspeed EBCS, Intake. It through the code on my way to my parents house so i let it run as i went inside real quick. Come back out and the exhaust was smoking bad. Shut the car off and turned it on a couple mins later. Was still smoking but not crazy. I decided to just re-flash the current pro tune map and the light is gone and no smoke anymore. Does anyone know what would cause this?
unlimited6986 is offline   Reply With Quote
Old 02-17-2013, 07:06 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
nhat is offline   Reply With Quote
Old 02-17-2013, 07:15 PM   #3
unlimited6986
Member#: 149206
08 FSXT
Not threw if you read the whole topic. I know what po137 is like i stated. Trying to figure out why the car was smoking after the code came up.
Old 02-17-2013, 09:06 PM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
through [throo] Show IPA
preposition
1.
in at one end, side, or surface and out at the other: to pass through a tunnel; We drove through Denver without stopping. Sun came through the window.
2.
past; beyond: to go through a stop sign without stopping.
3.
from one to the other of; between or among the individual members or parts of: to swing through the trees; This book has passed through many hands.
4.
over the surface of, by way of, or within the limits or medium of: to travel through a country; to fly through the air.
5.
during the whole period of; throughout: They worked through the night.
And I suspect the smoke has something to do with the rear o2 sensor which is why your ECU threw the P0137 CEL. You should go check it out.
Old 02-17-2013, 10:01 PM   #5
unlimited6986
Member#: 149206
08 FSXT
nhat
ukno, like the bug?
Member#: 140163
03 STi
hellaflunctional
View nhat's FaceBook Profile View nhat's Google+ Profile
http://bit.ly/XkKRHD
And threw.
Before your gonna be a dick read how you typed it first. Just copying what you wrote.
Old 02-17-2013, 10:15 PM   #6
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Because you are running hideously rich because of the failure. Read o2 sensor section, the page in whole is a good read, for the layman.
http://www.allpar.com/i/meets/carlisle/sensors.html
Cathexis is offline   Reply With Quote
Old 02-17-2013, 11:16 PM   #7
unlimited6986
Member#: 149206
08 FSXT
Thx at least there's good members here instead of a person in charge not doing anything. I'll go replace my o2 sensor and see if that helps.
Old 02-17-2013, 11:53 PM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
I through a po137 code which came up as rear 02 sensor. It through the code on my way to my parents house so i let it run as i went inside real quick.
First of all, what advice is there to give when you already know what the cause is? Replace the rear o2 and go from there. Let's see...CEL comes on, code reads P0137 which means rear o2, all of a sudden smoke from the exhaust! I wonder if they're related...
And it's threw, as in throw? If I were to throw the ball to you, I would be giving it to you much like the ECU is giving you the P0137 code. Through, in no way, is related to throw or to give. So please get it through (not threw) your thick skull that you're (not your) wrong. I even gave you the definition of through
Also, I'm doing plenty. You're welcome for the english lesson.
Old 02-23-2013, 02:36 PM   #9
dollar5th
Member#: 324540
Any luck with this?
dollar5th is offline   Reply With Quote
Old 02-23-2013, 07:03 PM   #10
unlimited6986
Member#: 149206
08 FSXT
Just replaced the o2 sensor, so far so good
