Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 02-13-2013, 07:12 PM   #1
Nutrients
Member#: 346825
2009 WRX
Default Close meh
Derp derp derp
Nutrients is offline   Reply With Quote
Old 02-13-2013, 07:20 PM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Perhaps because it's no longer broken?
Spenk is offline   Reply With Quote
Old 02-13-2013, 07:23 PM   #3
Nutrients
Member#: 346825
2009 WRX
Very well could be I have no idea, but the engine broke from a ringland issue
Old 02-13-2013, 08:03 PM   #4
Uncle Scotty
OK Houston
we have an Uncle
this is hard to understand
Uncle Scotty is online now   Reply With Quote
Old 02-13-2013, 09:21 PM   #5
Nutrients
Member#: 346825
2009 WRX
The car does not sound the same as before. Less throaty, much quieter.
I was wondering why that might be
Does that clarify?
Old 02-14-2013, 05:40 AM   #6
Spenk
Member#: 7164
2000 Miata LS
No intake = quieter.
Old 02-14-2013, 10:51 AM   #7
Nutrients
Member#: 346825
2009 WRX
I mean...it doesn't have the "pshh" lol
Old 02-14-2013, 10:55 AM   #8
rwfloberg
Member#: 327538
2012 WRX (307/344)
They rebuilt your engine with an uncatted DP? fo' free?!
rwfloberg is offline   Reply With Quote
Old 02-14-2013, 12:07 PM   #9
roadboy
Member#: 329556
my rebuilt 7mgte motor was quiet and more stable when it was fully rebuilt.
roadboy is offline   Reply With Quote
Old 02-14-2013, 12:13 PM   #10
Nutrients
Member#: 346825
2009 WRX
I suppose that's probably it
Old 02-14-2013, 03:15 PM   #11
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Running catless without tune?
minifreak is offline   Reply With Quote
Old 02-14-2013, 06:24 PM   #12
Nutrients
Member#: 346825
2009 WRX
OVeah
Old 02-14-2013, 06:34 PM   #13
Spenk
Member#: 7164
2000 Miata LS
Originally Posted by Nutrients View Post
Yes I am aware of what you're saying i check with a tech to make sure I would be safe for just the break in and he is a tech I trust, I'm driving it carefully and slowly as I am doing a extended break in, 1500 miles.
A appreciate the concern however.
Would it be better in your opinion to tune a car that has not been properly broken in yet? That seems a hair more risky
It would be much less risky to get a proper tune for the car's mods and just drive it gently for ~200 miles.
A 1500-mile break-in for an engine with factory tolerances is insanity. You're creating an engine that will guzzle oil.
Old 02-14-2013, 06:53 PM   #14
Nutrients
Member#: 346825
2009 WRX
Can you elaborate, I was told 1500 by my friend who is a tech to be safe. And it just has the pipe on it now, the only tunes I would have available to me is a COBB Stage 2 OTS map
Old 02-14-2013, 07:36 PM   #15
TheStepfather
Member#: 319109
2006 Forester XT
By babying the engine too much during break in, especially with factory tolerances, you will not seat the rings as well, making it more damage-prone down the road, and the engine will consume much more oil than it might if you were to break it in more aggressively. Such is not to say that you should beat the ***** out of it from day one, but not to baby it for 1500 miles.
TheStepfather is offline   Reply With Quote
Old 02-14-2013, 08:33 PM   #16
Nutrients
Member#: 346825
2009 WRX
I see so you're recommending a taper
Old 02-14-2013, 08:34 PM   #17
Nutrients
Member#: 346825
2009 WRX
I'm at 350m
Old 02-14-2013, 09:37 PM   #18
some dude
Member#: 100300
06 WRX
CGM
350... Meters?
some dude is offline   Reply With Quote
Old 02-14-2013, 11:42 PM   #19
Nutrients
Member#: 346825
2009 WRX
Don't be a jackass, miles.
I know the abbreviation wasn't correct, my apologies.
Old 02-15-2013, 01:05 AM   #20
TheStepfather
Member#: 319109
2006 Forester XT
At this point the motor should be fine. definitely open it up, get it tuned and give it boost.
Old 02-15-2013, 01:23 PM   #21
Nutrients
Member#: 346825
2009 WRX
Hmm alright ill look into it
Old 02-15-2013, 03:24 PM   #22
Leafy
Member#: 330625
2006 WRX
It was not run at full throttle within the first 20 minutes of run time, it will never be a strong engine.
Old 02-15-2013, 05:19 PM   #23
Nutrients
Member#: 346825
2009 WRX
Couldn't tell you if it was cause the dealership drove it
Old 02-15-2013, 10:15 PM   #24
corvallisbattery
Member#: 333030
'05 WRX
I did a "hard" break in on my motor. Brand new start up and brought to operating temp at idle. Shut it down... changed oil.. sae 30. Drove wot for the first 4 gears then left it in gear and came to a stop ( high.. HIGH vaccum).. until engine stalls. This is the way I break in all my motorcross engines... I have 160psi compression across the board with O..ZERO oil consumption. 35k later... she is flawless. Just my way... but there is a lot of merit to a HARD break in...its all about seating those rings as soon as possible. Otherwise your cross hatch with wear your rings down and there is no way to come back from that.
Currently at 310whp and beat on it every day....
corvallisbattery is offline   Reply With Quote
Old 02-23-2013, 03:08 PM   #25
dollar5th
Member#: 324540
Bump!
dollar5th is offline   Reply With Quote
