#1 |
Member#: 340852
E. Canada
Vehicle:2013 Impreza "base" White |
Hi,
I can't lock or unlock the two doors on the driver's side using the the remote button on the key or the power lock/unlock button inside. I own a Impreza 4 doors, base model and it's only about 3 weeks old. Anyone has or had the same problem. Thank you and Happy New Year!
#2 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
Is it weather related? How cold is it where you live? Can you unlock the doors manually?
#3 |
Member#: 334126
Vehicle:2013 5mt Sp Premium Venetian Red & Dark Gray |
i have a dream that one day, we will have a completed profile and more information then again it was only just a dream
#4 |
Member#: 340852
E. Canada
Well, cold, yes.
About 14F (-10C). But, if it was cold related, all my doors would be affected? It started by the rear and then the driver. |
#5 |
Member#: 316315
Vehicle:2012 Imp HB/Prem/CVT DCP |
I would guess it's moisture related. Perhaps the drivers side was windward when freezing rain or ice was coming down, the wind worked it into the doors and froze the mechanical part that works the lock from the electrical relay. Can you find a heated place to park for a bit to see if unfreezing it would fix it?
#6 |
Member#: 322264
Does it unlock manually?
#7 |
Member#: 340852
E. Canada
Manually, yes.
#8 |
Member#: 315631
Vehicle:2012 Impreza |
check the fuses. when i was installing the rear hatch led light, i accidentally touched both wires and it blew a fuse. i forgot which one. but i couldn't lock or unlock my doors with my key fob but i could still lock and unlock the door if i had used my key manually.
#9 |
Member#: 322264
Bettrave said that his locks are working normally on the passenger's side; it's only the driver's side that's not working.
I'd say that you should probably have this checked out and fixed by the dealer, under warranty. Shouldn't be a big deal. |
#10 |
Member#: 338666
Vehicle:2013 Impreza Premium Dark Grey Metalic CVT |
Do you by chance have access to a heated garage for a couple of hours just to see if things begin working after that? That may help determine if it is moisture/temperature related.
John |
#11 |
Member#: 340852
E. Canada
If it's moisture/temperature related, it would mean that the Impreza isn't well made.
Last night, we had family for a party. I did a small survey. Everybody live in my region, so moisture/temperature should affect their car too. Relsults. Nissan Versa 2010, Mazda 3 2012, Mazda 3 2008, Toyota Matrix 2011. None had any problem! |
#12 | |
Member#: 338666
John |
#13 |
Member#: 340852
E. Canada
Went to the dealer today.
Something was "unhooked" inside the door. What? I don't know. They didn't give much detail and I didn't ask. I was just happy that it was working. |
