Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-15-2014, 01:52 PM   #251
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
OEM WRX springs and struts definitely shouldn't help much. You'd need to go aftermarket.
averagewhiteboy is offline   Reply With Quote
Old 01-15-2014, 09:11 PM   #252
ddscoober
Member#: 375709
2014 Impreza sport
You can try the WRX struts with RCE black springs. That may give you a more even ride. I'm thinking of doing that. maybe upgrading to Konis for adjustable dampening too. If you want lower in the front you can also get the RCE front lowering camper plates.
ddscoober is offline   Reply With Quote
Old 01-16-2014, 02:23 PM   #253
jspec rsx
Member#: 321746
Anyone tried the STI suspension yet?
jspec rsx is offline   Reply With Quote
Old 01-16-2014, 02:24 PM   #254
solistik
Member#: 345948
I don't think garamas posted his car in here after switching from BC Racing BR Series to BC Racing Extreme Low coilovers so, I'll post it up for him just as a reference for other users. Plus his car looks great!
Rolled Fenders
VSP Type 1 18x9 +25
Nankang NS20 225/40/18
solistik is offline   Reply With Quote
Old 01-16-2014, 02:24 PM   #255
solistik
Member#: 345948
STi is not compatible, only the WRX.
Old 01-16-2014, 02:27 PM   #256
jspec rsx
Member#: 321746
Thanks all I needed to know
Old 01-16-2014, 10:16 PM   #257
FB20SLW
Member#: 370576
2013 Impreza Sport
Ice Silver
If you have aftermarket rear LCA's you can use the STI equipment in the rear. The front cleave that attaches to the hub in the front is too large at the moment and doesn't fit properly. I am working with my buddy who is a fabricator on some sort of piece to put in to make it work. It's almost the definition of insanity. I had this crazy idea of going kyb wrx struts up front and STI struts in the rear, the issue that rests with this idea is that the wrx kyb strut cannot deal longterm with a higher spring rate spring, ie rce yellows and possibly blacks. RS-R's, swifts, epics, eibachs, et al. are ok I am guessing. I haven't read their spring rates. A good rule of thumb is nothing over 235lbs/in on the fronts. If it is metric you can use the equation, 2.2lbs=1KG, 1 inch=25.7mm so it would go like 2.2*(stated kg amount)*25.7=lbs/in. Disclaimer: Not a math professor. Anyway have fun.
FB20SLW is offline   Reply With Quote
Old 01-20-2014, 03:47 PM   #258
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
Originally Posted by FB20SLW
if you do the koni inserts use an 08-09 donor strut, its perch is lower on the housing. perhaps even purchasing a stock wrx strut for an 08-09 may do the trick there.
I should be able to take a measurement here in the next week or two on the front stock strut perch.
08-10 wrx and 08-11 imprezas front struts all share the same geometry. the higher perch is only on the 11-14 widebody wrx. also, i would not recommend the 08 wrx's stock struts for aftermarket springs. the 08's dampers and springs are crazy soft. 151#F springs and 136#R springs, with soft dampers to match. 09-14 wrx and 08-10 sti's have 217#F and 194#R springs, and stiffer dampers. 2011+ STi springs are 250#F and 297#R.
does the 2012+ Impreza share the same front strut geometry as the 11-14 widebody wrx? Did you get any measurements?
Has anyone installed WRX springs on their 2012+ Impreza? I have some spare 2012 WRX springs i am thinking of installing on my wife's 2012 Impreza Sport...
does anyone know the stock spring rates for the 2012+? does the baseline impreza and the Sport share the same springs?
1 inch = 25.4mm.
FWIW, i am using 2011 STi springs and Koni's on my 08 wrx. it went from 15" hub center to fender in the front and 14" in the rear, to about 14.5" front and rear.
i machined some spacers for my rear koni's to raise the rear spring perch 8mm, to accomodate the 30mm shorter rear 2011+ STi springs. the front springs installed without an issue and lowered my front about 1/2". With my spacer (i used 8mm, but would do 7mm or maybe less if i was to remake them) it raised my rear a bit more than 1/2", so i am now more evenly raked, but with my rear a tad higher. 2LiveCrew style.
isotopesope is offline   Reply With Quote
Old 01-20-2014, 11:56 PM   #259
FB20SLW
Member#: 370576
2013 Impreza Sport
Ice Silver
1 inch = 25.4mm.
I don't know why I had the 7 stuck in my head! I don't know the spring rates on the '12+ impreza sport but I had a diagram printed from subaru for an '08 wrx and most of the parts are the same. I am guessing that the '12+ impreza sport is a recycled '08 wrx suspension. If you look at some of the earlier posts in this thread their were some pioneers that actually installed wrx aftermarket struts and springs in their '12+ impreza.
I think the 2012 wrx springs you want to use will be good to go. My RS-R downs are about 206#f and 222#r. As far as I know the '08-'14 impreza sport, wrx, and some of the obs have pretty similar suspensions. The obs has a taller strut, so I have read. When I complete my rce blacks and koni insert install on my car I will take the measurements off the stock '12 set-up.
For anybody who is insterested, I am running godspeed rear lca's for an '08-"14 wrx, whiteline rear 20mm sway bar BSR49, kartboy rear wrx '08-'14 end links, Megan Racing rear toe arms for '08-'14 wrx, legacy, brz, and this car. Off all the things I have in this car, the sway bar was the best investment. I promise to take pictures of it all when I do the koni install.
Any pics of your spacer? I am interested in a little rake for the rce blacks.
Old 01-21-2014, 12:37 AM   #260
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
^^ Still waiting for a pic of your car on the RSR springs..
Old 01-21-2014, 11:03 AM   #261
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
hmmm, interesting. i would speculate it is more similar with the narrow body 08-10 wrx's than the 11-14 wide body's. does anyone have the perch height of the stock front struts determined? i'll have to dig through this thread more. thanks for the heads up. i've heard and read they fit; i am more curious as to what the stock spring rates are for a comparision if it's really worth the effort.
still not sure i will actually install the springs, but after installing a 19mm STi rear sway bar and a sport grille on my lady's 2012 sport, she sort of has the mod bug. "what else can we do to make my car better?" hahaha she loves my stage 2 wrx.
so, my spacer was born out of me being a cheap bastard and becoming determined to run the stiffer and not really lower 2011 STi springs. i would've loved a set of King standard springs, but they're over $400 and i got the STi springs for $120.
this is the thread i took over, trying to make this work:
http://forums.nasioc.com/forums/show....php?t=2453203
OP never responded or returned my PMs. it was a looooong road of trying to have a stiffer and not lowered "daily driver only" suspension, without spending a trilliondy papers and shinies.
honestly, if you want to change your rake a tad, i think you'd be better off with strut spacers. i am definitely no suspension guru, but my spacer would add more preload to your springs, which could be problematic.
my spacer is necessary to run the rear STi springs as they are 30mm shorter, and were slightly loose when the spring and shock and tophats are installed. i initially made the spacers 30mm thick, giving the spring the same .750"ish preload as the WRX springs, but then my car was a good 30mm too high in the back!!! so i cut it down to just give the springs a touch of preload, and take up the spring's slop so it couldn't be misaligned at full droop.
final spacer:
2011 STi vs 2012 WRX rear springs:
Old 01-24-2014, 12:52 AM   #262
FB20SLW
Member#: 370576
2013 Impreza Sport
Ice Silver
final spacer:
Awesome info. So when I was researching struts and sways, I stumbled on the chassis code for the 2012+ hb, it's GP and then I verified on my RS-R box as GP. As a result, I started using that code to find parts and in turn landed on whiteline's page and their sway bars. The GP and GJ(non-hatch), MY 11-12 wrx/sti are all grouped together. Raised my eyebrows a bit. Some of my other research called for the GP as similar, if not downright identical to, MY '11 hatches. I have no idea what makes a wide body wrx and the slim line, all I have seen is the parts are interchangeable. Except that '08 suspension components are soft and if you modify the '08/'09 front perch for koni inserts there will be a little drop if you are using a leveling set-up. I will have pics up before the weekend is over and I will load more once I have the koni/rce drop on. So everyone can see the rs-r and the koni/rce set-up. I'll include the other mods to the rear end.
Old 01-24-2014, 06:28 AM   #263
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Don't forget the pics! Still waiting to see those RSR's before I make the purchase..
Old 01-24-2014, 06:17 PM   #264
solistik
Member#: 345948
Is there a specific reason you're waiting for him to post his car with the RS-R springs? Other users have already posted their car with those springs installed in this very thread, such as MjSub2.0:
Old 01-24-2014, 11:35 PM   #265
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Didn't know his was on RSR's. Sorry. lol
Old 01-25-2014, 07:02 AM   #266
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
I have been on RSRs for 8 or so months and love them. Nice soft ride and subtle drop. I feel the rake has been taken out and it sits pretty level.
ronjr8102 is offline   Reply With Quote
Old 01-25-2014, 10:18 AM   #267
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Very nice. Thanks for the info!
Old 01-25-2014, 12:39 PM   #268
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
RonJr, are you on 17's or 18's in that pic too? Width? Tire size? That looks to be around the stance I'm going for..
Old 01-30-2014, 02:08 PM   #269
nemos_black_wrx
Member#: 372679
2012 impreza
has any one done 2013 wrx springs on there 2012+ 20I. I've got a 2013 20I hatch, and a guy is going to give me his 2013 wrx springs for free. did it drop the car by anything? .25 .5 .75? or just stiffen up the car and make the handling better?
nemos_black_wrx is offline   Reply With Quote
Old 01-30-2014, 03:36 PM   #270
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Probably not enough to be worth the hassle.
Old 01-30-2014, 04:59 PM   #271
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
Default 56K warning. pedantic blathering ahead!
I have been running stock struts with RS-R springs and they struts are done. Not necessarily from the springs but impreza struts suck.
how long did that take? did just the front struts blow, or did the rear shocks get worn out too? i would imagine the fronts were totally worked, since the front is dropped over an inch and too damn soft with those springs. i would blame the spring's design, not the stock strut per se. imprezas, wrx's included, are just nice grocery getters, not sports cars. the strut wasn't designed to be used with such a spring.
if that's true, then that front spring rate is softer that 2009-2014 WRX stock springs! no wonder your struts blew! even koni's would probably hate those springs too!
did you ever get a measurement of the stock front strut?
i really wonder how it compares to the 11-14 vs 08-10 WRX:
http://forums.nasioc.com/forums/show...7&postcount=56
i read this entire thread twice now and still never found anyone's measurements, nor anyone installing stock WRX springs.
i'm picking up a used set of 16" momo winter pro wheels and general altimax snow tires for my wife's impreza sport tomorrow... so when i swap them, i'll measure her strut. HUBBA HUBBA!
On a side note if anyone is looking into a new rear sway bar, you will need new endlinks. The stocks are trash.
i wouldn't call the stock endlinks trash, but they certainly cannot hold up to a big bar. if you're just running a 20mm or smaller rear, i would speculate the stock ones would be fine. 2010-2014 STi's have a 19mm rear sway bar stock, with the same endlinks.
AFAIK, the main suspension differences are mainly in the front. 11-14 WRX's use the wider STi front sway bar, plus have the taller spring perches on the front struts, and slightly different strut clevis dimensions. the spring rates are identical to 09/10, but the dampers are a bit stiffer.
Old 01-30-2014, 05:13 PM   #272
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
what is your budget and your overall goal and intended uses for your car? daily driver only? autox or rallyx too? do you want to improve the handling or just want the lowered look? the spring rates are pretty much the same as those RS-R thumbs down springs, but would put you near stockish height, i'm sure.
if you're getting them for free and are feeling feisty, it may be worth a try if you're doing the install. you'd be the pioneer everyone is waiting for!
Old 01-31-2014, 06:10 AM   #273
nemos_black_wrx
Member#: 372679
2012 impreza
it's a base model 20I hatch, it's my daily driver. my intended use will be daily driver, with a little bit of spirted driving and playing with it. this car had to much back end roll. so I did the 16mm wrx sway bar. now I get nose dive and front left/right /right/ left roll in the corner. seems the front is to soft. I want to stiffen up the front, and have it handle better.
you wouldn't happen to know the spring rate of the 2013 20I springs do you? and what are the spring rates of the 2011-2014 wrx?
Old 01-31-2014, 07:37 AM   #274
ronjr8102
Member#: 216040
dark metallic grey
I don't know what picture you are talking about?
I have the base 15s
Old 01-31-2014, 11:18 AM   #275
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
man alive, i wish i did know... that's why i have been perusing this thread!
from what i have read in this thread, some folks with the RS-R Downgrade springs have said it feels a bit stiffer than stock? the RS-Rs are apparently at 206# F and 222# rear. but the front springs are too soft for how low they get and will blow your struts. in my opinion, lowering an impreza more than 3/4"-7/8" is stupid. typically, if you're going to lower the car, the dampers really should be upgraded.
the 2009-2014 WRX all share the same spring rates: 217# F and 194# rear.
another thing to keep in mind is that the 2011-2014 wide body WRX is 300 lbs heavier than the 2012+ 2.0i, so percentange of stiffness increase may be more drastic than putting stock WRX springs on a 08-11 2.5i.
if you're getting the WRX springs for free, why the hell not put them on your car!? it's bound to be a spring rate improvement. i would doubt the stock WRX springs would be too stiff for the stock dampers either...
running too soft and too low of a spring with be murder on the dampers. also, running too stiff of a spring with too soft of a damper, will cause the ride to be too boucy, since the damper cannot control spring properly.
i would also consider an even bigger rear sway bar... 08-09 STi's came with an 18mm, and 2010-2014 STi's came with a 19mm. i just put the 19mm STi bar on my wife's 2012 sport, and it made a nice, but subtle difference. hers came stock with a 16mm. i personally am running an adjustable 22mm whiteline bar, with support braces, and rallitek endlinks on my 08 wrx. i eventually want to upgrade my front bar to a 22mm adjustable as well.
this is a GREAT article on descriptions of handling characteristics of various swaybar setups:
http://forums.nasioc.com/forums/show....php?t=2462278
