Old 06-14-2013, 09:49 AM   #1
JVAWN
Member#: 265436
2002 wrx
blue
Default how much boost should i run/power expectations?
Okay so i haven't been on this forum much over the years but my car has gone through several different stages. Basically what im looking for is a general idea of what power i'll be putting to the ground, as well as what kind of a quarter mile time i could expect to achieve. also looking for input to make the set up better and what to set the boost at
Car: 2002 wrx
motor:
Ej205 bored .20 over
ACL rod/main bearings
eagle I beam rods
Wiseco 92.5mm pistons(stock stroke)
killer b ultimate oil pickup
brian crower valve springs with titanium retainers
heads recieved a slight port
tgv deletes
trans/drivetrain:
Car has a stage 2 clutch
Rallispec Sti gearset in trans with all new synchros
turbo/fuel:
Blouch 18gxt with a ceramic coated housing
bosch flow tested 850cc injectors
walbro 255lph pump
turboxs top mount intercooler
hks ssqv
3" perrin turbo inlet
other bolt ons:
Injen cold air intake
Invidia up pipe
4" bellmouth downpipe
3" straight pipe cat back
poly motor/trans mounts
Grimmspeed crank pulley
Megan short shifter
other stuff im probably forgetting
tune:
Cobb accessport with a dyno tune (not done yet)
wheels/tires:
17x8 rota g forces with 235/45/17 Z rated tires wrapped on them so it should hook
JVAWN is offline   Reply With Quote
Old 06-14-2013, 10:05 AM   #2
JVAWN
Member#: 265436
2002 wrx
blue
gunning for anything over 350whp and a 12.99 or faster time slip. i think that should be pretty well achievable but i've never built a subaru motor before. im a mustang convert lol. these cars are soo much fun
i was also thinking of tuning it at 20psi. that sound right?
Old 06-14-2013, 02:46 PM   #3
bluemk3
Member#: 263694
World Rally Blue
Your tuner should know what psi the car likes best. And should stop there.. I.e. when the car stops making power.... but if you are running this stuff with our a tune.. I'm sure you won't make it to a tune..
bluemk3 is offline   Reply With Quote
Old 06-14-2013, 03:57 PM   #4
JVAWN
Member#: 265436
2002 wrx
blue
motors still on a stand. lol. car is not being driven. going in for a tune in 3 weeks. just curious if anyone can guess what power it will put down
Old 06-16-2013, 08:00 PM   #5
bluemk3
Member#: 263694
World Rally Blue
Just fyi.. this question is a no no here...
Old 06-16-2013, 09:55 PM   #6
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Man those z rated tires should hook.
scby rex is offline   Reply With Quote
Old 06-17-2013, 01:45 PM   #7
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
I am runnin a 18g xt with a 8cm hotside on a 2L and I am overall unimpressed by this turbo, but it could just be my setup/tune on e-85 I only trapped 111-112 realistically this turbo should be able to net 340-350whp on pump gas but my car strongly disagrees
Shortpersonbk is offline   Reply With Quote
Old 06-17-2013, 02:51 PM   #8
scby rex
Member#: 104878
02 wrxbastardchild
Or you have a crap "conservative" tune.
Old 06-17-2013, 03:04 PM   #9
cowboy_Rob
Member#: 194062
2003 Impreza WRX
You should be doing way better then that especially on e85. Unless your maxing out your injectors do they had to keep the boost low maybe
cowboy_Rob is offline   Reply With Quote
Old 06-17-2013, 07:23 PM   #10
Shortpersonbk
Member#: 319017
15 Prius
23 psi and 30 degrees of timing up top it has to be something to do with my setup but in just sharing my personal experience
My injectors are close to maxing out, 750ccs but only at %90 at 12.0afr so the afrs may be a little conservative but the timing and boost isn't really
My tuner basiclly told me he doesn't like the 18gs to much and thinks we would have had much better luck with a 20g 7cm hotside
Old 06-26-2013, 11:30 AM   #11
verentchan
Member#: 355749
2008 WRX
Silver/Black
You're probably not getting enough fuel. Think about upgrading to 1100-1200cc's for E85 and I bet that thing will fly. You'll need a 2nd fuel pump or bigger than a 255 to keep the pump duty cycle down. I was running 1200cc injectors on E85 and getting around 480 ftlb, 430 hp on a conservative tune. Now unfortunately I'm in an area with no E85 within 100 miles so I'm stuck running 91 CA pump gas
::EDIT:: Depending on what block you're running....
verentchan is offline   Reply With Quote
Old 06-27-2013, 03:29 PM   #12
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Op, what are your build specs? Mainly bore, stroke, hg thickness, head cc size in cc's, piston dish size in cc's, piston to deck clearance? Cam size? All that stuff will matter and will have a greater affect on how much boost you can run and ultimately how much hp you can make on a certain fuel. Also what fuel are you going to be tuned on?
fastblueufo is offline   Reply With Quote
