Old 12-27-2012, 08:01 AM   #1
Viking Panels
Member#: 341684
2000 Impreza 2.5 RS
Default Need Dimensions of DCCD Switch ASAP
I'm fabricating a custom switch panel for a rally-car, and I need accurate dimensions of the DCCD switches. There was a last-minute change to use the factory DCCD-switches.
I would really, really appreciate it, if someone could measure the cut-out for the switch, and measure the front of the switch so I can get the spacing right for his panel.
I need to get this machined right away, and don't have time to buy a switch and wait for shipping.
Thanks very much.
Roy
Pics are here.
http://www.vikingpanels.com/dccd_switch.html
Viking Panels is offline   Reply With Quote
Old 12-27-2012, 11:51 PM   #2
TIGWERKS
Member#: 256615
If I had seen this early I could of pulled mine out and mic'd it for you. If you still need it tomorrow and if I remember I can do it.
TIGWERKS is offline   Reply With Quote
Old 12-28-2012, 12:14 AM   #3
pezcore
Member#: 178045
06 WRX
CGM
Do you have any of the blanks? Same sizes
pezcore is offline   Reply With Quote
Old 12-28-2012, 05:59 AM   #4
Viking Panels
Member#: 341684
2000 Impreza 2.5 RS
If you could do that for me, I would really appreciate it.
Roy
Old 12-28-2012, 06:10 AM   #5
Viking Panels
Member#: 341684
2000 Impreza 2.5 RS
I had a switch panel programmed for a rally-car. The guy emailed with a last minute change to use his DCCD switches. I don't have any of those switches.
I just need the hole size needed for the switch to pop into, and the size of the front of the switch, so I can get the spacing correct. It's a .125" thick, flat panel.
The customer seems like a good guy, but there's a little bit of language barrier, and his dimensions seem way too big.
Thanks very much.
Roy
