Old 08-08-2013, 09:57 PM   #751
swkep87
Member#: 150867
2004 sti
graphite gray
swkep87 is offline   Reply With Quote
Old 08-09-2013, 05:55 AM   #752
WhozNext
Member#: 265369
07 STI
Both those subys look good.
WhozNext is offline   Reply With Quote
Old 08-09-2013, 08:12 PM   #753
Mr. Nipples
Member#: 181426
2005 STi
Obsidian Black
Originally Posted by swkep87 View Post
Went to the tuner evolution show
What wheels are those, and offset? They look sexy.
I was thinking of rolling with these---> http://www.nlmotoring.com/XXR-531-Wh...53181542n1.htm
They are 18x11 with a 20mm offset, I've read through this thread and the common thing is to look for a wheel 15mm and below, is 20mm gonna be to much and cause some issues? I apologize for my ignorance but I'm trying to double and triple check before I spend any serious cash.
Mr. Nipples is offline   Reply With Quote
Old 08-10-2013, 01:19 AM   #754
apetron
Member#: 146874
07 STI Widebody
ETS,Volk,Voltex,Varis
18x11 is great to start with.
But you do want the offset lower. You could get those and run a 10mm spacer and be fine if you wanted.
apetron is offline   Reply With Quote
Old 08-10-2013, 01:52 AM   #755
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
Originally Posted by apetron View Post
Here are a few unused shots from my Super Street feature in the August 2013 issue.
Photos by Patrick Lauder
Looks amazing man. I'm running the charge speed rear aprons/spats also, did you just cut the bottom of the flare off in the rear to make it fit with them? If so did you fill the opening in the base of the flare left after cutting?
STiled_04 is offline   Reply With Quote
Old 08-10-2013, 12:14 PM   #756
718blackwrx
Member#: 199076
2006 "sti" limited
phoenix yellow metallic
I was waiting almost 6 months for those wheels and decided to cancel my order. Im going with enkies now
718blackwrx is offline   Reply With Quote
Old 08-10-2013, 02:14 PM   #757
swkep87
Member#: 150867
2004 sti
graphite gray
They r work meister s1r in 18X10.5 +15
Old 08-10-2013, 04:03 PM   #758
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
AKA sexiest wheel ever designed. I WILL own a set one day. I absolutely <3 your car btw dude. Makes me want flares.
Supa LA is offline   Reply With Quote
Old 08-11-2013, 12:20 AM   #759
718blackwrx
Member#: 199076
2006 "sti" limited
Depating whether I wanna go with enkie rpf1s in 18x10.5 +15 or nt03 18x10.5 +30 I will also be using 25mm spacers because they only come in 5x114 and my hubs are only 5x100 I already have 295/30 tires. So what do the gurus have to say as far as advice?
Old 08-11-2013, 07:57 AM   #760
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
Nt03 will be ur best option w that offset & tire size 'cause u'll practically be at 18X11.5 and rpf1's will need almost -4 of camber to fit properly. There are some scarce 5*100 wheels that wide u can get.
M4c0770 is offline   Reply With Quote
Old 08-11-2013, 10:38 PM   #761
apetron
Member#: 146874
07 STI Widebody
Yea, I just cut the flares. There really isn't any visible opening. Looks totally normal.
Old 08-12-2013, 03:41 AM   #762
STiled_04
Member#: 210933
2004 Impreza STi
Cool thanks. I hear a lot people saying they don't rub. My concern is the rear because that a common problem area. In the pics it looks like you have a finger/finger and half gap, no rubbing?
Old 08-14-2013, 04:08 AM   #763
Dena
Member#: 134874
Few newer shots of the WRX!
Dena is offline   Reply With Quote
Old 08-14-2013, 07:31 AM   #764
25rsti
Member#: 166324
So much win it's not even funny. She looks gorgeous!
Old 08-14-2013, 02:33 PM   #765
STiled_04
Member#: 210933
2004 Impreza STi
NorCal? Warren creek road?
Old 08-14-2013, 02:58 PM   #766
apetron
Member#: 146874
07 STI Widebody
No rubbing at all. There is nothing to rub on honestly. Everything has been cut off that would have rubbed.
Old 08-14-2013, 09:33 PM   #767
Dena
Member#: 134874
No sir! Maple Valley, Washington!
Old 08-14-2013, 10:08 PM   #768
STiled_04
Member#: 210933
2004 Impreza STi
Ah gotcha lol. Man that roads looks identical to where I used to live in Humboldt. Especially the train trestle. Looks beautiful and I bet it's awesome driving up there. Sure beats the hot desert here.
Old 08-14-2013, 10:14 PM   #769
STiled_04
Member#: 210933
2004 Impreza STi
Couple people I've spoke to said they rub on the under side of the rear door jam/fender. It's seems its a tight fit near the arching part, below the door latch. What areas did you cut? I've seen the post from T3hClap (or however it's spelled). Is that what you did, just the fender lip? Sorry for all the questions, I'm just questioning whether these are worth my time. I am extremely particular with aftermarket fitments. Lines have to be even, things can't rub or I don't sleep lol
Old 08-14-2013, 11:09 PM   #770
Dena
Member#: 134874
Oh yeah! Nice roads here
Old 08-15-2013, 02:38 AM   #771
apetron
Member#: 146874
07 STI Widebody
I basically cut from about 3" down on the rear bumper around the radius of the wheel well, and down to about 6" above the side skirt.
Total material cut off the actual rear is about 3 inches wide or so. Once the outer skin was cut off, the inner skin is cut into sections and folded up over the outer skin and bonded together. I then trimmed any excess and cleaned up the seam once it had cured.
Old 08-15-2013, 09:51 AM   #772
C-Farm
Member#: 280621
'07 WRX (racecar)
'14 Accord Sport 6spd
I have a question for all you guys running these flares. If you don't feel like sharing I completely understand, but what would you say is the average cost of adding these including new wheel setup and body work/paint? Very curious to see what the actual cost has been for some of you. Thanks!
C-Farm is offline   Reply With Quote
Old 08-15-2013, 03:39 PM   #773
apetron
Member#: 146874
07 STI Widebody
Really depends on the wheels you go with.
Rough guess on total cost for me to just do the flares with painting them (I did the install myself) is about $1000.
Add my Advans and Tires into that and you are look at about $5000 roughly.
Old 08-15-2013, 05:11 PM   #774
mhs5074
Member#: 184485
'06 STi AW
'08 FXT Sport 4EAT DGM
Anybody know a good body shop that could pull these off in the Tri State area?
mhs5074 is offline   Reply With Quote
Old 08-15-2013, 05:20 PM   #775
STiled_04
Member#: 210933
2004 Impreza STi
Ive been looking at the Work CR Ultimate Concave 18x10.5 e22
$1000 was what I estimated it would cost to have them installed and painted.
