Old 08-16-2013, 12:56 AM   #776
apetron
Member#: 146874
07 STI Widebody
ETS,Volk,Voltex,Varis
Offset on the Works is too high. You want +15 or lower
apetron is offline   Reply With Quote
Old 08-16-2013, 01:02 AM   #777
JoeM1494
Member#: 280146
2004 STi
Out of curiosity what offset is needed to clear the brembos?
JoeM1494 is offline   Reply With Quote
Old 08-16-2013, 01:06 AM   #778
apetron
Member#: 146874
07 STI Widebody
Depends on the wheel shape and spoke design. However if you are running +15 or lower there is going to be more then enough room typically.
Old 08-16-2013, 01:10 AM   #779
JoeM1494
Member#: 280146
2004 STi
Yeah that's what I figured. I heard like +28 or lower so basically if your blow 30 your in the clear
Old 08-16-2013, 03:08 PM   #780
Himynameisgreg
Member#: 200420
'15 LR WRX
'05 AW STI Track Car
Himynameisgreg is offline   Reply With Quote
Old 08-16-2013, 03:22 PM   #781
erok81
Member#: 300717
2004 WRX
JBP
Any info on that fender duct? Mine runs up through a fog light hole. That looks a lot better.
erok81 is offline   Reply With Quote
Old 08-16-2013, 03:26 PM   #782
Himynameisgreg
Member#: 200420
'15 LR WRX
it's just a naca duct from racepartswholesale.com. cut a naca shaped hole in the fender. riveted it on. and got an elbow pipe from home depot to feed the SRI.
Old 08-16-2013, 07:02 PM   #783
taiekchi
Member#: 130038
2004 Impreza WRX
This thread if full of win, win, win. Gotta save for my kit.
taiekchi is offline   Reply With Quote
Old 08-18-2013, 01:34 PM   #784
06_subie
Member#: 335841
Can anybody running these on just a wrx chime in? i had a few questions as to what wheel specs you guys were running and how hard it was to find a wheel wide enough with a 5x100 bolt pattern. Also i have been told before that running such and aggresive wheel/ tire combo can cause damage to the wheel bearings because they are smaller than STI ones.
06_subie is offline   Reply With Quote
Old 08-19-2013, 02:07 PM   #785
swkep87
Member#: 150867
2004 sti
graphite gray
swkep87 is offline   Reply With Quote
Old 08-20-2013, 01:48 AM   #786
apetron
Member#: 146874
07 STI Widebody
Old 08-20-2013, 10:07 AM   #787
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
Originally Posted by swkep87 View Post
Please stop posting pics of your car so i dont have to wait at least 15 minutes afterwards to stand up at work.
Supa LA is offline   Reply With Quote
Old 08-20-2013, 11:48 AM   #788
Batty
Member#: 38182
2006 STi
Matte Red Fernder flurrrs
Karlton Flares in their natural environment!
Batty is offline   Reply With Quote
Old 08-20-2013, 01:41 PM   #789
CatfaceType-R
Member#: 81102
^^^ewang achieved!
CatfaceType-R is offline   Reply With Quote
Old 08-20-2013, 05:49 PM   #790
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
Why do I see several cars on here not using the lower front section of the front flares?
STiled_04 is offline   Reply With Quote
Old 08-20-2013, 06:01 PM   #791
JSti07
Member#: 190019
07 STi
swp
I'm assuming that the tire rubs on them since most people running the flares have such wide wheels. But what I am wondering is what do the people running the full flare do to add the extra clearance.
I could be wrong though.
JSti07 is offline   Reply With Quote
Old 08-20-2013, 07:10 PM   #792
apetron
Member#: 146874
07 STI Widebody
Depends on how much caster they are running and how wide the wheel is.
I have no clearance issues on mine.
Old 08-20-2013, 07:23 PM   #793
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Got a question. Looking at putting these flares on my car, how will an 18x11 +20 fit? Thanks
dburgoon is offline   Reply With Quote
Old 08-20-2013, 07:39 PM   #794
apetron
Member#: 146874
07 STI Widebody
+20 is too high. You'd want a 5mm or 10mm spacer with those.
Old 08-20-2013, 07:46 PM   #795
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
+1 depends how much caster they're running. I also have no clearance issues on mine. 18x11 +10 with 5 degrees of caster.
18x11 +20 will be ok, but +1 to what apetron said
pignoseSTI is offline   Reply With Quote
Old 08-20-2013, 07:48 PM   #796
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Thanks! I'm not opposed to spacers but I would rather not drive with them. I just need some wheels to drive around on until I get the money to get some ccw's. but if I'm doing the flares I need to do them now before I get the car re-painted
Old 08-21-2013, 12:57 AM   #797
JoeM1494
Member#: 280146
2004 STi
Does anyone have a step by step thread on installing the flares? I've heard it of different ways and I'm just curious before I go and purchase them this winter
Old 08-21-2013, 01:34 AM   #798
jutes85
Member#: 127232
E92 M3
98' Foz
http://t3hclap.com/archives/552
jutes85 is offline   Reply With Quote
Old 08-22-2013, 09:59 AM   #799
Subazda
Member#: 362836
2005 Impreza TS
Rally Blue
Default fitment question
so i have a 2005 Impreza , Planning to buy Enkei RPF1 18x10 +38 and 25 ISC Adapters to change the bolt pattern , so i will be running +13 offset , and 285/35 tires , my question is will it be big enough to fit flares or i need to get 10.5 or 11" wheels ? , notice that i can't buy the 18x10.5 +15 because of the offset and adapters , because if i do i will be running -10 offset , which will be too much.
Subazda is offline   Reply With Quote
Old 08-22-2013, 10:06 AM   #800
07imprezRS
Member#: 164302
2011 STi Ltd Sedan
DGM & 02 WRB WRX
285 tires on a non turbo impreza seems a bit much but if you are just going for the look like most are these days you'll need at least 10.5 wide wheels to justify the flares. Maybe even a 5mm spacer as well...
07imprezRS is offline   Reply With Quote
