Old 08-22-2013, 11:02 AM   #801
Subazda
Member#: 362836
2005 Impreza TS
Rally Blue
Originally Posted by 07imprezRS View Post
285 tires on a non turbo impreza seems a bit much but if you are just going for the look like most are these days you'll need at least 10.5 wide wheels to justify the flares. Maybe even a 5mm spacer as well...
it's for the looks , but isn't a 5mm spacer on a adapter is a killer for the bearings , the safety , and my wallet ? and if i need those extra 5mm i may go for the 18x10.5 +15 and have a -10 offset , but will it look stupid ? , specially that i won't be slamming the cars because of the bumpy roads .
so what are the cons of having a -10 offset ?
Subazda is offline   Reply With Quote
Old 08-22-2013, 01:08 PM   #802
apetron
Member#: 146874
07 STI Widebody
ETS,Volk,Voltex,Varis
I would not in any way run that setup on your Impreza.
The 25mm spacer/conversion is going to kill your wheel bearings. -10 is really low and will take a ton of work to make it look right, especially with the wheels only being 10" wide.
My suggestion is to save your money, get a nice set of wheels that fits your stock body with 5x100 and be happy.
Adding the flares and massive wheels on an Impreza TS with no turbo is going to make you sad, especially if you are not lowering it enough to make them look right.
apetron is offline   Reply With Quote
Old 08-22-2013, 01:19 PM   #803
Subazda
Member#: 362836
2005 Impreza TS
Rally Blue
i am glad that i got the reply from you , i was actually going to copycat your car with the Enkei's , so what wheels do you suggest to be wide enough to fit with the flares ? also where did you get the center console carbon part ?
Old 08-22-2013, 03:43 PM   #804
Himynameisgreg
Member#: 200420
'15 LR WRX
'05 AW STI Track Car
Originally Posted by STiled_04 View Post
Why do I see several cars on here not using the lower front section of the front flares?
mine were installed before i bought the car last year, but i think the front section of mine was left off because of the Cusco lip. either not wanting to notch the flare or not wanting to drill a hole in a perfectly good Cusco lip is my guess haha.
Himynameisgreg is offline   Reply With Quote
Old 08-22-2013, 03:52 PM   #805
05subysti
Member#: 268190
2005 STi
Man don't listen to the low offset crap, unless youre 5x100 LOL
5x100 bearings suck whale dick
I have 18x10.5-26 and the lip is flush with the flare.
So 18x10.5-10 with be fine.
Don't waste money getting the flares and get 18x10s cause it'll look stupid.
Anything 18x10.5/11/11.5/12 +22 or lower offset will work with 285/30,295/30,315/30.
05subysti is offline   Reply With Quote
Old 08-22-2013, 03:54 PM   #806
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
So what you are saying is I can get 18x10.5 et20 and get 5x100 to 5x114 25mm spacer with 285/30 will work?
dburgoon is offline   Reply With Quote
Old 08-22-2013, 03:59 PM   #807
05subysti
Member#: 268190
2005 STi
Yes I had 18x11+21 with 285/30s and 25mm spacers on top equalling 18x11-4 which worked out perfect.
Old 08-22-2013, 04:07 PM   #808
07imprezRS
Member#: 164302
2011 STi Ltd Sedan
DGM & 02 WRB WRX
Sell your impreza TS and with this extra money you are contemplating on spending for flares and wheels buy a wrx or sti. Trust me I've had a couple non turbo subies and they can be fun but not with 45lb tire and wheel setups. You'll want to invest that kind of money in something more enjoyable. Not trying to discourage you from getting the look you want just offering advice.
07imprezRS is offline   Reply With Quote
Old 08-22-2013, 04:34 PM   #809
Subazda
Member#: 362836
2005 Impreza TS
Rally Blue
where i live , there is only 3 WRX , 2 STI :/ , so this will be impossible .
Old 08-22-2013, 04:35 PM   #810
Subazda
Member#: 362836
2005 Impreza TS
Rally Blue
did misunderstand you , or you are saying that the bearings are bad but there is no problem with the negative offset and 25mm adapters ?
Old 08-22-2013, 06:11 PM   #811
apetron
Member#: 146874
07 STI Widebody
He is 5x100 with a base Impreza, not a WRX.
That's why I said it would take too much work to make them fit properly and safely. 18x10 -10 would look weird. On top of that adding spacers/adapters to make it 5x114.3 would be worse then just running a low offset 5x100 wheel. Those bearings are going to die a smokey death.
-26 is fine if you have 5x114.3 and the right wheel width to make it work.
Old 08-22-2013, 10:25 PM   #812
05subysti
Member#: 268190
2005 STi
if you don't care about being slow and blowing a wheel bearing on the highway run 5x100.
or convert to 5114.3 and do whatever size wheel you want.
but ya I agree about having 285s being too much for a non turbo car.
Old 08-23-2013, 08:09 AM   #813
Batty
Member#: 38182
2006 STi
Matte Red Fernder flurrrs
Still no pictures on this new page
Batty is offline   Reply With Quote
Old 08-23-2013, 09:35 AM   #814
mhs5074
Member#: 184485
'06 STi AW
'08 FXT Sport 4EAT DGM
Batty, what are your wheel specs again? She looks mean
mhs5074 is offline   Reply With Quote
Old 08-23-2013, 09:50 AM   #815
Batty
Member#: 38182
2006 STi
AME TM-02's 18x11 +10 with 295/30/18 tires
Old 08-23-2013, 02:47 PM   #816
05subysti
Member#: 268190
2005 STi
Looks great batty!
Here's an old pic of mine
Old 08-23-2013, 02:47 PM   #817
05subysti
Member#: 268190
2005 STi
Double post*
Old 08-23-2013, 04:31 PM   #818
jutes85
Member#: 127232
E92 M3
98' Foz
Stretched 295's on a STi. Never thought I'd see the day.
jutes85 is offline   Reply With Quote
Old 08-23-2013, 10:26 PM   #819
Batty
Member#: 38182
2006 STi
Looks great batty!
Looks awesome, I love those wheels!
Old 08-26-2013, 12:49 PM   #820
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
Do many of you have that slight gap between the flare and body/bumper on the rear side of the rear flares? Right near the section of the bumper where the oem flare would match up.
I've looked at several installs and all have had that slight gap. It does not sit flush to the body.
STiled_04 is offline   Reply With Quote
Old 08-26-2013, 11:03 PM   #821
apetron
Member#: 146874
07 STI Widebody
Old 08-26-2013, 11:12 PM   #822
mhs5074
Member#: 184485
'06 STi AW
Mine has a slight gap as well
Old 08-27-2013, 01:12 AM   #823
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Are you talking about on a 04 sti like this? Because they were only made for the 05 sti.
These don't have a gap, maybe because I had a hand in installing them I don't know haha. My car also doesn't have a gap.
pignoseSTI is offline   Reply With Quote
Old 08-27-2013, 11:08 PM   #824
apetron
Member#: 146874
07 STI Widebody
As posted above by karlton, no gap on mine. (Black STI)
Old 08-30-2013, 05:51 PM   #825
Scooby001
Member#: 366953
Originally Posted by pignoseSTI View Post
You should be ok on the 285s. I ran 10.5 +25 with 285/30/18 and your setup will sit 3mm further in than this.
I was reading your post and was wondering if you think i will rub with 18x11 +20 with 285 tires
Scooby001 is offline   Reply With Quote
