Old 08-30-2013, 08:08 PM   #826
SpeedElement
Member#: 18920
2004 WRX/STI
Originally Posted by apetron View Post
nice!
SpeedElement is offline   Reply With Quote
Old 08-31-2013, 12:58 PM   #827
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
Karlton, apetron, yours do look as though they were installed more carefully than others I've seen. I know that I would need an 05-07 rear bumper, just wanted to be sure that a flush fit was possible once the bumper was changed.
STiled_04 is offline   Reply With Quote
Old 08-31-2013, 02:36 PM   #828
apetron
Member#: 146874
07 STI Widebody
ETS,Volk,Voltex,Varis
Most likely because both sets were installed by Karlton himself. I did all the cutting on mine but he helped with all of the alignment and setup.
apetron is offline   Reply With Quote
Old 08-31-2013, 06:43 PM   #829
05subysti
Member#: 268190
2005 STi
Originally Posted by Scooby001 View Post
I was reading your post and was wondering if you think i will rub with 18x11 +20 with 285 tires
I ran 18x11+21 with minor rubbing up front.
And if you go lower than 2 inches your wheel will rub the coilover depending on camber.
05subysti is offline   Reply With Quote
Old 08-31-2013, 08:55 PM   #830
STiled_04
Member#: 210933
2004 Impreza STi
Gotcha. Well it shows haha. I will be talking to a local body shop and showing these photos.
Old 09-01-2013, 11:02 AM   #831
05subysti
Member#: 268190
2005 STi
Just man up and do the install yourself.
It really is not difficult.
After you install the flares and are happy with fitment, then get a body shop to paint them:
You will easily spend $1-2500 getting a good body shop to cut your panels, bond/weld, seal, bodywork and paint without the cost of flares.
You can save over half if not most if that by doing it on your own.
Old 09-01-2013, 10:29 PM   #832
STiled_04
Member#: 210933
2004 Impreza STi
I hear you. I would need to buy more tools to complete it, welder for example. The inner and outer fenders are already split from aggressive wheel fitments. The body shop who is installing a friends is charging 1k.
Old 09-02-2013, 10:19 AM   #833
05subysti
Member#: 268190
2005 STi
You don't need much tools lol. I did mine with grinder, dremel, 3m panel bond, clear silicone, nutserts, and bolts of your choice.
You don't have to weld them shut. You can rivet them, use expandable foam inside any gaps, bond it, then seal.
Old 09-02-2013, 07:16 PM   #834
erok81
Member#: 300717
2004 WRX
JBP
Speaking of 3m panel bond. Is it possible to use that stuff without the dispensing gun? I'm thinking maybe squeeze it out and mix like you would jb weld or something? I'm all for buying one time use tools but that thing is a tad expensive.
erok81 is offline   Reply With Quote
Old 09-03-2013, 01:00 AM   #835
apetron
Member#: 146874
07 STI Widebody
Not that I am aware of honestly.
It needs to be mixed at a specific ratio which the gun when set properly does when you squeeze it.
Old 09-03-2013, 11:57 AM   #836
mhs5074
Member#: 184485
'06 STi AW
'08 FXT Sport 4EAT DGM
Have any of you had issues with rubbing of the front tires on hard turns? It may be because I sit too low because my wheels aren't that aggressive (10s on 285/30/18s).
I was wondering whether trimming down the fold on the inside of the flares would eliminate this issue. Have any of you guys run into an issue like this before and what did you do to fix it?
mhs5074 is offline   Reply With Quote
Old 09-03-2013, 02:16 PM   #837
apetron
Member#: 146874
07 STI Widebody
You are supposed to trim the lips off of the insides of the flares. They are only there to make removing them from the molds easier.
Old 09-03-2013, 02:30 PM   #838
mhs5074
Member#: 184485
'06 STi AW
Thank you!!!
Old 09-03-2013, 08:05 PM   #839
05subysti
Member#: 268190
2005 STi
Ya trim all that crap off lol it's like a half inch of pointless fiberglass.
Old 09-03-2013, 09:53 PM   #840
mhs5074
Member#: 184485
'06 STi AW
I trimmed about half of the width of it off just to test if that's where I was rubbing. Turns out when I do the same test at the same speed, it still makes the identical rubbing sound (no more no less). So I think it might be an issue else where.
Mind you the test turns I'm making are slight elevation changes as well so maybe height is a factor?
Edit: One other question, did you guys cut the front bumper at all when installing these? Mine wheels sit pretty damn close to the bumper that's why I ask
Old 09-06-2013, 04:38 AM   #841
stallisassjason
Member#: 260197
wrx youtube.com/
user/stallistib
If its hidden under the flare and you want to chop it off do it. ( not the nutserts tho ) I cut a bit of my bumper's
stallisassjason is offline   Reply With Quote
Old 09-06-2013, 03:35 PM   #842
apetron
Member#: 146874
07 STI Widebody
I did not cut my front bumper at all.
Old 09-06-2013, 06:13 PM   #843
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
I cut the corner of my bumper off, and some of the attachment clip. I prob have 70% of the attachment left or so. But yea, basically if it's hidden under the flare, you can hack it off lol.
pignoseSTI is offline   Reply With Quote
Old 09-06-2013, 06:25 PM   #844
apetron
Member#: 146874
07 STI Widebody
I take back my previous statement. We did the same thing on my car.
Old 09-06-2013, 07:26 PM   #845
igz
Member#: 188104
2005 subaru wrx sti
dont know yet :P
had a friend of mine take some shots of the car, let me know what you guys think and what i can improve on maybe?
igz is offline   Reply With Quote
Old 09-06-2013, 08:50 PM   #846
Aarron_M
Member#: 68210
2016 Mustang GT
Oxford white
Car is too small in the pic to see anything.
Aarron_M is offline   Reply With Quote
Old 09-06-2013, 10:25 PM   #847
Mishal Jackson
Member#: 304871
05 WRX Wagon
Well I zoomed... Looks good though man. Just make her faster I'd say
Mishal Jackson is offline   Reply With Quote
Old 09-13-2013, 12:38 PM   #848
sk8rtilldie
Member#: 157070
03 RR EVO *8
WFC #44
does any know where i could get this black stripe molding??
sk8rtilldie is offline   Reply With Quote
Old 09-13-2013, 02:08 PM   #849
igz
Member#: 188104
2005 subaru wrx sti
dont know yet :P
thats my car ^^^ got it at a local truck shop. call around.
Old 09-13-2013, 08:00 PM   #850
RJSMITH
Member#: 347474
2002 wrx,01 L coupe
mbp,sr
looks like just door edge stuff u should be able to get in a pretty good amount of length ebay probably the easiest way probably most auto parts places like advanced auto parts pepboys bigger napas might have it
RJSMITH is offline   Reply With Quote
