Old 02-01-2013, 08:23 PM   #151
mhwrx02
Member#: 174582
2005 STI
Originally Posted by Dena View Post
here's a bit of an update.
Went to Discount and mounted the tires on the new wheels; did a bit of a test fit in the front to see if there will be any clearence issues; nope they fit perfectly; full turn left and right it clears at this height and I can even go lower and add more camber if needed. Don't mind the mexi-poke; flares haven't arrived yet .
What size are the barrels, and what size are the lips. I am currently building a set of VS-XX's as well and have 6" barrels. I was thinking of running 5" lips in the rear and 4" in the front with 275/35/18 all the way around.
mhwrx02 is offline   Reply With Quote
Old 02-01-2013, 08:29 PM   #152
Dena
Member#: 134874
they are 18x11.5 +7 5" lips all around. 295/30/18 Hankook Ventus V12's i believe they are 6" barrels i never measured.
also if you plan on doing karlton flares; run a 275/30 35 is too tall
Dena is offline   Reply With Quote
Old 02-01-2013, 08:35 PM   #153
mhwrx02
Member#: 174582
2005 STI
ok. those lips are insane, thus i will be buying some monday. Those would fit well with the flares. One thing i ran into with my flares is i had them painted without trimming the under lips. I recommend before you send them off to paint (if you are painting them), to cut the inner lips, so you dont run into a rubbing problem. The install of the rears is time consuming because of all of the cutting, so make sure you have plenty of brews.
Old 02-01-2013, 08:41 PM   #154
Dena
Member#: 134874
I heard about the lip on the flares being too big; i plan on getting everything set up then taking the flares off and sending them in for paint. I need to restock on some Becks; i ran out.
Old 02-01-2013, 08:56 PM   #155
subarutah
Member#: 248428
2006 STI
FROZEN GREY
Go up to outback and take a look at the lips on mine, they haven't been trimmed down yet
subarutah is offline   Reply With Quote
Old 02-01-2013, 11:07 PM   #156
apetron
Member#: 146874
07 STI Widebody
ETS,Volk,Voltex,Varis
Just to confirm what was said above, 275/35/18 is way too tall for this setup/our cars. I had them on my RPF1s before I switched to the Advans. The 295/30/18 fit much better.
apetron is offline   Reply With Quote
Old 02-01-2013, 11:45 PM   #157
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Definitely trim the lips on the flares. They're just there as it makes it easier to pop them out of the molds
pignoseSTI is offline   Reply With Quote
Old 02-02-2013, 12:47 AM   #158
subarutah
Member#: 248428
2006 STI
FROZEN GREY
I'm terrible at raking pictures
Old 02-02-2013, 12:59 AM   #159
jutes85
Member#: 127232
E90 M3
98' Foz
And grammar apparently.
Damn molded looks good, still can't decide if its worth the money. Did they strengthen the flares at all?
jutes85 is offline   Reply With Quote
Old 02-02-2013, 01:03 AM   #160
subarutah
Member#: 248428
2006 STI
FROZEN GREY
Posted from my phone and auto-correct is a bitch lol.
They seem pretty damn solid. They are still riveted under the mold though
Old 02-02-2013, 02:27 AM   #161
Strawhatrr
Member#: 267395
Looks good molded. That's cool.
Strawhatrr is offline   Reply With Quote
Old 02-02-2013, 01:06 PM   #162
blu subaru
Member#: 117584
2006 WRX TR
San Remo Red
Originally Posted by Eww Evo View Post
@WRXPCT04
Here's my 06' contribution
Very nice, looks mean!!
Where did you purchase your flares? I'm sure this is a very common question and I apologize, I just don't check out the Members Car Gallery that often. Also, what wing is it that you're running?
What hood do you have?
blu subaru is offline   Reply With Quote
Old 02-02-2013, 01:29 PM   #163
WRXPCT04
Member#: 144563
2006 STi
SGM GTX3076
Kaminari
WRXPCT04 is offline   Reply With Quote
Old 02-02-2013, 01:55 PM   #164
bboylocob
Member#: 151809
2007 WRX
Hopefully i can get a pair soon
bboylocob is offline   Reply With Quote
Old 02-02-2013, 07:48 PM   #165
Ronin_STi
Member#: 147969
2007 STi
I'm not trying to be ignorant, but it looks like you will still rub with these on any bumps. Don't get me wrong I love the way they look but do you guys rub at all?
Ronin_STi is offline   Reply With Quote
Old 02-02-2013, 07:54 PM   #166
05subysti
Member#: 268190
2005 STi
No you don't rub. There's like an inch worth of flare to trim if you run negative offsets or 295s< just trim the excess.
05subysti is offline   Reply With Quote
Old 02-02-2013, 10:51 PM   #167
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
You do realize you clearance your stock fender right? Then add these on top. That gives you enough clearance for you to run pretty much whatever you want.
And how my car currently sits. Redoing a few things
Old 02-02-2013, 11:22 PM   #168
stockturboftw06
Member#: 171505
06 sti
java black
18 x 10.5 with 275s
18x11 with 295s
stockturboftw06 is offline   Reply With Quote
Old 02-03-2013, 07:26 AM   #169
mhwrx02
Member#: 174582
2005 STI
how is the drivability with the 11's on 295's when it comes to turning, do the front wheels rub on the inner panels of the car at all? And what offset are those?
Old 02-03-2013, 10:40 AM   #170
05subysti
Member#: 268190
2005 STi
the offsets iirc are +5 and depends on the offset but yeah you might get some rubbing on the inner tubs on full lock.
Old 02-03-2013, 02:11 PM   #171
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Actually we found out he has +0 offset wheels. I have no rubbing at full lock at 11 +10 though I have 285s (that run wide)
Old 02-03-2013, 02:43 PM   #172
05subysti
Member#: 268190
2005 STi
Oh he posted 18x11+5 but okay lol and if anyone has 18x11 with a higher offset than +20 you will rub on full lock depending on your ride height.
Old 02-03-2013, 04:41 PM   #173
mhwrx02
Member#: 174582
2005 STI
So by me running 18x11 +22 with 285/30/18 I will rub under full lock? I plan on leaving a half inch of space between the flare and my tire.. Thoughts on this setup?
Old 02-03-2013, 04:47 PM   #174
subarutah
Member#: 248428
2006 STI
FROZEN GREY
You need to lower the offset. Id go somewhere between +15 and +5
Old 02-03-2013, 05:16 PM   #175
1VIPWRX
Member#: 107554
yellow
do the rear tires hit the body of car when running these flares?
1VIPWRX is offline   Reply With Quote
