Old 06-21-2012, 07:48 PM   #1
outdoorsoob
Member#: 317053
Default 2012 Impreza Removing the Grill
Hi so I finally got my 2012 Sport limited yesterday and im loving it so much! i want to plastidip the chrome wings on the grill black, like i've seen you guys doing. i know i could mask it ON THE CAR like some but there's no way to cover the radiator with cardboard so id rather remove it. how do you do this?? there are little black-capped things on the lip right under the hood (are they screws). directions would be much appreciated. photos not necessary but would be amazing.
Thanks!
outdoorsoob is offline   Reply With Quote
Old 06-21-2012, 08:55 PM   #2
WLS
Member#: 316030
Thanks!
I want to swap out my grill so I'd appreciate a how to. I expect those plastic things are push in rivets but I don't know the best way to pry them out. I'm just gonna get the sport grill cause even if you paint the original grill it's still gonna look boring.
WLS is offline   Reply With Quote
Old 06-21-2012, 09:01 PM   #3
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
They are simple little push pins I used a small (tiny) Flat head screwdriver to pry mine out while doing a horn upgrade. They removed very easily and went back just as quick and easy.
ZionZR2 is offline   Reply With Quote
Old 06-21-2012, 09:40 PM   #4
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Haunty is offline   Reply With Quote
Old 06-22-2012, 07:52 AM   #5
WLS
Member#: 316030
Originally Posted by Haunty View Post
Thanks. they are a bit confusing though. They seem to imply that the whole front fascia has to be removed and that there are screws at the bottom of the grill. I hope not. I just want to remove the top push pins and pull it up and out. I hope it works that way. My sport grill will arrive in a week. I see some people are trying to sell their original grills on eBay but no takers.
Old 06-22-2012, 12:22 PM   #6
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
It is possible to remove the grille without having to remove the front fascia. Have not done it yet myself, but a few here have.
jr0bb5 is offline   Reply With Quote
Old 06-22-2012, 12:43 PM   #7
ans2k
Member#: 315631
2012 Impreza Sport
U don't have to remove the whole front bumper. I have removed the grille without removing the bumper. But you need small hands really. So there are the black pus pins on top. Remove all of them. You need to black plastic behind the grille first. That is a separate piece. Removing it will allow access to the four screws on the left and right side of the grille. Then, there are four sets of two clips. They need to be pushed together to remove the grille. Also there are clips on the sides. But I just gave it a gentle/forceful yank. But the bottom clips will break if you are not rushing. Ask me how I know. when you do push the clips at the bottom together, do not push them together at the top. Try to push them together where they meet the back of the bumper. Also start from one side. And then pull it out from one side as you push the clips together.
Old 06-25-2012, 03:06 AM   #8
outdoorsoob
Member#: 317053
Thanks guys! I got it off and everything. but one problem. i sprayed on four coats of plastidip and then when I went to remove the masking tape, the plastidip just peeled off! did i not buy the right stuff?
Amazon.com: Performix PLASTI DIP Intl. Mulit-Purpose Rubber Coating Spray BLACK 11oz: AutomotiveAmazon.com: Performix PLASTI DIP Intl. Mulit-Purpose Rubber Coating Spray BLACK 11oz: Automotive
I know it's not rubber I'm spraying, but I thought this was it.
Old 06-25-2012, 03:43 AM   #9
doomedromance
Member#: 320293
2012 Impreza Sport P
More boring than a sheet of chicken wire with a Subaru logo in the middle of it?
Probably didn't do it right.
doomedromance is offline   Reply With Quote
Old 06-25-2012, 03:51 AM   #10
ans2k
Member#: 315631
2012 Impreza Sport
yep that is the right stuff. you just have to be careful.
Old 06-25-2012, 04:00 AM   #11
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Yup you got the right stuff, did you wait for at least 2 hours in between coats for it to dry before applying the next coat?
Old 06-25-2012, 04:18 AM   #12
outdoorsoob
Member#: 317053
Wow! Thanks so much for the video. Glad I got the right stuff. In the video, he said he only waited 15 minutes between each coat and 30 for the last. What should I do? Wait 2 hours or 15 minutes? the back of the bottle says 30 minutes haha.
One more bit of advice please: I'm going to black out the entire thing except the emblem. Should I bother to mask the emblem and the stuff that's black (not chrome) that I don't want to be black or can I just peel off the dip on the emblem ex post facto?
Thanks guys
Old 06-25-2012, 04:19 AM   #13
outdoorsoob
Member#: 317053
I, who is used to regular old spraypaint, carelessly took off the masking tape. that's the only issue.
Old 06-25-2012, 05:33 AM   #14
doomedromance
Member#: 320293
I'd say spray the whole thing and then use a razor to cut out the emblem.
Seems easier. The guy in the video sprays entire cars without taping over the windows. He said it's just easier, faster, and better spray coverage to just paint the windows then peel it off later.
Old 06-27-2012, 05:59 PM   #15
WLS
Member#: 316030
Got my new sport grill and was able to remove the OEM grill with minimal problems. You do have to remove that back shelf and then with a bit of twisting you can get at the 4 screws on the sides. I used a stubby phillips sucessfully on the lower two. with those out you can twist it forward enough to get a hand in and push the bottom clips free. No need to remove the front fascia at all as there is enough flex to work with.
Now I'm lovin my new distinctive grill look. The mesh should do a better job of stopping rocks or big bugs from hitting the radiator and the color matched edges give it a much more subtle and
stylish look. I like how the Subie stars emblem just seems to float there.
Old 12-09-2012, 09:24 PM   #16
azerpmis
Member#: 338832
Can you do a vid on how to remove the grille. Or can anyone make on here make a vid? XD I'm having a bit of trouble installing my sports mesh grille.
azerpmis is offline   Reply With Quote
Old 12-11-2012, 04:17 AM   #17
pkL
Member#: 313093
2012 Impreza 2.0i
Thanks guys
Wow, I never checked back on this thread until today. I didn't bother with any masking, I just sprayed the whole grille and peeled off the paint on the emblem. If you're paranoid in tearing off more than what you want, you can always lightly run a sharp cutter along the crevice and peel it off.
Old 12-11-2012, 04:57 PM   #18
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
I doubt anyone will make you a video, but this SHOULD be pretty straight forward:
http://techinfo.subaru.com/proxy/661...010fj000xx.PDF
Blur125 is offline   Reply With Quote
Old 01-05-2013, 06:28 PM   #19
azerpmis
Member#: 338832
Did you guys go under the car to try to get the screws in the back?? Or is there another way I dont know about
Old 01-06-2013, 02:28 AM   #20
Chingyul
Member#: 333537
2013 Impreza 5dr
Touring DGM
No need to go under. Just use a stubby screw driver and come in from the top. Gotta really get your hand in there.
Or try to find a small ratcheting bit driver.
Chingyul is offline   Reply With Quote
2012 Impreza Matte Black Wrap. Side Mirror Removal. Help Please!!!! audiophile17 Interior & Exterior Modification 0 04-12-2012 05:56 PM
Replacing the parking bulb: do I REALLY have to remove the grill? Asinine Service & Maintenance 4 02-21-2010 03:39 PM
Please help me find... How to remove the grill on MY04 jason2004STI Interior & Exterior Modification 3 08-09-2006 05:35 PM
I-Badge for GC8 (need I remove the grille?) balajc Interior & Exterior Modification 7 06-25-2003 11:55 PM
Remove the grill Funfun Vancouver Impreza Club Forum -- VIC 6 03-15-2002 03:52 AM
