Old 12-27-2012, 11:54 PM   #1
bruuster
Member#: 310131
2013 Impreza Limited
Satin White Hatchback
Default Touch up paint- spray or brush
I have a nice size scrape on the front plastic skirt of my Satin White Pearl Impreza. I scraped it on a high curb. Should I buy a spray can from those 3rd party paint companies. Cost about $60 with tricolor and a clear coat. Or should I just use the factory bottle w/ brush from the dealer for $10.
bruuster is offline   Reply With Quote
Old 12-28-2012, 04:13 AM   #2
NewportSooob
Member#: 333403
May as well brush it on if you already have the factory bottle. Since it's only plastic, you could probably sand it afterwards too if it looks shoddy. Hard to say though without having seen it.
NewportSooob is offline   Reply With Quote
Old 12-28-2012, 06:00 AM   #3
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
I'd just brush it, unless you're well versed in the refinishing process. Could come out worse.
MattTHEpainter is offline   Reply With Quote
Old 12-28-2012, 07:53 AM   #4
dsn112
Member#: 332561
2016 WRX LTD
Spray gets everywhere too, so much prep involved. Also SWP is so hard to match right, even for body shops. Just brush it with a very small amount and try just to cover it up. Never gonna match it on your own.
dsn112 is offline   Reply With Quote
Old 12-28-2012, 08:33 AM   #5
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
debatable.
Old 12-28-2012, 01:59 PM   #6
bruuster
Member#: 310131
Default Guess I'll try the brush
I can get the paint from the dealer. Satin white comes in 2 bottles for separate coats. Base and Pearl I think. Just thought a spray would give a better matching texture but I can always get the spray if the brush doesn't look as good.
Thanks for your inputs
Old 12-28-2012, 02:58 PM   #7
dsn112
Member#: 332561
2016 WRX LTD
Originally Posted by MattTHEpainter View Post
debatable.
using the factory paint code of the vin, a reputable shop that has a great rep, is on their second attempt to paint a new tow hook cover for my car. They said all of the cars with this color paint can give some trouble.
Using the factory code the first try it wasn't even close.
Old 12-28-2012, 03:01 PM   #8
vuskeedoo
Member#: 312613
2012 WRX Prem. Stg 2
Buy the touch up paint from a dealer. I scraped my front bumper pretty bad and it cleaned it up. I also got some 3000 grit sand paper and sanded between coats because I had gashes.
you can barely tell it's there unless you look closely.
vuskeedoo is offline   Reply With Quote
Old 12-28-2012, 03:06 PM   #9
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
I could see where that may be difficult. I've painted that color quite a few times with zero problems. Just spray a letdown panel and see how close you are.
What paint system?
Old 12-28-2012, 05:19 PM   #10
dsn112
Member#: 332561
2016 WRX LTD
What paint system?
I'm not sure, but in there defense the car was with me the whole time so they had no idea if it was close. Hopefully next week it's done and is closer.
Old 01-03-2013, 03:55 PM   #11
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
how many coats would you say you did before you started to sand? i have a decent scrape under the front lip of the bumper and its bugging me...would like to try to level off the scrape, i assume lots and lots of coats to fill it in.
Blackmamba24kb is offline   Reply With Quote
Old 01-03-2013, 05:32 PM   #12
vuskeedoo
Member#: 312613
Here is the pic of what happened:
Here is what I did.
1) Use the pen or brush to paint the base coat.
2) Let it dry for about 30-45 minutes.
3) Sand down the coat.
Repeat 1-2 times depending on how bad the scratches are. After you feel that the base coat is good and nothing bleeds through. Apply 2 coats of clear and sand in between.
I'll try to post an after pic tonight.
Old 01-09-2013, 12:19 AM   #13
Oraga1
Member#: 343029
2012 Impreza S 2.0i
Satin White Pearl
For small chips to the bumper I have found that paint pens from http://www.automotivetouchup.com work rather well. Just make sure that the first coat has dried completely. The pen tips are a little abrasive and you might accidnetly undo the first layer if you are impatient. I have the two layered Pearl Satin White. With a steady hand you don't notice the touchup until you are about four feet away.
Oraga1 is offline   Reply With Quote
Old 01-14-2013, 09:29 PM   #14
nabokovfan87
Member#: 340943
Had some chips on mine (Dark Gray Metallic, 2012) and I got the turtle wax repair kit.
Don't use that. It essentially scratched the clear off.
Anyways, something like that with spray clear and some polishing compound as well as the paint is what you want. For LARGE areas you want to use the brush, but make sure it isn't TOO much or it will just come off.
For the deeper or chip type damage you want to use a stick/q-tip end (not the cotton one), or toothpick and dab it into the hole.
After either method, seal it. and polish the edges after it dries.
nabokovfan87 is offline   Reply With Quote
Old 01-24-2013, 04:42 PM   #15
subi21
Member#: 338346
2010 Wrx
Ok so I just got my fenders rolled a while back and the paint started flaking off. I'd like to re paint or use an epoxy to stop it from ever rusting. I live in Chicago which means snow and salt. Thanks
subi21 is offline   Reply With Quote
Old 01-30-2013, 05:21 PM   #16
What v8
Member#: 254718
how badly? really the proper way to repaint over bare metal is to etch prime, prime, then paint. As for the three stage paint matching it is very difficult to match and damn near impossible without the car there to see how close you are. basically you are just getting the color darker everytime you apply the mid coat so its kinda like eyeballing it. Wish it was as easy as just blending the next panel for color match.
What v8 is offline   Reply With Quote
Old 01-31-2013, 01:03 AM   #17
subi21
Member#: 338346
2010 Wrx
It's not to bad it's just the inside of the fender where it got rolled. No cracking that can be seen unless you look under the well. I'd just like to get it taken care of ASAP so I don't have any rust problems in the future. I'm thinking a body shop would be the best because I'm not to handy with paint.
Old 01-31-2013, 09:21 AM   #18
whiteout007
Member#: 345512
i would use a brush
whiteout007 is offline   Reply With Quote
Old 01-31-2013, 09:28 AM   #19
subi21
Member#: 338346
2010 Wrx
I was thinking maybe doing a like bed liner coating on the inside the fender well. More opinions would help out thanks
Old 01-31-2013, 09:31 AM   #20
subi21
Member#: 338346
2010 Wrx
What do you guys think about a white herculiner for inside the fenders?
Old 01-31-2013, 10:06 AM   #21
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
It wont be white in about 10 miles. IMO unless your getting it way cheap go black
dangerousatom is offline   Reply With Quote
Old 01-31-2013, 10:12 AM   #22
subi21
Member#: 338346
2010 Wrx
Haha alright. I think ima just have a shop do it. My buddy lives in Colorado and his are all chipped and said he hasn't experienced rust yet. I just want to be safe because I'm in chi town
Old 01-31-2013, 01:52 PM   #23
Mista_rogers2002
Member#: 345530
I used a brush and paint from the factory and it looked like ****.
Mista_rogers2002 is offline   Reply With Quote
Old 01-31-2013, 01:57 PM   #24
sabregen
Member#: 338852
2013 WRX Premium
WR Blue
did my WRB with the brush/pen from the dealership the other day. can totally see it from 6ft. i didn't really have an option though. in most cases, it was all the way down to the primer. did about 20 spots. have owned the car for 2 months. not excited about that.
sabregen is offline   Reply With Quote
Old 02-01-2013, 03:25 PM   #25
Arwing19
Member#: 341137
2009 WRX
Couldn't agree more, my old impreza was impossible to match. I tried both methods and brush seemed to work the best!
Arwing19 is offline   Reply With Quote
