Old 09-15-2002, 02:19 AM   #1
codemunky
Member#: 1804
Default Engine vibrating, check engine light on
My car is vibrating like crazy on idle. And the CHECK ENGINE light is flashing. What's the problem? My fuel tank is full. Air filter, somewhat dirty. I'm sure I tightened fuel cap all the way.
Thanks.
codemunky is offline   Reply With Quote
Old 09-15-2002, 06:03 AM   #2
Glockperfection
Member#: 10135
MY02 IMPREZA WRX
platinum Silver
uh oh, dealer time. If it's flashing that means somethng is really messed up. Perhaps the engine is misfiring? It happened to me the first week I got my car, the coil plug fall off a spark plug.
Glockperfection is offline   Reply With Quote
Old 09-15-2002, 07:50 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A flashing CEL means a misfire is being detected NOW. You should not drive in this condition especially if it's bad enough that you can feel it.
First thing to check is plug wires, make sure they are all tight and in good shape. Could also be a bad/fouled plug or a bad coil pack. If nothing visually looks wrong you can pull the plugs out to see if one shows signs of fouling or improper burning.
Also watch the engine as it idles at night, if there is a coil or wire arcing you should be able to see it.
06 sti check engine and cruise drive lights on. Black hawk 06 Newbies & FAQs 11 01-09-2009 11:15 AM
Engine vibration -- Bad engine/tranny mounts? texan5 Tribeca Forum 0 10-08-2007 01:10 PM
Check engine and cruise control light on TENAZ Engine Management & Tuning 6 03-13-2007 01:16 PM
check eng light on tell me what u think avengermike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-17-2005 04:35 PM
Check Engien light on?? After heave mods... comcop General Forum Archive 3 02-06-2001 06:57 AM
