Old 12-28-2012, 11:59 AM   #1
Suspence
Member#: 184294
2010 STi
Default Flutter under boost?
I have been experiencing a bit of Turbo flutter when I'm in boost, i've heard it about three times since I last had my car tuned with a few parts installed. (DP, Headers, Exhaust). I figure that it's air being pushed back into the Turbo or maybe because I'm running a stock BOV? Not sure, still new to turbo vehicles.
Any help would be appreciated, need a solution so I don't damage anything.
Thanks,
-Spencer
Suspence is offline   Reply With Quote
Old 12-28-2012, 12:04 PM   #2
Stoutjr
Member#: 318113
2004 STi
Sounds like its letting out air at an early psi. May want to bring it up to the tuner that its letting out the boost to early.
I have this this same problem when I adjust my waste gate too low.
Stoutjr is offline   Reply With Quote
Old 12-28-2012, 12:09 PM   #3
Suspence
Member#: 184294
2010 STi
Oh ok, got it. How bad of a problem is it to have? If I somewhat baby the car for a few weeks until I can get back to my tuner. I still have power, I just hear it and it doesn't sound too healthy.
Old 12-28-2012, 12:20 PM   #4
The Duke
Member#: 264877
Or it's just the internal wastegate flapping around and doing it's job. Happens with intakes mostly, but downpipes can let enough sounds through to make it audible as well.
It's wastegate flutter. It's caused by the BCS system opening/closing the wastegate to modulate the boost pressure. In stock form, there's enough pipe mass/baffling so don't hear it. With aftermarket intakes, thinner wall/less restrictive pipes the sounds permeates more into the cabin. If anything the sounds is something you want to hear, as it means the system is doing it's job.
I'm going to take a guess it happens mostly at higher gears in lower rpms at full boost? Didn't really happen until you put the aftermarket parts on?
The Duke is offline   Reply With Quote
Old 12-28-2012, 12:47 PM   #5
Suspence
Member#: 184294
2010 STi
Exactly.
It doesn't happen until 4-5kRPM, under a lot of throttle pressure. That's good to hear though, I just was hoping it wasn't doing any damage of any sort.
Thank you for the information.
-Spencer
Helps a lot!
Old 12-28-2012, 01:28 PM   #6
RoadKillDMD
Member#: 284792
2011 STI
Blurple
+1 I agree with this ^^^
OP, to be safe, to you have an AP or other tuning software on you laptop, you should take a couple of data logs to check I'd things are running okay.
Wut? Sounds like you're just talking out your arse... Don't spread useless misinformation. It makes you look really stupid
RoadKillDMD is offline   Reply With Quote
Old 12-28-2012, 01:45 PM   #7
Stoutjr
Member#: 318113
2004 STi
Lol just an observation, had this problem when I had an electronic boost controller freshly put on. Solved by changing BCS settings. Suppose I was a too vague. My bad
Old 12-28-2012, 03:39 PM   #8
Half Crazed
Member#: 321842
2008 STi
I have the same fluttering when I hit 17lbs.. but I'm aftermarket. Pretty sure it's normal so you don't blow your engine.
Half Crazed is offline   Reply With Quote
Old 12-28-2012, 04:09 PM   #9
tuzzio
Member#: 292532
05 STI
It's the BCS opening and closing when you're at full boost.
tuzzio is offline   Reply With Quote
Old 12-28-2012, 10:12 PM   #10
hutch959
Member#: 267463
at what rpm and throttle position? if is lower rpm at wot its more than likely turbo surge. ... like a "cha, cha,cha, cha" sound.
hutch959 is offline   Reply With Quote
