Old 09-15-2002, 04:38 AM   #1
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
Cool MY02 STi Colour Coding ...
Finally managed to get some colour coding done to the car aswell as get the side indicators replaced... so long to that ugly orange. For those of you interested in taking a look at the colour coded front reflectors and mirror supports you can see some photos I took today here:
http://photos.smktech.com.au:58885/g...oded&preview=1
The paint match came up flawless as you can see in the image below:
Any thoughts?
Gerrod
fatcatwrx is offline   Reply With Quote
Old 09-15-2002, 04:41 AM   #2
WRX_Colin
Member#: 15960
Dirt/Sap
Nice lookin ride man!
WRX_Colin is offline   Reply With Quote
Old 09-15-2002, 06:39 AM   #3
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
Thanks, much appreciated
Whilst it may look stock, I've actually had a little bit of work done to it to help it realise it's potential
See here:
http://photos.smktech.com.au:58885/g....jpg&preview=1
Gerrod
Old 09-15-2002, 02:52 PM   #4
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Gerrod-could you do me a huge favor and measure the distance between the door crack and the outside edge of the side marker. A picture with a ruler measuring the distance would be perfect. Would you sell me the orange one? Thanks!
Jay
illmatic is offline   Reply With Quote
Old 09-15-2002, 06:21 PM   #5
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
Jay
I'll see if I can get you a photo of the measurement tonight but I don't think I've got an imperial ruler lying around so you may have to make do with metric.
As for the orange indicator I wont be selling them as I want all of my parts to return the car back to stock for when I sell it.
Gerrod
Old 09-15-2002, 06:27 PM   #6
illmatic
Member#: 3536
Metric is fine
Old 09-16-2002, 12:16 AM   #7
SubaruRules
Member#: 20267
|'02 GGA WRB|
|'03 BH6 PSM |
Exclamation Um....
Nice man. Do the tires suck?
SubaruRules is offline   Reply With Quote
Old 09-16-2002, 12:46 AM   #8
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
Default Re: Um....
I've actually found the tires to be really good, but then again... the STi does come with different and more tread than the standard WRX as you can see here:
In the above photo you can see that the tires are actually Bridgestone RE040 225/45R17's which means they are considerably wider that those on the US WRX.
If they weren't so expensive I wouldn't see why I would get anything else but the same tires when I was due for new ones.
Gerrod
Old 09-16-2002, 05:37 AM   #9
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
Jay
Here you go.. couldn't quite get the ruler in place whilst being far enough away not to cause a hot spot with the camera. Either way you get the idea... the ruler shouldve been slightly more to the right, which makes it pretty damn close to 1 1/4 inches. Of course this can be a tad difficult to see as the seam to the door isn't straight.
Gerrod
Old 09-16-2002, 05:41 AM   #10
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
Thumbs up
And for those of you interested, yes... the side repeaters do still flash orange.
Gerrod
Old 09-16-2002, 11:40 AM   #11
Syntax
Member#: 14452
I have got same car as your but mine is in white....
What mods have you done to it?
and is the dyno figure at the wheels or at the fly wheel..?
Nice mod... I am wanting to get the STi carbon indicator...
Syntax is offline   Reply With Quote
Old 09-16-2002, 01:32 PM   #12
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Wow.... that's a real STi... very nice...
ejicon is offline   Reply With Quote
Old 09-16-2002, 04:38 PM   #13
Thumper23
Member#: 11571
God I love those rims
Thumper23 is offline   Reply With Quote
Old 09-16-2002, 06:31 PM   #14
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
The figure quoted is at the flywheel... I have the APS STi Sprint Spec fitted which I'd give you the link to but unfortunately the web site is currently down. When it's back up I'll throw the link in here.
In addition to that kit I've also got the APS High Flow Air Intake which goes down into the gaurd on the drivers side and takes air from infront of the wheel. Air flow can be greatly improved just by simply popping off the front foglight protector exposing the inner guard to the oncoming air.
Gerrod
Old 09-17-2002, 01:29 AM   #15
Syntax
Member#: 14452
Thanks for the info fatcatwrx...
Just another question... do you know what is the standard boost on a stock STi?
and also, what boost are you running on now?
Old 09-17-2002, 04:10 AM   #16
fatcatwrx
Member#: 18173
2002 Impreza STi
WR Blue
Smile
The stock STi runs 17.5psi at about 4000rpm... I'm now running only about 18psi but it holds a lot stronger as opposed to the stock boost curve which drops off to about 12psi at redline, whereas I'm running about 15-16psi at redline.
Gerrod
Colour code for STI pink Mutsuraboshi Interior & Exterior Modification 5 09-24-2003 09:15 PM
OT: Colour Code For Car fukamoto Vancouver Impreza Club Forum -- VIC 3 05-23-2002 10:51 PM
OEM harness colour codes Peaty Car Audio, Video & Security 12 09-09-2001 11:06 AM
('93-'01) Diff between colour code vs chromavision? Scoobie Newbie Impreza Forum 3 08-26-2001 03:30 AM
Colour code for WRC Prodrive paint KK General Forum Archive 0 12-02-2000 09:54 PM
