Old 12-28-2012, 11:36 PM   #1
-] Kenpachi [-
Member#: 211890
Default Timing belt jumped 2 tooth.
Is the white mark on the belt suposed to be align on that cam notch? Because I'm sure it jumped 2 teeth, because of that crazy sound in the head.
I have a ej253 by the way.
Thanks
-] Kenpachi [- is offline   Reply With Quote
Old 12-29-2012, 03:07 AM   #2
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
When you're first putting it on it's more just a guide (have all three line up straight with the line on the block) the service manual will also say how many teeth are between the right cam sprocket to the crank, then from that to the right cam. As soon as the belts on and the tensioner is uncompressed and you turn the crank those lines won't line up on the belt with the lines on the sprockets anymore especially if it's a different amount of teeth for each side like the ej22 is 44 on one and 42.5 on the other.
If it made a some unusual sound you might have hit a valve(s) with the piston
alt14 is offline   Reply With Quote
Old 12-29-2012, 03:20 AM   #3
darksc00by
Member#: 102140
The cams and belt won't line up after the engine has been ran, check your timing marks on crank and cam gears.
darksc00by is offline   Reply With Quote
Old 12-29-2012, 10:10 AM   #4
-] Kenpachi [-
Member#: 211890
And let's say I can't find any notch on the left cam sprocket. There are some yellow marks though. Any idea on how to check this?
Old 12-29-2012, 12:39 PM   #5
alt14
Member#: 271928
2014 WRX Limited
There should be a line pressed into the cam sprocket, and usually they have yellow paint on them.
Take a wire brush and lightly brush the surface to see of you can find it, you also might want to keep a wrench on the center bolt to keep the sprocket from moving while cleaning it off
Old 12-29-2012, 10:16 PM   #6
-] Kenpachi [-
Member#: 211890
Thank you all guys. I realigned everything and it turns super smooth. Didn't do a compression test do.
