Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 12-29-2012, 01:10 AM   #1
scx89
Member#: 269388
2011 Impreza WRX
obp
Default 2011 WRX CEL after fixing blinker
I just took off my intake so I can reach into the blinker bulb to fix it. It had a fast blinking problem and the dealership just couldnt fix it lol. Turns out it was a loose bulb...
Anyways, during the intake uninstallation i saw that there was a lot of bees and random crap in my filter, so I just tapped it on the floor to get anything heavy out of the filter. Then I put everything back together and when I turn on the car afterwards I get a CEL with the codes reading
P0102 - MAF sensor low circuit
P0113 - intake air temp circuit high input
I'm hoping those just came up because I slightly cleaned up the filter or it was because of moving the MAF sensor a bit. I didn't disconnect the battery while doing this - am I supposed to?
Is there anything I should be watching out for?
scx89 is offline   Reply With Quote
Old 12-29-2012, 05:55 AM   #2
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
reset the connection to maf sensor.
Old 12-29-2012, 11:40 AM   #3
Half Crazed
Member#: 321842
2008 STi
Clean your MAF sensor if the above doesn't work. You can pick up a can of maf cleaner for pretty cheap at auto stores.
Half Crazed is offline   Reply With Quote
Old 12-29-2012, 12:36 PM   #4
Tripintaz
Member#: 245218
2013 STI Limited
Ice Silver
Make sure everything went back together properly and you tightened up the connection after the MAF and that your MAF was plugged back in.
Tripintaz is offline   Reply With Quote
Old 12-29-2012, 02:30 PM   #5
tuzzio
Member#: 292532
05 STI
Also make sure you didn't put the maf on backwards
tuzzio is offline   Reply With Quote
Old 12-29-2012, 10:58 PM   #6
StealthTL
Member#: 206912
2006 Forester XT
MAF doesn't fit in the stock filter housing backwards, screws won't line up.
StealthTL is offline   Reply With Quote
Old 12-30-2012, 12:09 PM   #7
xxxhpdrw
Member#: 206183
2008 WRX
Spark Silver
It sounds like its not plugged in or not plugged in all the way. If not, check the wires going into the maf connector if the look pulled out that's your problem. The maf sensor has the intake air temp sensor built into it. So if the connector is no priestly seated both codes will come on.
xxxhpdrw is offline   Reply With Quote
Old 12-30-2012, 03:14 PM   #8
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Satin White Pearl
I, too, would just re-check the maf connections and assure it is seated properly. I'm doubtful your maf needs cleaning already on a 2011, but it's possible. Please report back.
Decipher is offline   Reply With Quote
Old 12-30-2012, 05:31 PM   #9
scx89
Member#: 269388
2011 Impreza WRX
obp
Thanks everyone, i replugged the connection and it has been perfectly fine.
Old 12-31-2012, 01:19 PM   #10
Decipher
Member#: 262760
Satin White Pearl
That's as easy of a fix as they come!
Message Board Statistics All times are GMT -4. The time now is 01:59 AM.
