Old 01-01-2013, 03:36 AM   #26
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
want a oem type turbo thats better and fully rebuildable, get a 16g, want a slightly slower spooling turbo that would kick you in the nuts, get a 20g. or go rotated and stop ****ing around wasting money.
scby rex is offline   Reply With Quote
Old 01-01-2013, 03:00 PM   #27
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
No turbo upgrade is a waste of money. There are drivers looking for all levels of power. I did a vf39 for a customer that is scared of it, not a waste for him. For those looking for 300 to 350 there is no need to go rotated or even front mount. There is no one size fits all. I play with all kinds of setups just to get a feel for them. I've done six combo's in my car this year ( well I guess last year now). I am running a 20g right now but when my vf48 comes back I will run it in one of my cars.
Old 01-01-2013, 04:44 PM   #28
WhatTurboLag?
Member#: 243992
2006 WRX TR
Exactly. I want to try new and different things.
WhatTurboLag? is online now   Reply With Quote
Old 01-01-2013, 06:07 PM   #29
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
Originally Posted by Uncle Scotty View Post
you want the best street turbo for a dd 2.5???
td06sl-20g with the xl wheel and with the 8cm hotside
and stop screwin around with the stupid vf garbage
Yep, I agree. You are a bit of a di*k, but you are right
noonagon is offline   Reply With Quote
Old 01-01-2013, 08:13 PM   #30
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Originally Posted by WhatTurboLag? View Post
Anything stock location is a waste and garbage. I'm not buying anything stock location other than messing with the turbo I have now.
You're clearly new here, or at least to turbo's and Subaru's. Many stock location turbos can put down great numbers. Saying what you said is simply stupid.
But is you want td04 like spool with vf power and good transient response. This is the thing to get.
Also can run Moar boast
Boast? I assume you mean boost. And even so, you're not gaining a lot by swapping out a wheel. You'll still max out the turbo fairly quickly. Plus boost is not a direct correlation to power.
Simply put, this whole thread is pretty useless. I even took my time to clean the damn thing up. If you want more power, get a better turbo.
Old 01-01-2013, 08:24 PM   #31
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
^ Glad to see I wasn't the only trash taken out
sense of nature is offline   Reply With Quote
Old 01-01-2013, 09:33 PM   #32
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
Outside if the 'e-p##&#' fight in this thread there is good advice here.
If you have a low mileage vf and for whatever reason it needs a rebuild, this could be a good option.
If you are looking for more power, then it probably makes more sense to set your goal, and start looking at how you want to get there. Big snail on pump? Small snail on meth? E85?
geddesk2 is offline   Reply With Quote
Old 01-01-2013, 10:24 PM   #33
WhatTurboLag?
Member#: 243992
2006 WRX TR
Yes, I was on my iPad and the auto correct made it boast and I didn't see.
I said that because I think it's pretty much a waste of time for my goals. I know stock location turbos can make good power because I have a hard time not getting one.
And how is this thread useless? I don't see any other threads talking about this? If I do please point me to it.
I never said I was even looking to make more power I just wanted to try it and see what happens.
Old 01-01-2013, 10:54 PM   #34
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
I'm interested in the results.
I hope mod maniac posts up his findings.
theotherguy is offline   Reply With Quote
Old 01-01-2013, 11:13 PM   #35
holyjoetart
Member#: 232986
07 Legacy GT
I read your post and clearly understand what you're asking.
I think this upgrade is illogical.
Your gains will be negligible at most.
You can only push so much air through those tiny little housings.
There are better ways to spend $500.
holyjoetart is offline   Reply With Quote
Old 01-02-2013, 04:16 AM   #36
WhatTurboLag?
Member#: 243992
2006 WRX TR
500 for a full rebuild and a port and polish and a new compressor wheel isn't bad....
Old 01-02-2013, 06:46 AM   #37
FRWRX
Member#: 15306
2011 STi
White pearl
I beleive it can make sense because unlike some beleives here, VF series turbos are great, especially VF48 which gives full bost before 3000rpm and 380bhp on the 2.5L with pump gaz. So 500 bucks to gain 30 to 40 bhp and keep a good spool worth it.
So I really hope mod maniac will post up his findings ;-)
FRWRX is offline   Reply With Quote
Old 01-02-2013, 10:04 AM   #38
The Duke
Member#: 264877
Would these things need new injectors and a fuel pump? If someone wants to get that little extra power when they alreaqdy have to replace a worn part, I don't see what's wrong with this. Besides, a higher response can be more advantageous in racing applications than just moar power. (I'm no turbo guru, just the basics). If this is literally a bolt in upgrade (sans maybe tuning, but with these cars that's a given), it could be a nice end of the line upgrade. No need for injectors, pump, or a new IC could help the decision a lot. Sure, it's 500 bucks for 30hp/spool, but given what people pay for a cat-back, at least there's gains. The OEM turbo can use an upgrade, this could be a nice little upgrade if it fits in someone's plans (like mine).
The Duke is offline   Reply With Quote
Old 01-02-2013, 02:17 PM   #39
Rally2
Member#: 132023
2005 STI
blue
I'm also hoping mod maniac bolts it onto something and does before / after comparison
Rally2 is offline   Reply With Quote
Old 01-02-2013, 06:15 PM   #40
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
$500 for a complete rebuild, PnP and new compressor wheel sounds alright to me! Still much cheaper than an oem replacement with some power gains!
Mike
GrimmSpeed is online now   Reply With Quote
Old 01-02-2013, 07:59 PM   #41
scby rex
Member#: 104878
02 wrxbastardchild
I would **** a brick if this made 30-40 whp, even after a 600$ protune. 5-10..maybe. pnp doesnt really do **** on that tiny ass hotside though. 500 bucks could be better spent on hookers and blow.
Old 01-02-2013, 09:09 PM   #42
matts
Member#: 322939
10 WRX
96 LSi
awesome. best response yet.
matts is offline   Reply With Quote
Old 01-02-2013, 09:11 PM   #43
WhatTurboLag?
Member#: 243992
2006 WRX TR
Then get the bigger hotside for the vf.
Old 01-02-2013, 09:17 PM   #44
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Seems like BNR is successful stuffing td05 16, 18 and 20g chra's into those small vf hotsides. In a vf40 no less.
Old 01-02-2013, 10:29 PM   #45
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Im sorry to disappoint you guys but this turbo will be going in my wifes car. It's a 94 impreza that will have a 03 wrx upgrade. The turbo is on the way back right now but I can't convert her car till after winter when she doesn't need it. There is the possibilty that my other 02 will be back from the body shop (rolled it) before then and I could try it on that one but either way it will have to wait. Im not going to put it on the one im driving. About all I can do is post pic.
Old 01-02-2013, 10:38 PM   #46
WhatTurboLag?
Member#: 243992
2006 WRX TR
Pics ftw
Old 01-02-2013, 10:47 PM   #47
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Pics ftw
Ok I will post them when it gets here. They said it shipped yesterday.
Old 01-03-2013, 12:10 AM   #48
theotherguy
Member#: 191514
'05 FXT 6spd, 98
That's exactly what I had in mind for a billet wheeled vf, a daily driver 2.0 with some oem 560 top feeds. Be a nice 500 cfm turbo for cheap, already have 2 blown vf39s on a shelf.
Old 01-03-2013, 01:03 AM   #49
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
The Wifes engine is also a 2.1 stroker but she doesn't want it to be scary. So she gets the vf48. She doesn't like my car.
Old 01-03-2013, 08:43 AM   #50
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
wont be big enough
i promise
