Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 03-31-2013, 01:38 PM   #151
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
I should have it on tomorrow.
I just drove tractor trailer from dallas to san diego in less than 24hrs, so im a little tired.
08WRXNUBE is offline   Reply With Quote
Old 03-31-2013, 01:42 PM   #152
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
Originally Posted by WhatTurboLag? View Post
But is you want td04 like spool with vf power and good transient response. This is the thing to get.
Also can run Moar boast
I see 20psi on my EVoIII 16G by 3400 rpms. You don't really need much better spool than that.
codesoccer is offline   Reply With Quote
Old 03-31-2013, 02:02 PM   #153
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Not to bad.
Old 03-31-2013, 03:01 PM   #154
WhatTurboLag?
Member#: 243992
2006 WRX TR
For some, like with a 2.5l a 10cm 16g might be a good option. It's also 1200 dollars.
I see 20psi by 3000 rpm on my vf...
WhatTurboLag? is offline   Reply With Quote
Old 03-31-2013, 03:34 PM   #155
chemtek
Member#: 310710
2008 Impreza WRX
I bought my pnp hot side vf52 late last summer from 6speed and finally got around to installing it in my 2008wrx. I bought this turbo from their stock and was delayed because they never had some gaskets needed for rebuild. They too sent me a Perrin turbo blanket because of the delay. My butt dyno says it's a lot faster and virtual dyno show nice upgrades but haven't actually protuned it yet. Currently running Torqued Performance stage 3.52 map with all supporting mods. (Process west top mount, 3 port and turbo). Also have tomei eql headers and up pipe, Cobbs downpipe, aem intake and invidia q300.
I am currently dealing with a strange boost issue which I hope is a leaky bpv. I hit max boost of 20psi but it doesn't hold.
Here's the virtual dyno graph
chemtek is offline   Reply With Quote
Old 03-31-2013, 03:47 PM   #156
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
How long have you been running erics map?
Old 03-31-2013, 04:15 PM   #157
chemtek
Member#: 310710
2008 Impreza WRX
I have been running Eric's stage 2 map on the my td04 since last November. I have only been running the new map for the vf52 for about a week and am on revision number 3. I'm sure the tune is not the boost issue or the turbo. I don't even see how the turbo could be to blame for the boost issue. I have an aftermarket bpv lined up and if this doesn't correct and hold steady boost, I'll look at pressure testing system at shop.
Old 03-31-2013, 04:27 PM   #158
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
What bov are you running?
Forge?
Old 03-31-2013, 04:31 PM   #159
chemtek
Member#: 310710
2008 Impreza WRX
I just have the plastic stocker right now. Picking up a lightly used turbosmart recirc from a fellow enthusiast.
Old 03-31-2013, 04:32 PM   #160
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Ok can someone explain to me why we can not attach a photo on here.
Do i really have to do it via a link.
Old 03-31-2013, 04:34 PM   #161
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Chuck that plastic pos.
Does the turbo smart have differnet springs?
Either way that should help with holding the boost. Just dont use rtv on any connecting surface.
Old 03-31-2013, 04:43 PM   #162
chemtek
Member#: 310710
2008 Impreza WRX
Previous owner is including the spring that comes with bpv and a softer one he bought afterward. Hopefully this corrects issue and my 6 speed review can be a little more complete. I don't plan on using silicone rtv. The stock gasket that comes with bpv is paper. Previous owner made a cork gasket. I'll probably do the same.
Old 03-31-2013, 04:55 PM   #163
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Lets us know how it works out.
Old 03-31-2013, 06:02 PM   #164
masayver
Member#: 176021
2011 Impreza WRX
Lighting Red
I hope you get your boost issue sorted to get good data for comparison. I have similar mods (AEM CAI, Tomei ELH and UP, GS EBCS, CNT catted DP, but still stock CBE and unmodified VF52) and I'm at 20 psi at around 3300 RPM in 3rd gear. Eric is still doing fine tuning on my map.
Last edited by masayver; 03-31-2013 at 06:05 PM. Reason: specify I still have unmodified VF52
masayver is offline   Reply With Quote
Old 04-02-2013, 12:11 AM   #165
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
^^^ those numbers are kinda low with those bolt ons and @20psi
Is the tune conservative ?
I'm at 300/320 at 17.6psi no EBCS yet
Only intake , FMIC and catless DP
I'll be getting another tune soon tho ... I just added a bunch of bolt ons
Hoping for 315/335
ANR62NV is offline   Reply With Quote
Old 04-02-2013, 12:35 AM   #166
masayver
Member#: 176021
2011 Impreza WRX
Lighting Red
Hoping for 315/335
I'm still going through an e-tune process. My road dynos have ranged from 300/315 to what you see in the graph. Assuming knock doesn't become an issue with some timing advance, I should see slightly higher numbers in the next few revisions. I am looking for a conservative tune as I track my car a couple times per year.
Old 04-02-2013, 01:37 AM   #167
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
The numbers are low because its street tuned vice dyno. Either way numbers are just numbers.
All i have for mods om my 08 are tbe, 3port ebcs, intake, recirc bov, fuel pump, and the VF52.
300whp 331wtq.
Old 04-04-2013, 12:29 PM   #168
meat_WRX
Member#: 96919
2004 sti
black
Hoping for 315/335
an ebcs isnt gonna give you any more power really.
meat_WRX is offline   Reply With Quote
Old 04-05-2013, 10:31 AM   #169
decodeddiesel
Member#: 64102
I ran a PnP 6-Star VF39 on my STi with an EWG for a while and I was really impressed with the quality of work and performance on the turbo.
I would be curious how this would do on the setup I will have after my motor is finished on my 05 STi.
  • 99.5mm CP Pistons
  • ACL Race Bearings
  • One Step Colder NGKs
  • Grimmspeed uppipe
  • Tial 38mm MV-S
  • Grimmspeed EBCS
  • Invidia EL race headers
  • Invidia dp with Cobb cb
  • DW300 fp
  • DW850 injectors
  • AMR hardinlet
  • TGV deletes
  • K&N intake
  • E85
I'll still probably go with a Morrocco88 pipe set-up and a Borg Warner S200SX-56. Interesting idea though.
decodeddiesel is offline   Reply With Quote
Old 04-07-2013, 11:52 AM   #170
tuzzio
Member#: 292532
05 STI
How did that vf compare to the stock vf?
tuzzio is offline   Reply With Quote
Old 05-04-2013, 10:00 AM   #171
Rally2
Member#: 132023
2005 STI
blue
bump - any more info on six star VF39's?
Rally2 is offline   Reply With Quote
Old 05-27-2013, 09:12 PM   #172
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
I just got another car and will be installing my ssp vf48 on a stroker with meth and an ewg
Old 06-04-2013, 07:55 PM   #173
meat_WRX
Member#: 96919
2004 sti
black
just bought a vf48 that needs rebuild, it will get some upgraded treatment for my automatic 2.5 setup
Old 06-06-2013, 01:50 AM   #174
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Go for the pnp with the billet wheel. Just be patient six star is super busy and turn around time is about 3 weeks, but its well worth the wait.
Old 06-06-2013, 08:50 AM   #175
Rally2
Member#: 132023
2005 STI
blue
Pics of PnP VF39 from SixStarSpeed next to Greddy 18G. Been busy working but soon should have time to get the VF39 installed in my WRX along with a few other mods. Might go EWG still debating, at minimum I'm gonna install EWG uppipe and blank if off for future.
