Old 12-29-2012, 03:24 PM   #1
bettrave
Member#: 340852
2013 Impreza "base"
Default Can't lock/unlock doors
Hi,
I can't lock or unlock the two doors on the driver's side using the the remote button on the key or the power lock/unlock button inside.
I own a Impreza 4 doors, base model and it's only about 3 weeks old.
Anyone has or had the same problem.
Thank you and Happy New Year!
bettrave is offline   Reply With Quote
Old 12-29-2012, 04:17 PM   #2
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Is it weather related? How cold is it where you live? Can you unlock the doors manually?
sgoldste01 is offline   Reply With Quote
Old 12-29-2012, 04:25 PM   #3
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
i have a dream that one day, we will have a completed profile and more information then again it was only just a dream
aeoporta is offline   Reply With Quote
Old 12-29-2012, 04:46 PM   #4
bettrave
Member#: 340852
2013 Impreza "base"
Well, cold, yes.
About 14F (-10C).
But, if it was cold related, all my doors would be affected?
It started by the rear and then the driver.
Old 12-29-2012, 04:59 PM   #5
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
Originally Posted by bettrave View Post
Well, cold, yes.
About 14F (-10C).
I would guess it's moisture related. Perhaps the drivers side was windward when freezing rain or ice was coming down, the wind worked it into the doors and froze the mechanical part that works the lock from the electrical relay. Can you find a heated place to park for a bit to see if unfreezing it would fix it?
tomwi53092 is offline   Reply With Quote
Old 12-29-2012, 09:57 PM   #6
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Does it unlock manually?
Old 12-29-2012, 10:48 PM   #7
bettrave
Member#: 340852
2013 Impreza "base"
Manually, yes.
Old 12-30-2012, 03:43 AM   #8
ans2k
Member#: 315631
2012 Impreza Sport
check the fuses. when i was installing the rear hatch led light, i accidentally touched both wires and it blew a fuse. i forgot which one. but i couldn't lock or unlock my doors with my key fob but i could still lock and unlock the door if i had used my key manually.
ans2k is offline   Reply With Quote
Old 12-30-2012, 08:09 AM   #9
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Bettrave said that his locks are working normally on the passenger's side; it's only the driver's side that's not working.
I'd say that you should probably have this checked out and fixed by the dealer, under warranty. Shouldn't be a big deal.
Old 12-30-2012, 08:13 AM   #10
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Do you by chance have access to a heated garage for a couple of hours just to see if things begin working after that? That may help determine if it is moisture/temperature related.
John
Guzzi 1 is offline   Reply With Quote
Old 12-30-2012, 09:27 AM   #11
bettrave
Member#: 340852
2013 Impreza "base"
If it's moisture/temperature related, it would mean that the Impreza isn't well made.
Last night, we had family for a party.
I did a small survey.
Everybody live in my region, so moisture/temperature should affect their car too.
Relsults.
Nissan Versa 2010, Mazda 3 2012, Mazda 3 2008, Toyota Matrix 2011.
None had any problem!
Old 12-30-2012, 10:11 AM   #12
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
Relsults.
I certainly was not trying to blow it off as normal. Only trying to determine why it is happening. If it is moisture or temp related, that could help them in correcting the issue, that's all.
John
Old 12-31-2012, 05:04 PM   #13
bettrave
Member#: 340852
2013 Impreza "base"
Went to the dealer today.
Something was "unhooked" inside the door.
What? I don't know.
They didn't give much detail and I didn't ask.
I was just happy that it was working.
