Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 12-29-2012, 06:06 PM   #1
maliciousmic
Member#: 274394
Default Check engine light help
My CEL came on and was putting out the following code: P0138 O2 sensor circuit high voltage (bank 1 sensor 2). Can anyone shed some light on this for me...I'm not too good with CEL codes
maliciousmic is offline   Reply With Quote
Old 01-03-2013, 07:29 AM   #2
monstor955
Member#: 288540
google
monstor955 is offline   Reply With Quote
Old 01-03-2013, 01:38 PM   #3
Strider327
Member#: 131280
2004 Impreza WRX
What does that mean?
The Heated Oxygen Sensor (2) located rear of catalytic converter produces an output signal relative to oxygen storage capacity of catalytic converter. Ho2S 2 signal is less active than signal produced by front oxygen sensor. This code sets when HO2 Sensor voltage is greater than 999 mV for more than 2 minutes (time depends on model. Could be as high as 4 minutes)
Symptoms
There may be no noticeable symptoms except for MIL illumination. Possible high fuel pressure can over rich the system.
Causes
A code P0138 may mean that one or more of the following has happened:
Faulty O2 sensor
Short to battery voltage in O2 sensor signal circuit
High fuel pressure (not as likely)
Possible Solutions
Here are some potential solutions:
Replace O2 sensor
Repair short to battery voltage in o2 sensor signal circuit
Strider327 is offline   Reply With Quote
Old 01-03-2013, 03:01 PM   #4
maliciousmic
Member#: 274394
Awesome thank you
Old 01-04-2013, 12:44 PM   #5
Strider327
Member#: 131280
2004 Impreza WRX
No problem. More than likely the O2 sensor is shot.
