Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-29-2012, 07:21 PM   #1
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Default Where to get pre-purchase inspection done on a turbo model?
The only places I have any experience with are Goodspeed before they moved north and the Superstore. I am in SE Chandler and the car I am thinking about is as well, so Goodspeed is pretty far away now. Anything in particular that should be checked on a turbo that they might not normally check?
Thanks, Doug
dvancleve is offline   Reply With Quote
Old 12-29-2012, 08:40 PM   #2
zachd
Member#: 267575
2008 STi
So more info on said car would be useful to us..
zachd is offline   Reply With Quote
Old 12-29-2012, 09:36 PM   #3
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Barry, AKA Japcarrealgood, has a shop that can help you out.
C-grunt is offline   Reply With Quote
Old 12-29-2012, 10:53 PM   #4
dvancleve
Member#: 5211
It is a stock Outback XT (so 2.5 turbo) with manual transmission, a trailer hitch is supposed to be the only mod...
Thanks, Doug
Old 01-05-2013, 02:33 AM   #5
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
99OBSTi 91NSX 06 9-2xAero
OMGHi2U
Thanks C-grunt!
dvancleve you have a PM.
-DBB
JapCarRealGood is offline   Reply With Quote
Old 01-09-2013, 02:36 PM   #6
dvancleve
Member#: 5211
Well Wrench Auto WorX sounds great but Glendale is a solid hour each way from the seller's house. The Superstore is close, but I would prefer a non-dealer if possible. Any other suggestions closer to SE Chandler?
Thanks again, Doug
Old 01-10-2013, 12:30 AM   #7
dvancleve
Member#: 5211
Okay, there is a nearly new WRX in Havasu that I might try to get. Any suggestions for a shop somewhere around there to check it out?
Thanks again, Doug
Old 01-20-2013, 09:30 PM   #8
dvancleve
Member#: 5211
No go on the WRX. I drove the OBXT again today, everything seems great but the clutch pedal is quite stiff. It is stiffer than anything I recall driving, including my brother's Mazda Speed3, a Ford Focus ST and an '11 WRX. The owner said it has always been that way or at least he never noticed a change. Does that seem normal? Is there something a dealer can check? If I do a PPI it will most likely be at the Superstore since they are close and I don't have any other near(ish) suggestions...
Thanks again, Doug
