Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 12-30-2012, 12:50 AM   #1
neilperry
Member#: 330340
2011 WRX
SWP 4Dr.
Default Stock dp
So a year ago I took my stock dp off including stock heat shield. Put an aftermarket dp on instead. Few months later decided I didn't like that dp and put the stock dp back on. Unfortunately lost oem heat shield and bracket.
Do I honestly need it?? I have a stock intercooler btw.
Oem heat shield/brackets for sale seperately ?? Or do u have to buy a new oem dp to have that stock shield there?
Another heat shield that would fit?? Do I even need one??
neilperry is offline   Reply With Quote
Old 12-30-2012, 12:53 AM   #2
ShinjiML
Member#: 257231
2011 STI
Just get a Turbo blanket, or make your own with unabomber's DIY tutorial. I'll actually work better than a heat shield.
ShinjiML is offline   Reply With Quote
Old 12-30-2012, 12:55 AM   #3
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Search "infrared" then make your own choice.
HeroCrank is offline   Reply With Quote
Old 12-30-2012, 01:06 AM   #4
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Did you tune for the aftermarket downpipe? If you didn't then that's why you didn't like it.
mrkyle3 is offline   Reply With Quote
Old 12-30-2012, 01:19 AM   #5
neilperry
Member#: 330340
2011 WRX
SWP 4Dr.
Turbo blanket sounds good.... Which one? Any drawbacks to using it
How bout a Cobb or Perrin or grimmspeed shield? Would they fit a bracketless oem dp?
Old 12-30-2012, 12:07 PM   #6
StackSmasher
Member#: 316928
2012 STI limited
I have a Perrin blanket and it works great. I hear the PTP lava is quite good as well. No drawbacks only a much cooler engine bay and TMIC.
also have the grimmspeed shield ceramic coated heat shield. I think it reuses the stock bracket tho. You can probably find one on here for cheap
StackSmasher is offline   Reply With Quote
Old 12-30-2012, 04:16 PM   #7
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Satin White Pearl
Definitely go for a turbo blanket since you don't have the bracket or anything. It just makes more sense in your scenario. Why hassle with obtaining parts when you can go a better, cooler route anyways?
Decipher is offline   Reply With Quote
Old 01-02-2013, 12:17 PM   #8
ShinjiML
Member#: 257231
2011 STI
I used thermotec, because it's cheap and DIY, but the others are good options as well, just more expensive
