Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 12-30-2012, 03:12 AM   #1
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
Default Forester suspension
I am looking to do some work on my 98 forester project. I know the 02-03 WRX and the 04' STI springs and struts will mount up without a problem. I was trying to get a answer if any other years would fit.
My major concern is the uneven rise height that can occur though. I was wondering if a WRX wagon set up would fix this problem.
bugeye-brawler is offline   Reply With Quote
Old 12-30-2012, 02:18 PM   #2
Kumachn
Member#: 264764
2004 Forester XT 5MT
Java Black Pearl
WRX Wagon Take-Offs should fit fine. I'm using these right now on my 2004 and feels just like stock.
The only issues you should really run into is Saggy Butt, which can be resolved with a 1/8 in Spacer. But with the Wagon Rear you may not need it due to the higher spring rate.
As for the springs with 04-07 you would need the Top hat for that year, I think it wider at the top of the spring.
+05 "STi" Struts are a bit diferent on one of the holes but can be drilled if done properly.
Kumachn is offline   Reply With Quote
Old 12-30-2012, 09:12 PM   #3
pleiad7
Member#: 71056
MY04 Forester XT
If you want to skip the saggy butt spacers, I'd recommend 02-03 WRX wagon struts with blue WRX Prodrive springs for a perfectly level ride height.
pleiad7 is offline   Reply With Quote
Old 12-31-2012, 02:33 AM   #4
bugeye-brawler
Member#: 182337
Sport -- White
It seems like wagon struts and will eliminate the problem. But is it the springs that are fixing the problem or the struts? And also if I get the springs and struts off a sedan will it just make the problem worse?
Old 12-31-2012, 04:47 PM   #5
pleiad7
Member#: 71056
MY04 Forester XT
It's the Prodrive springs in particular that even out the ride height because they're designed to have a "forward rake."
Old 01-07-2013, 10:16 AM   #6
KIRKOY
Member#: 115756
2002 wrx impreza
ASPEN WHITE
can u fit an 06 sti struts and springs on a 07 fxt? straigt up swap....?
KIRKOY is offline   Reply With Quote
Old 01-11-2013, 08:36 PM   #7
Topher03
Member#: 209375
2002 wrx wagon
Wrx wagon take offs will result in a saggy butt. I have 3/8th rear spacers and Im still a bit saggy. So Im going to swap over 05 sti front springs
Topher03 is offline   Reply With Quote
