Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-30-2012, 07:37 PM   #1
pearl08
Member#: 282356
2008 wrx
Default ipr top mount fitment issue
I bought an ipr top mount and have tried to install it. First the two bolt holes on the turbo side don't match up that well. But the biggest issue is the throttle body hose (avo) doesn't even come close to lining up with the top mount. How have any of you made this work
pearl08 is offline   Reply With Quote
Old 12-31-2012, 02:50 AM   #2
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
I installed a ebay tmi on a customers car that didn't line up. I installed the tmi to tb hose and then drilled new holes on the bracket.
Old 12-31-2012, 09:52 PM   #3
holyjoetart
Member#: 232986
07 Legacy GT
Even the perrin was a pain to install. I think gimmick makes a longer TB hose for the top mount. I heard it helps with the install.
holyjoetart is offline   Reply With Quote
Old 01-01-2013, 02:52 PM   #4
danger1138
Member#: 279525
04 rex luger!
Had alot of issues installing an ebAy tmic, its heavy and doesnt line up well. Instead of having the rubber coupler on the tmic itself, place it on the throttle body. Try that approach
danger1138 is offline   Reply With Quote
Old 01-01-2013, 08:32 PM   #5
pearl08
Member#: 282356
2008 wrx
That's what i did from the tb first then to the ic. Seems like the hose doesn't have enough bend to it. Maybe its just me but did you run into this
