Old 12-30-2012, 08:10 PM   #1
fullCircling
Member#: 290547
Default Can I fit a 2010 Legacy GT swap into '97 Legacy GT?
Just as the title states, would I be able to make it work with all/most of the stock components? I want to use the OEM turbo setup that mounts the turbo in front of the engine. Anyone know if I would I have enough clearance? Would the stock front crossmember be an issue?
Thanks,
-Jon
fullCircling is offline   Reply With Quote
Old 12-30-2012, 09:31 PM   #2
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
The wiring will be your biggest issue since the 2010 is a CANBUS system.
Old 12-30-2012, 09:48 PM   #3
fullCircling
Member#: 290547
Meh, I'm probably gonna go with a link storm g4 ecu and be done with it. I plan on creating my own harness anyways, I'm not too worried about that part of it, as I've done chassis harness rebuilds before.
I guess at this stage I'm more concerned about fitment considering the different palcement of the turbo stuff. Just picked up a set of brand new '10 legacy gt heads, man these things are sweet!
Old 01-04-2013, 08:25 PM   #4
Montero.shane
Member#: 342579
Default 99 swap
I have a 99 legacy gt but want to do a turbo build what ecu, turbo components, and what year would the parts come from? would I be able to use a link storm ecu on the build? Could I use the parts from a newer model legacy gt such as the 05.
Montero.shane is offline   Reply With Quote
