Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 06-20-2012, 03:14 PM   #1
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
Default Hard Wire Fuel Pump "How To"????
Im running out of fuel when I shouldnt be. Is there a write up of something that shows/tell how to hard wire the fuel pump to get constant voltage?
banshee04 is offline   Reply With Quote
Old 06-20-2012, 03:55 PM   #2
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
Huh? more info please. Big turbo, injectors, fuel pump, tune? What do you mean by "running out of fuel"?
Cr4ckfi3nd is offline   Reply With Quote
Old 06-22-2012, 12:12 AM   #3
banshee04
Member#: 179014
'06 WRX/STi
FP Red, 1400cc Inj, DW 300lph pump, E85 on only 23psi. IDC's are already at 97%. The fuel system is good for around 600Whp.
So I need to "re wire" the fuel pump where its gets constant voltage so the pressure doesnt drop off up top.
I really just need to know which wire on the fuel pump harness is the trigger wire for the fuel pump.
Old 06-22-2012, 01:45 AM   #4
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Increase fuel pressure.
Old 06-23-2012, 03:17 PM   #5
Tyrael
Member#: 139244
2002 EJ207 WRB WRX
I'm actually in the process of working on this right now. I helped hard wire a GC running on an AEM and was able to get the fuel pump at 100% all the time. I'm now working on my car (02 wrx) and if I run the pump 100% (Direct 12v from the battery via a relay - as the aeromotive pump instructions suggest and direct to ground) I'm getting a CEL for fuel pump primary circuit. While this makes sense to me and I can turn it off, I'm not 100% sure on if I need the ground to the chassis or if the controller's ground will net me the desired effect (keeping fuel pressure up top like the OP)
BTW OP:
Looking at the Male Connector (You can de-pin this and not have to cut the wires if you have another pin you can re-use like an injector clip) The Black with Red stripe is the 12v from the controller and the solid black below that is the ground from the controller. So:
Male
12v ? ?
G ? ?
I don't have a Fuel pressure gauge however my ID1000's are maxed currently (113%) on base Fuel Pressure, but only from 6k+ (I rev to 8 so that's a problem).
So if you could PM me the results of just doing the 12V constant and re-using the controller ground it would be super helpful. PM me with any questions / advice haha.
Mod Maniac may be correct in your case because your injectors are not maxed, however you're running out of fuel, but I know that the Aeromotive pump needs more amperage than the stock wiring can give it.
let me know how it works!
Tyrael is offline   Reply With Quote
Old 06-24-2012, 02:41 PM   #6
apexanimal
Member#: 170186
08 Fit
this was a common problem on neon srt4's... the wire gauge was too thin and would heat up and show a voltage drop...
painless makes a nice relay that you run a wire to the battery, a good ground, and then your switch line is your oem pump wire... that way you can run a heavier gauge power wire...
apexanimal is offline   Reply With Quote
Old 06-24-2012, 04:18 PM   #7
Tyrael
Member#: 139244
2002 EJ207 WRB WRX
Exactly what I did, except i used Ye Olde 30amp relay to power the pump (controller voltage is my on/off, clean ground and 12v from the batter via my existing sound system 0ga wiring).
So far so good...
Old 12-31-2012, 02:04 AM   #8
Irv Weissmanhowerton
Member#: 278519
30r E85 STI 450+whp
kb'izzle
bump, who's got some more stories?
Irv Weissmanhowerton is offline   Reply With Quote
Old 12-31-2012, 02:30 AM   #9
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
maxpowr is offline   Reply With Quote
Hard Wire Fuel Pump dunk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-14-2008 09:23 AM
hard wireing dual fuel pumps RichWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 09-16-2006 12:37 PM
STi Pad Replacement "How To" We're Here Brakes, Steering & Suspension 5 10-21-2003 04:24 AM
Anyone recommend a good book for Microsoft Frontpage "how to"? paultg New England Impreza Club Forum -- NESIC 15 10-18-2002 06:52 AM
Here is the "how to" gutting the uppipe GLwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-15-2002 12:18 AM
